Question about Dishwashers
Bosch SHU33A won't drain
Can you help concerning a bosch model shu33a will not drain water
Thamk you
  • kenny232 Nov 17, 2008
    Bosch SHU33 won't drain at all. This started after about 2 years of working with no problem. Bottom is completely full after a cycle and sometimes spills out on the floor. I've ensured the drain hose has the proper elevation. I've ensured the drain is not clogged.
    Sometimes I detect an electrical smell.
  • Anonymous Mar 04, 2009
    i have the very same problem
I believe you, but did you check the nipple on the drain where the hose connects?
My sink drained OK, and when I took the dishwasher hose loose from the sinkdrain it drained great into a bucket.
When I stuck a screwdriver down where the drainhose connects to the sinkdrain, I felt all kinds of resistance. Its now cleaned out and the dishwasher drains again.
Hope this is your problem otherwise you may need a new pump.
Posted on Mar 08, 2009
Bosch SHU33A-No Water coming out arms Top/Bottom.
this is suposed to ocurr for the first 3 minutes of every cycle , this step was added to dishwashers of late because everyone seems to wrinse the dishes off first ,adding a lot of driping water to bottom , so it's just pumping it out thats why it's so important to use the detgerent dispensers and not just dump it into bottom
Feb 17, 2015 | Bosch 23 in. SHU33A Built-In Dishwasher
The dishwasher keeps running, doesn't finish cycle, doesn't drain. What can I do to fix it. Put a load in and it ran for over 2 hours. I had to manually stop it. (push off button)
uou must replace the module control. some of those control are covered under the recall at bosch or go to thermador .com they are the same company. hope this helps.
Mar 12, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
My bosch dishwasher model shu33a keeps running.At first the sanitized light would not light now it just keeps running and when i open the door its not real hot like before..the washer is only 3 years old.
change the control module. check to see if there is a recall on this module. bosch will tell you if it is.give them model # and serial #. by the way if the modell is arecall you will get a free fix. let me know if this info helps,
Feb 23, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
Wont drain check everything push drain botton still wont drain
i call a repairman in it was the drain pump thank you for your help NOT what a joke this site is have a good day boys
May 18, 2009 | Bosch 23 in. SHU33A Built-In Dishwasher
I have a bosch shu33a dishwasher and its not draining at all. it washes the dishes but the water wont drain out
Remove the lower front panel and you will see the drain hose leaving a tiny pump and heading out of the dishwasher space into the sink space where the drain line is attached to your drain line.
Remove the clamp on the drain line closest to the little pump and then unscrew the pump. you are looking for an obstrution in the form of a piece of broken glass, a bone, or something else which is preventing the pump from pumping the water into the sink drain.
please rate my answer as a fixya!
Feb 25, 2009 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch SHU33a won't drain
Try pouring in enough water to cover the screen in the bottom of the dishwasher, maybe a 2 quarts or so, then run the drain cycle. This should prime the pump and at least tell you wether the drain pump is working or not. Just a trick i've heard and worked for me, not my area of expertise however.
Jan 05, 2009 | Bosch 23 in. SHU33A Built-In Dishwasher
Not cleaning dishes
sounds like you are not getting enough or any water a check the water level when it fills... let me know
Apr 05, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch dishwasher model #shu33A
your dirty water backed up into the washer (which it shouldn't do) and probably clogged something in there,..i would recommend getting it flushed out somehow, not sure how, time, your washer drain hose should go up under the sink as high as possible and then back down to drain,....this settup makes it hard for drain water to go back into washer,'s instructed in any dishwasher manual
Mar 06, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Dishwashers Logo
279 people viewed this question
Top Dishwashers Experts
