Question about Video Game Consoles & Games
Don't know what an ipaddress is - Video Game Consoles & Games
    Scholar:
  • 119 Answers
An IP address is an Internet Protocol address. Essentially it's like your mailing address, but for the Internet. It's a unique address that identifies a specific Internet connection (not necessarily a particular machine, however).
For online gaming, your IP address is how the online part of the game can talk to your individual game console.
Having an IP address requires having an Internet connection. Normally if you have a broadband connection, your IP address is assigned to your cable or DSL modem, which may then assign a private internal IP address to its clients (your PC, your game console, etc).
Depending on your game console and how it communicates with the Internet.
http://en.wikipedia.org/wiki/IP_address
Some additional information would be good...
  • What kind of connection to the Internet do you have?
    Cable, DSL, something else?
  • What game console do you have?
  • How does your PC connect to the Internet? Is there a box it is connected to, or does it use wireless?
Posted on Apr 07, 2008
I need to know my ip adress and all that stuff?? help please
Inorder to find the ipaddress of your computer follow these steps,
1. Click on start? Go to All programs? Accessories?Command Prompt
2. You will find a black screen which is the Command prompt
3. In the command prompt you will find a blinking cursor , there you type in "ipconfig/all" (without cotes)and hit enter.
4. You will find ipaddress, subnet mask, default gateway , mac address/physical address and all other information of your comp.
Thanks in Advance!
With Regards,
Prema
Dec 31, 2010 | Computers & Internet
Tip
How to check ipaddress of your windows computer?
1Click on Start in the bottom left hand corner of your screen-->Click on Run-->Type "cmd" or "Command" in the Run box-->Click on OK or press the Enter key on your keyboard-->Type "ipconfig/all"-->your ipaddress, default gateway and etc will be displayed..
on Jun 11, 2010 | Computers & Internet
How do i find my modems ip adress
In order to find out the modem ip address
1)Connect your modem directly to the computer using an ethernet cable
2)If you are using windows XP >Go->Start>Run>type CMD>click ok>You will get Command prompt/(black window) type inside the command prompt>ipconfig and hit enter-/under Ethenet adapter local area connections, you will find your ipaddress,ipv4address and the default gateway will be your modem ipaddress
3)If you are using windows Vista >Go to start>type under start search>CMD> cmd.exe will be listed on the top>right click the cmd icon using your mouse>select run as administration>you will get the command prompt>type inside the command prompt>ipconfig and hit enter-/under Ethenet adapter local area connections, you will find your ipaddress,ipv4address and the default gateway will be your modem ipaddress
If you look at the bottom of the modem you will find the ipaddress of the modem
Nov 02, 2010 | Computers & Internet
I cannot connect to the internet with the wireless connect, it is showing that the wireless is connected and the signal is excellent, but when I try to get on the internet I get a message saying the page...
I got your issue , If you need to check the ipaddress on the wired computer which is online. You need to check the ipaddress on the wired
So please follow these steps.
1. Click on start--> go to RUN --> in Run you type in "cmd" and click ok
(If you do not find RUN in the start search box type RUN and hit enter)
2.You will get a black screen(command prompt) , there type in "ipconfig" and hit enter
3.Please make a note of the ipaddress (or it says ip V4 ipaddress) , it will be like 192.168.2.2 /192.168.0.2 /192.168.1.5
Now move to your wireless computer
1. Click on start --> go to control panel
2. Go to network and sharing center (or network and internet connection in xp , then network connection)
3. In the left side click on manage network connection in vista
change adapter settings in win 7
4. If you find the wireless network connection, right click on it and go to properties
5. select Internet protocl TCP/IP(ver:4 in vista & Win 7) and click on properties
6. change it to use the following IP address
7. Then type ipaddress :192.168.2.50 (provided IPaddress in the wired comp is 192.168.2.x, if its diff change it accordingly)
subnetmask :255.255.255.0
Default gateway :192.168.2.1
8. Change to Use the following DNS server address
Preferred DNS :4.2.2.1 & alternate :4.2.2.2
Im sure this will work
Thanks & Regards,
Prema
Oct 11, 2010 | Computers & Internet
Using linksys wet11 to connect to internet through linksys wireless router, working before, suddenly, not working, trying to setup again using static IP, not working, using DHCP, not working, run...
