Question about Dell 922 All-In-One InkJet Printer
Cartridge stall message
Were you able to resolve the error? Learn anything? We changed carts and immediately got the error message but cannot see anything blocking.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 07, 2008
How can I fix no cartridge error on brother mfc-465cn
It sounds like it may actually be the "print head" which is what the carts fit into. These can and will go bad. Sometimes you can find replacements on ebay etc. But you need to make sure it is exactly the same part number. There could also be a number of other issues, the cart contacts could be dirty or damaged (another print head issue resolved by replacing), counterfeit cartridge, bad cart. These are the most common, but not the ONLY issues that can cause your problems. I'd check prices for replacement print head vs. new printer.
Jul 18, 2014 | Brother MFC-465CN InkJet Printer
Hp cp2025 remove shipping lock
I had same problem with black and blue cartridges. I did all recommendations -- return to factory setting ( no help). Shake cartridges REALLY hard ( no help); reinstall printer/ driver ( no help). What finally WORKED was SWAPPING the cartridges around ( for ex. put red in black spot, blue in yellow). I then got an error message ( b/c in wrong spot). Then I placed them back in correct spots and it WORKED !!! NO more error message that the ship lock was on !!! And this worked with generic cartirdges.
Nov 19, 2011 | HP Laserjet Cp2025n Printer
Cartridge error 1203
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Hope it will work for you take care all the best Pineworks
Mar 13, 2010 | Lexmark X7170 All-In-One InkJet Printer
I have a lexmark printer and it is showint an error message saying error#1203 cardtrige error... how do i resolve this?
Worth a try
or
Nov 14, 2009 | Lexmark X5470 All-In-One InkJet Printer
Changed HP74 Black cart, printer not hooked to anything wireless or usb. Used Inksell carts and official HP carts. Used small cart and XL cart. All cause an error after alignment, and all print fine if...
What is the exact model of your printer?
This could be an issue with how the printer detects the cartridge replacement. Have you tried doing a factory reset of the printer settings?
Looking forward to your response.
Aug 08, 2009 | Computers & Internet
Error message 83 - photodev cart exhausted
The photoev cart is the photo developer cartridge.
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
83 Photodev Cart Exhausted
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Dec 08, 2008 | Lexmark C510 Laser Printer
Lexmark c510 error message ;83 photodeve cart missing
See User Reference
pages 184 and 185
"Message:
What you can do:
Continuing below
Message:
What you can do:
Continuing below
Message:
installed.
What you can do:
Nov 26, 2008 | Lexmark C510 Laser Printer
Lexmark x6100
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.If this does not resolve the issue then try the next steps.
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Good luck and dont forget to rate me!!!
Dec 19, 2007 | Lexmark X6100 Flatbed Scanner
Ink cartridge (not) installed properly
unplug machine from power outlet. take all carts out. wait 5 min. plug machine to power. wait until machine demands carts. reinsert carts and make sure they are secured. answer display when asked if you have changed.
If you still have the error message use a original brother cart.
Dec 16, 2007 | Brother MFC 210C All-In-One InkJet Printer
Inputting new ink cartridges
Error 1102 means cart error. Try cleaning the copper contacts on the cart and the contacts in the printer also. If still fails, then put old carts and check if u still get same error. If u dont get the error then there is a problem with the cart itself. But if you have bought a refilled cart then the print heads on the carts are bad. Needs replacement.
Sep 19, 2007 | Lexmark P4350 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
282 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
