Question about Kitchen Ranges
Replace wick in vintage coleman catalytic heater
2 Suggested Answers
SOURCE: When I light my Coleman Catalytic Heater, it burns
The wick isnt drawing up any fuel? Does this heater have a primer?
Could the wick be sitting above the fuel inside the tank?
You might just try changing wicks and restarting.
Posted on Dec 12, 2009
dougpeot
SOURCE: How do you light a Coleman catalytic heater
Users manual from that era - parts also available ....
http://www.oldcolemanparts.com/resources/scans/512_1.htm
Posted on Aug 23, 2015
Answer to Terry Hair - cat. 280 RA77, ser. 38 80A, GE Hotpoint electric range/stove/oven
You weren't kidding when you said Vintage! I was thinking maybe 1950's. What you have is purely antique! I doubt you will easily find anything for something that old. There are a few websites online that cater to antique and vintage appliances. Some have forums where you can request info. You might fare better there.
Nov 07, 2015 | Hotpoint EDISON GENERAL ELECTRIC APPLIANCE...
Oil fired Aga is making wheezing sound
Sounds like air passing where it should not be, try checking that all the components of the burner are seated properly for example the cap on the centre resivour and the other thing is that the wicks are high and causing a taller flame
Mar 31, 2014 | AGA Kitchen Ranges
Could you tell me if an oil fired rayburn will run ok on red diesel, I live in spain and kerosene is not available. thanks peter williams
if it is wick burner it will not work. if it is a single pj a gas oil burner can be fitted that will work. if a twin pj then it will work if you turn up the fuel pressure to 12 bar
Nov 29, 2009 | Kitchen Ranges
Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Sep 23, 2008 | Kitchen Ranges
Vintage electric hotpoint range
I have one of these same model stoves in near perfect condition. I found a website that has a lot of information on these and other vintage appliances as well. The sell parts and even buy appliances too. They will give you an appraisal, but that costs $50. Here is the URL address- http://www.antiqueappliances.com/index.htm
Aug 18, 2008 | Kitchen Ranges
I have an older (20 yrs) coleman cook top camping stove that does not work. It runs on coleman fuel. What are somethings i can try to fix it
Here is Coleman's web support. I also need some work on my stove.
http://www.coleman.com/coleman/manuals/manuals_resp.asp?category_id=1100
Jul 07, 2008 | Kitchen Ranges
I have a sunbeam kerosene heater that was given to me and I was wondering about the right wick t get for it. The only number that I could see that might be a ser # is 48337. Could you be able to help me...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=573599
Generic problem for all Kitchen Ranges
I have a Sunbeam kerosene
Posted by hecklers55 on May 05, 2008
I have a sunbeam kerosene heater that was given to me and I was wondering about the right wick t get for it. The only number that I could see that might be a serial # is 48337.
Could you be able to help me find the proper wick? Thanks
I did research on the wicks that you are looking for and the one that had the most selection for the Sunbeam Heaters was the site I listed below:
So if you need further assistance, please feel free to contact your local appliance dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.outdoordistributors.com/Kerosene_Heater.html
Contact Us
Toll Free Order Number
1-(877) 70-PARTS OR 1-(877) 70-72787
Thanks, Don – The Appliance Man
Go Ahead. Use Us.
May 05, 2008 | Kitchen Ranges
Coleman stove, model 412-5621, will not pressurize the fuel tank. The pump appears to need some replacement part or parts. What should I do?
disassemble the pump by removing the c-shaped ring aroudn the metal cap. a flathead screwdriver will work to pry off the ring.
pull out the pump assembly. The end is probably a old dried out leather ring. It needs oil (car motor oil shoudl be fine) and it needs to make a tight seal.
if it is too loose, it might be possible to press it out to make it wider. If not, it needs to be replaced. The pump assembly is about 8 dollars at many stores.
Apr 29, 2008 | Kitchen Ranges
Kitchen Ranges Logo
504 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