it's because you need to change the ipaddress in you linksys
make sure the ipaddress from you modem it's not 192.168.1.1
if you have the same ipaddress on the modem try changin the ipaddress on the linksys to 192.168.1.1
Oct 15, 2009 | Linksys 802.11b Wireless Ethernet Bridge:...
Cannot connect to internet
First check ipaddress Click Start -run- type cmd hit enter for XP or Start -search-type cmd hit enter in Vista. On the DOS black screen after the blinking cursor type ipconfig hit enter check the ipaddress if are getting ipaddress other than (169........) it is proper ipaddress for e.g 147.14.48.478
Ping the default gateway e.g ping 147.11.445.478 if you are able to get packets send 4 received 4 loss zero is with Internet explorer or operating system.
If unable to ping or getting 169..... ipaddress . you are having static ip address
On the black screen at the blinking cursor type ipconfig /release hit enter
then type ipconfig /renew hit enter .check ip address
Ping default gateway then ping www.google.com if you are able to get packets send 4 received 4 loss 0. Try connect to internet using internet explorer or other browser. if still unable to connect then issue with firewall or antivirus or IE corruption .
Create new administrative account in XP and do MSconfig .Restart the system and logon to new account and try connecting to internet.
If issue persist might have to repair IE or operating system as it is software issue or virus issue.
You can connect a different computer if you have one and check internet.
If unable to get any ipaddress or still getting static ip address ,reset modem or check ethernet cable ,do a hard reset on the internet modem.Shutdown and restart computer and check ipaddress then try connecting to internet. Good luck.
Aug 27, 2009 | Fujitsu AMILO Pro V1000 Notebook
I have the HERMO packard bell model. I can hardly access internet and the sound is not heard. Please hhelp
For internet
Resolution:
NO sound : Check the sound driver .Try reinstalling sound drivers
Aug 24, 2009 | Computers & Internet
Can't connect to the internet after running Rescue and Recovery
It seems you have a static ip address. Check the ipaddress by clicking - start -run - type cmd hit enter. on the black screen - type ipconfig and enter. If the ipaddress shows ipaddress e.g 169.10.14.12 . its is static ipadress. Do ipconfig /release then ipconfig /renew.If u are getting new ipaddress. Ping www.google.com and check if you are able to ping. You should be able to connect to internet. If not then reset the Internet router if you have one or shut down the computer.Disconnect internet cable .If u have modem,turn it off.Wait for 10 second. Connect internet cable.Restart the system and check. If issue persist contact ISP. Good luck.
Aug 19, 2009 | Lenovo Thinkpad T60 Notebook
Cannot scan items to an ipaddress
There could be a number of things causing this, including port blocking at your server level - check with your IT professional.
It would help to know how you're trying to scan (i.e. scan to e-mail, scan to FTP, scan to desktop), if the C351 has an EFI (Fiery) print server incorporated and how it's set up for scan interfacing with the copier. There's so many variables, it would be very difficult to pinpoint any one solution without knowing just how the copier and your network are set up.
Aug 07, 2009 | Konica Minolta bizhub C351 All-In-One...
Ps3 keeps on saying ip timed out
your ip settings are most likely wrong, check your desktop pc settings
here is how
start -> run -> cmd -> ipconfig
note, ipaddress, subnet, gateway
if your desktops ip is similiar to 192.168.1. 2 to 254
then set your ps3's ip as 192.168.1.25 for example
just a number between 2 and 254 (the 1 is used by router) witch isnt used.
your address might show 10.0.1.20 for example or a more complex ip like 86.32.55.100 if this is the case set the ps3 on automatically get ipaddress and dns server.
if you need any help let me know. Good luck.
Apr 02, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
