Question about Sony Playstation 3 (PS3) Console
Video but no audio
Got ps3 going directly into tv, video but no audio,
any help would be appreciated.
thanks bob
[email protected]
    Problem Solver:
  • 37 Answers
PS3 is The amazing device by sony but it has some common problems like video but no audio problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Posted on Feb 27, 2009
SOURCE:
How can i get my ps3 to use the av cable instead of the HDMI cord
Hello there,
There is no way to connect an AV cable directly to a PS3; however, you can purchase a special cable that convert the HDMI to AV. Here is one such cable. http://www.amazon.com/Universal-S-Video-Audio-Cable-GameCube/dp/accessories/B000IAPGII
I hope this has helped! Thumbs up are much appreciated.
May 06, 2011 | Video Game Consoles & Games
I have a 32 "
Check how you have the satellite cabled. I suspect that you have the video from the satellite to the TV but the audio cable going directly to the stereo. You probably have the DVD audio and video going directly to the TV. (I'm assuming you have the 32LA30rq and not the 32LA30rqd which has a built-in DVD and thus has the audio connection inside the TV.)
Since you don't mention which connection you are using for the DVD player and for the satellite, I will just mention the basics. If your DVD player is connected to one of the HDMI ports, that cable carries audio and video between the TV and the DVD player.
Devices that use component video cables use two separate cables. One cable with two sets of three RCA plugs carry the video; a second cable carries audio with 2 RCA plugs on each end. When you connect these, you do not have to connect the audio to the TV. (Similarly, a composite video connection can be modified for one line with the video signal going to the TV and the audio cable going to a speaker system.)
If my solution is correct, you may want to rearrange things. You can connect the satellite audio out to the TV audio in at the same location as you have the satellite video in. Then connect the TV's audio out (to the right of the component 2 in and above the coax audio out) to the stereo. Then switch the TV speakers off to use the stereo - Menu > Sound > Other Settings > Speaker On/Off. Then both devices will play either at the TV speakers or the stereo depending on the state of the TV speaker setting.
The manual is available here: http://tv.rca.com/product/manualdown.asp?modelnum=32LA30RQ .
I hope this helps.
Jan 20, 2011 | RCA Televison & Video
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Dec 27, 2009 | Bose Lifestyle 48 Series IV DVD Home...
Audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Jun 14, 2009 | Bose Lifestyle 48 Series III System
Separate video and sound on hdmi
yes it would be possible to separate audio and video from your PS3. You would need to go to the PS3 setting for audio and choose Optical instead of HDMI. You would need to connect and Optical cable from the PS3 to the receiver. Then on the receiver you would need to set the digital inut for your source(PS3) to optical.
Mar 10, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
I've had my 80G PS3 for less than 1 month and I am having a major problem. Everything was working fine. I occassionally turned it off directly from the back. 99% of the time I shut it down correctly. I...
Hold your ps3 power button. It will scroll to different video settings. I believe there are 3 different video settings. I believe each beep is a different video setting
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Ps3 to marantz receiver to sony brava lcd tv
Loop the ps3 through the tv and out to the receiver. You only need audio going to the receiver.
Aug 14, 2008 | Sony Playstation 3 (PS3) Console
Full HD picture NO SOUND from ps3 to lg42hd using HDMI
Maybe your TV is not made for HD from the Sony Console. Try calling Sony Customer support, then your TV's brand Customer support. That will tell you if your TV Model allows the HD from the PS3. Remember though, PS3 Uses Blu-Ray. So you need Blu-Ray for your TV. Hope this helped.
Jul 11, 2008 | Sony Playstation 3 (PS3) Console
Interference audio and on-screen
Try an HDTV. If you only have a standard TV, try a different one. I had the same problem and then bought a 1080p 16:9 aspect ratio HDTV and everything cleared up completely (sound and video). Update the ps3 to version 2.2 as well (just came out last night). Good luck!!
Mar 25, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
65 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
