Question about Brother MFC 420CN All-In-One InkJet Printer
Ink cartridge printer tells me the yellow is "nearly empty" and I just replaced it
  • 832 Answers
anyway. always print until machine stopps printing! The job is not lost and will be finished after replacing ink cart.
If you still have trouble although follwed the outlined link, unplug machine from power outlet. take all carts out and plug to power again. after set up machine will demand the carts. set in place and answer display!
Posted on Apr 07, 2008
Brother MF 5440CN USB Printer won't print. Says "Ink Empty Cyn" and then "Ink Empty Yellow" Replace Ink There is ink in the cartridges.
While there may be ink in the cartidges, your printer is getting a signal from the cartidge that it's near empty. There is no real workaround for this; you just have to replace the cartridge(s). If you use a LOT of ink, you might consider installing a CIS (continuous ink system) now made for most printers. You will save a lot of money over time.
What you describe is typical.
Dec 06, 2010 | Brother MFC-5440 Printer
Where do the ink cartriges on a brother mfc 5460cn fo
Your machine is equipped with an ink dot
counter. The ink dot counter automatically
monitors the level of ink in each of the 4
cartridges. When the machine detects an ink
cartridge is running out of ink, the machine
will tell you with a message on the LCD.
The LCD will tell you which ink cartridge is low
or needs replacing. Be sure to follow the LCD
prompts to replace the ink cartridges in the
correct order.
Even though the machine tells you that an ink
cartridge is empty, there will be a small
amount of ink left in the ink cartridge. It is
necessary to keep some ink in the ink
cartridge to prevent air from drying out and
damaging the print head assembly.
a Open the ink cartridge cover.
If one or more ink cartridges are empty,
for example Black, the LCD shows
Ink Empty Black and
Replace Ink.
b Pull the lock release lever down and
take out the ink cartridge for the color
shown on the LCD.
c Open the new ink cartridge bag for the
color shown on the LCD, and then take
out the ink cartridge.
d Remove the protective yellow cap (1).
If the protective yellow caps come off
when you open the bag, the cartridge will
not be damaged.
e Each color has its own correct position.
Insert the ink cartridge in the direction of
the arrow on the label.
f Lift each lock release lever and push it
until it clicks, and then close the ink
cartridge cover.
g If you replaced an ink cartridge, the LCD
may ask you to verify that it was a brand
new one. (For example,
Did You Change Blck?) For each
new cartridge you installed, press 1
(Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge
you installed is not a brand new one, be
sure to press 2 (No).
If you wait until the LCD shows
Near Empty and Ink Empty, the
machine will automatically.
Find this on page 113 of the manual:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 04, 2010 | Brother MFC-5460CN All-In-One InkJet...
Printer keeps telling me that the yellow cart is empty and I have put a new one in
Are you positive it says the yellow cart is empty? Because that brother printer is designed to say that a cartridge is empty whenever ANY of the color cartridges are empty. Usually it doesn't tell you which one is really empty either. So even if you replaced the yellow cartridge and say, the black cartridge is empty, it still won't let you print until you replace that empty black cartridge, nor will you know which of the cartridges is empty unless you pull them out of the printer and manually check the ink levels.
Its pretty much a guessing game with those old brother ink printers.
Hope this helps :)
May 03, 2010 | Brother MFC-5440CN All-In-One InkJet...
My printer says install magenta what does that mean
It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
Changed yellow ink to new cartridge. Printer won't recognize.
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
Jun 04, 2009 | Brother MFC 420CN All-In-One InkJet...
Operating problem as described below
unplug mfc from power outlet. take all carts out and leave scanner open. wait a minute. replug to power. wait until machine demands carts. insert one after another and ANSWER display! Close cover.
NEVER change cart until mfc stopps printing (near empty is a reminder to buy new ones :-))
Jun 18, 2008 | Brother MFC 420CN All-In-One InkJet...
Replaced color ink cartridges
Do a print head alignment. This will tell the printer there's a new cartridge.
Mar 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-in-One Ink Cartridges
near empty message is a reminder: plz buy a new cart (but do NOT change until EMPTY). You still can print.
the ink left in an empty cart keeps the system alive when some ink is neede for the automatic cleaning cycle.
If you print until this cart is really empty air will get into the tubes and ph. That leads to faulty printings.
brother had made sure that the amount of printable ink can be consumed. The rest is for service.
Jan 31, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printer says ink near empty
Black electrical tape works like a charm on a Brother MFC-465CN. Thanks for the tip! :-)
Jan 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
50 people viewed this question
James Cagle
James Cagle
Jim Keysor
