Question about iLO 3200 32 in. LCD Television
  • iLO Master
  • 1,779 Answers
If you have component ( blue-green-red ) on your DVD output then it should work. Other wise, you would use Video out on the DVD to Video 1 or 2 which ever one you would like on the TV.
Posted on Apr 17, 2008
How do i manually program my channels on older tv without a remote
Nothing you can do without the original remote. One cannot get into the setup pages. Replacement remotes usually don't work on this point either. They are missing this special setup button. In order to watch DVD, VCR, connect them with a SCART cable. When you switch on the player, the TV will detect this and go automaticaly to this input. If connected with RCA plugs, you can choose the input with the program Up/Dwn buttons on the TV set itself, going "lower" than channel 1.
Jan 04, 2014 | Philips Magnavox 20MT133S 20" TV
I dont have cable.i was using this tv just to play dvds and i accidentally hit channel search. now i get a blue screen that says" plerase connect cable system or an antenna to the terminal on the back...
Using remote locate a button called tv/video or Input, turn on the DVD player and hit this button until you see your DVD player Logo. Most dvd players use either video 1 or 2, or componet or HDMI outputs. Seems you have changed the TV's input back to TV mode and you need to change it to a video mode input.
May 17, 2011 | Televison & Video
What channel do you use for a DVD player? It won't "see" any channels that doesn't have a program on it.
If your dvd player has 3 plugs red white and yellow plug them into the slots marked av. the colors will correspond with whats on your tv inputs. then turn the tv to the av setting according to the av number you have the plugs in either av1 or av2 you should now see dvd player logo.
Jan 06, 2010 | Emerson CR202EM9 TV
No signal on TV when we go to watch a movie on the DVD player
You may have to select a different input on the tv. iIs there an "input" put on the tv remote? If not, try channel down.
Apr 30, 2009 | Sanyo DS31520 31" TV
When i hook my dvd player up i don't get a picture, when i play the dvd, i get sound. what is wrong? thanks bonnie
If Progressive scan is turn on the player and not on the tv it wont show a picture, or it could be your tv doesn't have progressive can, or check your AV cables, if through componet you have to make sure your tv is on the componet channel and that the colors all match and are inserted fully into the jacks.
Dec 29, 2008 | Philips Magnavox MWD7006 DVD Player
I cannot get my DVR4300 to go in to TV channel change mode while recording a program
Why not simply record a channel tuned into the vcr and use your tv remote to watch a channel tuned into your tv? that is how it is normaly done... don't forget a vcr/pvr/dvd recorder has it's own channels just like a tv does... just no screen of it's own the tv has of course it's own channels and in fact does not even need to be switched on in order for your recorder to record a program neither does the recorder need to be on to use your tv
Oct 14, 2008 | GoVideo DVR4300 DVD Player/VCR
RCA f20580wn 20" TV about 20 years old
Hopefully you have the problem solved.
If not, the RCA plugs, listed as input 1 and 2 are shown on channel 91 and 92.
I recommend connecting the DVD to either input. Turn on the DVD. Then run the auto programming function of the TV. It will find and program the channel for the DVD. Then use the channel up or down on the remote you are currently using and you should find a working DVD.
Hope this helps.
Apr 07, 2008 | Televison & Video
Hooking up a DVD player to a LCD TV
Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
Jul 08, 2017 | LG 42LB5D 42 in. LCD Television
Can't get to "Video 1" to play DVDs
try turning your dvd player on and then doing a channel search if that does not work just buy a RF modulator and hook up your dvd player to it and it will run on channel 3 or 4 and will switch over by itself when you turn on your dvd player
Feb 26, 2008 | Emerson EWF2703 27" TV
Grey Screen
Try the reset on the remote. Press this key twice to restore factory settings. The TV will automatically start Channel Search and clear all customized settings. These features will automatically reset: ? Picture/Sound Adjustments: Color, Tint, Contrast, Brightness, Sharpness, Color Enhancer, Tone, and Surround Sound ? Channel Memory ? Audio to Stereo ? Caption to OFF ? V-Guide to OFF ? Aspect Ratio to 4:3 (normal) ? Menu Language to English ? Sleep Timer (if previously set) ? Video to TV (if previously set) If desired, personal settings can be made again using the menu options
Jun 23, 2007 | Sanyo DS32224 TV
iLO 3200 32 in. LCD Television Logo
27 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
