Question about Cuisinart DLC-8S Pro Custom Food Processor
Broken plastic piece
The plastic covering of the stick that turns the bowl and blade, broke!
Where do I find a replacement, if at all possible?
  • grey_lensman Aug 15, 2008
    got the part from smallappliance.com. now I can't figure out how to replace it. dlc8s cuisinart. I don't understand how to get the broken one off
If it is the motor shaft cover, amazon or smallappliance.com
Posted on Apr 26, 2008
The lid of my EP91 quad blade is broken
Hi Rosa
Depending on the severity of the broken lid....
I fix a lot of plastic items with either super glue or 2 part epoxy resin.
Then for reinforcement at the edges. I take a 2cm (aprox) piece of thin wire. Like a staple. Then heat it with the soldering iron. sliding back and forth until the wire is embedded into the plastic. even slightly covered over.
This often makes a cracked piece of plastic quite strong.
It may not look great but it might hold you over till you find a replacement
Good Luck
Here are some ideas....
Repairing plastic parts
How to Fix Broken or Cracked Plastic or Weld Plastic
Mar 16, 2016 | Euro-Pro EP91 Quad-Blade Food Processor
My food processor is ancient and works like a new one. but broke a piece (small nick) from the bowl. All blades work fine but cheese grater. The only thing I can provide for id number is CFP 9A. This is on...
You should probably not use the thing anymore. The type of plastic they used back then gets very brittle over time, and there's a chance that the bowl could shatter while you're using the processor. There's a chance that if that happens the safety switch will stay engaged and the unprotected blades will keep spinning, right where your hand is. It happened to me.
Sep 17, 2009 | Cuisinart DLC-5 Food Processor
My braun 3210 food processor will not work with the large bowl and sharp blade. Will work with the blender/chopper but large bowl the on/off switch cannot be moved. All of the contacts seem lined up - very...
I had a similar problem. Part of the lid had a small piece of plastic chipped away. It was the part of the lid that rotates and locks into the machine base. If the lid is missing a small piece of plastic on where it connects to the base, the machine will not switch on. You can compare the lid for the food processor to the mixing lid and see if the piece that juts into the base is broken at all. If it is order a new lid. There are several online places that still carry them; or try a local parts store.
Aug 20, 2009 | Braun Food Processors
Need to find a replacement blade for B&D
call 1-866-925-PART
the two parts you will need are
175728-00 disc stem assembly
175726-00 blade assembly
2.95 for the disc
9.95 for the blade
Aug 05, 2009 | Black & Decker FP1300 Quick N Easy Food...
Doesn't start
Buy parts by phone at
1-800-366-PART (1-800-366-7278)
Mar 14, 2009 | Kenmore KFP-70 Food Processor
Need a replacement part for food processor
Try this site for the parts. If I have model # I might be able to help more.
http://www.householdappliance.com/food_processor_parts.html
Good Luck and Please Rate FixYa!
Dec 29, 2008 | Food Processors
Motor switch not activating on a dfp-14ts
Is the cover assembly engaged and locked into place? If you can't lock the cover into place, it's possible that part of the plastic on the cover assembly is broken and not engaging the white rod inside the bowl. Determine which part is at fault (either the bowl or the cover assembly) and replace it.
Dec 19, 2008 | Cuisinart DFP-14BC Custom Food Processor
Cuisinart DLC-8S Pro Custom Food Processor Logo
281 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
