Question about Tacsew Sewing Machines
Tacsew lu-563 sewing machine
How to slow down the machine
  • 3 Answers
Generally going to have to be addressing the drive motor, either substituting a lower speed clutch motor for the existing one, ie if you have 3000 rpm motor, then going to a 1725 rpm motor. Alternatively, selling the clutch motor and buying a servo motor instead, which should be available with a variable maximum speed control. The Sewquiet 4000 can select different speed ranges with the flick of a switch. If you already have a servo motor and it does not have a variable max speed, then switching the drive pulley on the servo motor to a smaller size should help
A more convoluted solution would be building a support under the table for a layshaft with different pulley sizes so that the motor could drive one pulley and then a smaller pulley on the shaft would drive the sewing machine. Not a bolt on solution but pretty cheap to do if you are good at fabricating.
Posted on Jan 01, 2009
    New Friend:
Riclap
Thanks. Are there variable speed drives for thse motors?
Posted on Jan 26, 2010
SOURCE:
The Bobbin Assembly will turn in reverse but not forward Juki LU-563
Most likely the bobbin retainer has been bent. Turn it over by hand with the power off and look carefully, you will prolly see it.
Dec 18, 2014 | Juki Sewing Machines
Is there a way to slow down the motor on a Tacsew blindhemmer machie
try adjusting the foot pedal, there are jam nuts under the foot pedal
to make it go slower or faster.
Sep 27, 2012 | Tacsew T500
Instructions
try sewusa
Nov 10, 2011 | Sewing Machines
How do you slow down the running speed? Is there a reestat for this machine? The motor is a Tacsew Clutch Motor, Model RM1878-1L, 1/2 hp, Sr. # HMC 04051325
Techsews are industrial sewing machines. Check out http://shop.raphaelsewing.com, especially their web blog. It's full of great information on Techsew machines.
Jan 26, 2010 | Tacsew Sewing Machines
Thread keeps breaking on sewing machine
Probably just the needle. Try turning it 180 degrees
Aug 24, 2009 | Yamata FY700 Mechanical Sewing Machine
I need a manual for a JUKI LU 563
JUST check at google ,com manuals
and then write you model# or you can go directly to your manufactury on line or if you heve costumer service # call them
Aug 15, 2009 | Sewing Machines
Looking for a manual
JUKI HOME SEWING DIVISION 8500 NW 17 th Street Miami, FL 33126 Phone: (305) 594-0059 [email protected] she will send you one
Mar 25, 2008 | Yamata FY700 Mechanical Sewing Machine
www,raichert.com has a free PDF download for the manual for this machine but his pictures are not good. Still, it may be enough to let you figure out what to do.
Mar 25, 2008 | Juki MO-655 Mechanical Sewing Machine
Sewing Machines Logo
391 people viewed this question
Top Tacsew Sewing Machines Experts
Nick Olsen
Ruth summersides
ray gallant
ray gallant
Are you a Tacsew Sewing Machine Expert? Answer questions, earn points and help others
