Question about Kitchen Ranges
Oven Error # F6E0. Says "lost communications". How do i fix?
  • 3 more comments
  • Anonymous May 11, 2008
    Ple
  • djasonde Aug 30, 2008
    I have a Kitchen Aid Range and the touch screen shut off for 3 days. When it came back on it read F6E0 0101 AM16 UI15 EEKE0-254. Any Idea as to what this means?
  • tallhamm Nov 27, 2008
    I had the same problem today. The problem started with no display. We turned off the breaker and about an hour later when turned on. The oven came on with this error code.
  • Anonymous Feb 25, 2009
    I was baking and 1/2 way through the message appeared as described
  • costello267 May 18, 2009
    We are having a problem also with the error code F6e0 coming up on the digital panel. We've had our wallover since Sept2007, almost 2 years, with no issues whatsoever. Over the last month this error code has been coming up. Last week we had a service technician in to replace the digital panel and 10 minutes after he left the error came up again. Occassionally we can push the "off" buttons which removes the error code and then we can use either the microwave or the over (or both if needed). For example, this morning I was able to do bacon in the microwave using the crisp feature for 6 minutes and when I tried for 1 more minute it no longer worked. We have the technician coming back again tomorrow, he will be removing the walloven and checking the wiring (he seems to think its kinked somewhere). My question is, is something similar happening with the rest of you who are having the same problem? And how can this type of problem not show itself for almost 2 years and then all of a sudden be a problem with the wiring (as you all know once this oven is in its place there is no moving it) so why would there be a kink in the wiring?
2 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: lost communications error code F6E0
F6 - E0 Return line not connected If switch pulse return line is not connected, electronic control will display F6 within 60 seconds after power up. Replace control.
Posted on Oct 04, 2010
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Kitchenaid microwave error f6e0
1. Unplug oven or disconnect power.
2. Open the back panels and make sure the P6 and P2 connectors are fully
inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step 6.
- If they are plugged in, go to step 3.
3. Visually inspect all wires between P6 on the appliance manager and P2 on the
lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between
P6-1 of the appliance manager and P2-1 of the user interface board.
Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to
P2-5(UI). All the measurements made should be less than 5 ohm . If any of
these measurements exceeds 5 ohm, go to step 5.
4. Replace the appliance manager. Ensure all connectors are properly inserted.
5. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
6. Replace all parts and panels before operating.
7. Plug in oven or reconnect power.
8. Observe for longer than 1 minute to determine if error has been repaired.
9. If error does not appear, initiate a bake cycle. Let the cycle run for at least
1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step 1.
At step 4, replace the lower oven user interface board if appliance
manager has already been replaced.
- If both are replaced the problem has been repaired.
May 15, 2013 | Cars & Trucks
Shortly after end of 1 year warranty, KEMS378SSS04 began displaying F6E0 Lost Communication on lower over UI (not on the microwave). Turning power off/on (multiple times required sometimes) fixes the...
Below is the complete instruction sheet.
You are having a communication error between the appliance. Here is the actual tech manual instructions for that code:
PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic
mode and verify the error codes. Ensure AM software, UI software and EEPROM
CHECKSUM versions appear on the lower text line. If AM software and EEPROM
versions do not appear, UI and AM may not be communicating. Verify this for the
lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show
the AM software version for the lower oven appliance manager, and the microwave
UI will show the AM software and EEPROM versions for the microwave appliance
manager.
If the lower oven UI is not displaying the AM software version, go to UI IS NOT
DISPLAYING AM SOFTWARE VERSION.
If the upper oven UI is not displaying the AM software and EEPROM versions,
go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND
EEPROM VERSIONS.
If lower oven UI and microwave UI are both displaying an error, go to LOWER
OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
UI IS NOT DISPLAYING AM SOFTWARE VERSION:
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the
P2-5(UI). All the measurements made should be less than 5 ?. If any of
these measurements exceeds 5 ?, go to step E.
D. Replace the appliance manager. Ensure all connectors are properly inserted.
E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
F. Replace all parts and panels before operating.
G. Plug in oven or reconnect power.
H. Observe for longer than 1 minute to determine if error has been repaired.
I. If error does not appear, initiate a bake cycle. Let the cycle run for at least
1 minute.
- If error occurs again, restart the troubleshooting procedure at step A.
At step D, replace the lower oven user interface board if appliance
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 22, 2011 | Ovens
Oven does not work is reads F6E0 error code lost communition what's wrong?
I assume it's a KitchenAid that you have. Here you can find a previous thread about this code:
http://www.fixya.com/support/t1176150-f6e0
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Jan 24, 2011 | Ovens
I have a kitchen add KGSS907 it is showing an error message F6E0 lost communications how do I correct this
F6 E0 means the switch pulse return line to the electronic control is not connected
The usual way to correct this is to replace the electronic control (clock).
You might want to check for loose or burnt out wires on the clock unit before replacing tho'.
Dec 17, 2010 | KitchenAid Architect Series KEBC107KSS...
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Jun 06, 2010 | KitchenAid 27 in. Built-in...
KITCHENAID KGRS807 ERROR MSG F6E0
Problem with the time keeping unit. You will need to reset the unit. Unplug it for 30 minutes then plug it back in. If that does not work then check for bad ground wires that are not fully grounded on the unit. If you find a problem and need to order the part you can order it at repairclinic.com
Feb 22, 2009 | KitchenAid KGRS807SSS Gas Kitchen Range
F6E0
Last night I saw the lights in the house flicker momentarily... This morning, I turned the oven on, set it to Bake and within a few seconds, the control panel reported error code “F6 E0” then shut the oven off. The control panel also reported "Lost communication...". I read on another site that this code may require replacing the control panel itself. Apparently, the momentary power fluctuation wasn't large enough to damage the electronics (since the control panel still works), but was significant enough to confuse the electronics controlling the oven. To fix the oven, I simply turned the 30 AMP breaker for the oven off for about 5 minutes. When I turned it back on, the oven worked just fine. Solution #1 recommends taking off the control panel, which voids the warranty. It's more likely that it was fixed just by cycling power to the oven via the breaker.
Oct 27, 2008 | KitchenAid Architect Series KEBC107KSS...
Kitchen Ranges Logo
558 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
