Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Belkin Router My Belikin Router is not working.When i go through the 6 steps the first step messes up and says that is couldnt find a netwwork adaptor.
    Brigadier General:
  • 6,966 Answers
It is possible that the problem is with your PC's networking card. It may or may not be present; it may or may not have appropriate drivers, it may or may not have been configured properly.
Pls post back what PC you are connecting the Belkin Router to.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 07, 2008
SOURCE:
How to config my belkin n300 to change nat to open in xbox live
Belikin has one DMZ IP option in the web admin.
Go to Portforward dot com for step by step instructions. Also refered to as virtual servers on some routers.
Dec 29, 2012 | Belkin Surf N300 Wireless N Router
I have CenturyLink. I cannot get the Belkin router to work. What to do?
IF THE MODEM GIVEN BY CENTURY LINK is 660 Series then the IP Address of the Modem and Router Will be the same
So before starting the troubleshooting ... Disconnect the centurylink Modem from the Belkin
Step 1 : Connect One of your computer to the belkin ( to any one of the 4 grey ports ) with an ethernet (CAT 5 ) Cable
Step 2 : Open internet explorer
Step 3 : On the address bar type http://192.168.2.1 and press enter
Step 4 : If you are at the belkin Router Setup utility ..
Step 5 : On the Left under LAN Setup click LAN Settings
Step 6 : Leave the Password blank and click submit
Step 7 : Change the IP Address to 192.168.3.1
Step 8 : Click apply changes
Step 9 : Connect the Modem - Router ( to the yellow slot )
Step 10 : Check the color of the light in the Router
Step 11 : If it is solid green .. Check if you have internet
SETTING UP A WIRELESS NETWORK
Even though The router comes with a Pre-Set Wireless network many people wont like to use it
if you like to setup a connection
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Dec 26, 2010 | Belkin Wireless Surf Router (F7D2301)
I have been using the Belkin F5D7633UK4A wireess router for 4 years now. A few weeks ago I attempted to put a password on the router, instead I somehow messed it all up so I was forced to reset the...
WIRELESS SECURITY ISSUES
Dec 06, 2010 | Belkin (F5D7633UK4A) Wireless Router
The Belkin wireless router was working for our home computer and one laptop, but the other laptop was not working. Later we figured out the laptop that was not working had other issues, but after calling...
Oct 24, 2010 | Belkin (F5D7231-4) Wireless Router
How do i reset my wps orange light stays on no internet
Sep 23, 2010 | Belkin (F5D7231-4) Wireless Router
The router Belkin F5D7234 v4 has alredy included WPA2 sistem? Thanks
YES THE BELKIN F5D7234 HAS WPA2
Step 7 : Enable WPA/WPA2
Sep 13, 2010 | Belkin F5D7234-4 Router
How to connect Belkin N N 300 Router to Cox Cable Modem step by step instructions. Cox just installed a new modem since the old one "went bad" and was giving a wrong "number". Was working fine before and...
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
================================================WIRELESS SETTING UP A WIRELESS CONNECTION
Aug 30, 2010 | Belkin Wireless Play Router (F7D4302)
Signal problem
Step 1: Connect Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer (You can use any Web browser )
Step 3:On the left, under wireless click on channel and SSID (leave the password Blank and click submit )
Step 4: Change the Wireless Channel to 6 ( If its already 6 change it to 11)
Step 5: Click apply changes
Step 6: unplug the Router
Step 7: Restart the Computer
Step 8: Plug the power Cable back to the Belkin
Step 9: Connect to your wireless network
Jul 31, 2010 | Belkin N1 Vision Wireless Router
Problem with Mac and Belkin router
I have a Mac Pro and a Belkin F5D 7230-4 Router. The Mac links to the WiFi but will not go on to the internet. The Router works fine with a wired PC and other wireless PCs. I have updated the Belkin with the latest Firmware but it does not help. I have tried powering down the Router and Modem
Gmac
Feb 18, 2009 | Belkin (F5D5231-4) Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
29 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
