Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Akai PDP4294 The Picture is out and on start-up, the red power light flashes 5 times. Is it worth fixing? Thanks
  • 3 more comments
  • BABESOFTWO Apr 11, 2008
    WHEN TELEVISION IS TURNED ON, THE L.E.D. FOR THE TELEVISION"ON INDICATOR" WILL FLASH RED FIVE TIMES AND THEN STAY OFF. THE DISPLAY ON THE MONITOR STAYS BLACK (OFF).THE STEPS I'VE TAKEN TO RECTIFY THE PROBLEM ARE, DISCONNECT ALL INPUTS/OUTPUTS, DISCONNECT INCOMMING POWER AND VERIFIED VOLTAGE- O.K.. TELEVISION DID NOT RETURN TO NORMAL OPERATION. NEED HELP PLEASE!!
  • jrcoxusa Apr 14, 2008
    I have exactly the same problem with my set. When I turn the set on the power button flashes red five times then goes blank; I have sound but no picture or access to the menu.
  • mikeyr May 06, 2008
    same problem as the others. TV was working great, then no picture. turned off then back on, indicater light blinks 5 times. Everybody seems to think it's a fuse or the power supply, but has anybody acutually got theirs repaired
  • jc2rock Aug 01, 2008
    Same problem... No picture and no sound. Power light blinks five times then stays out. Green light internally behind the digital input board keeps flashing. Where can I find a replacement power supply board?
  • courtneyw75 Aug 04, 2008
    Where do you get the capacitors? I have the exact same problem--no picture.
    President:
  • Akai Master
  • 749 Answers
Repair service for power board B4K-50:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110646032176
As stated in the listing there please note that there are unique board components that are not replaceable...so depending on the failure there's always a risk that the board may not be recoverable.
Posted on Feb 07, 2011
    Problem Solver:
  • 17 Answers
I have the same set. Actually 2 of the same model. One fell and the screen is cracked. The other just went dead like everyones. About the fuses, how do I know if they are blown. I saw one and it is white. Is that normal or blown. I'm not familiar with these types of fuses. I've only seen the clear ones with the fuse that you can see clearly inside.
Posted on May 05, 2008
  • 1 more comment
  • Ter Xiong May 05, 2008
    Also I was wondering for all of the people who has opened up their tv, did you guys notice anything with the big capacitors on the power boards? I believe there are 4 of them. The ones in my set looked like they got very hot and look like they are going to pop. The tops are popping up round. They are suppose to be flat. I may order the same capacitors and swap them out to see if it helps. Also since I have 2 of the same sets, I'm going to try to see if swapping the boards around will fix the one that didn't crack. I'll do some voltage and continuity checks on each set to see if they check out the same and maybe I can figure out what we need to change out. Since we all seem to have the same problem, it should help everyone out.
  • Ter Xiong May 06, 2008
    Ok i've swapped power supplies from the cracked tv to the one that went black. It worked for me. After replacing the power supplies, the display came back on. I'll swap out boards and do some testing to see where I can trace the problems.
  • Ter Xiong May 08, 2008
    I've traced the problem down to 2 capacitors. After changing them out on the bad PS with the good PS, the bad PS is now working. Screen came back on. I found that the VS voltage had dropped. It's should be around 90v and was only 68v.
  • 22 Answers
New here.. thanks.. I have the same issue as all of you . So the answer is get a new power supply board huh, or check the fuses..? The fuse is all white, so i cant seem to see if it's blown or not. it seems to be a 8ah250v fuse, the ones on the sides are 4ah250v.i'll go to Fry's and get some fuses, if doesnt fix, i'll replace the board. Please confirm?
Posted on May 03, 2008
    Scholar:
  • 52 Answers
Problem is with the power supply, you are getting power to the logic board and input board, but the main HV for the panal is dead. With the set unplugged, you can check the supply for any blown fuses.
Posted on Apr 21, 2008
Akai pdp 4294 wont turn on
The power supply board needs to be replaced or repair. No other quick fix is available. Thanks
Nov 26, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Almost same symptom
Probably what happend to mine. It's all the same problem. It's actually fixable. I repaired mine.
Jun 04, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai dlp
i have a similar tv, with 5 blinking red lights on the power off. is that a power board issue? (I see the small green light ionside the tv, flashing green.,,) the outer light stays red or flashed red when i power off. i replaced the fuses, still same issue.
Mar 18, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Flashing power button
Depending on the number of flashes,it could be a power supply or y-sus board.Both parts are silly money.The flashing light indicates a fatal startup error.These units make a great boat anchor for a 16ft boat.
Mar 03, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
No picture ; no sound
the red blinking light usually has a pattern that gives you a code to the possible problem.
Maybe you have a bad power supply board. You have to open the panel and do a few tests on the power supply's outputs to be sure.
It produces a variety of voltages for different parts of the tv ie. the plasma display panel and the audio system. The components supplying power to the audio system may have failed a year ago and recently the pdp.
plasma tv's are expensive to repair, most of the time you can get a better tv for the same price. You can reduce that cost by learning and troubleshooting it yourself.
Feb 23, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
AKAI LCT2701td TV No Picture
Your pwer supply module has problem. Check diode (Z3) and 2 surface mount resistors (R65A and R65B).
Good luck
Nov 25, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai Plasma TV's screen suddenly went blank -model PDP4294
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Nov 04, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Testing the BN96-00249A power supply in an Akai PDP4294
You can get the schematics for the bn96 00249a smps here in pdf format. http://www.wimtv.be/techniforum/files/ps42p3sx_ch._d58a.pdf
Jul 23, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai Plasma 42" PDP4294
I had the same problem I was told to unplug then reset but still no luck. Mine have been broken since Aug 2006 and seems like it's so hard to find somebody to fix it. Please let me know if you fix yours.
Jan 21, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Screen went out
I had the same problem, but I had no sound at all. The power indicator light was flashing green. I tried to unplug the unit and plug it back in, but the light then was red briefly, turned orange then flashing green. What I did to solve the problem was to unplug the set and leave it for a few minutes then plug it back in and hit the front power switch at the same time. Voila! It started working again. Good luck solving this.
Aug 18, 2006 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
623 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
