HITACHI HARD DRIVE LOCKED
HELLO
I CANNOT GET MY TOSHIBA SATELLITE NOTEBOOK TO BOOT UP. IT HAS A HITACHI HARD DRIVE MODEL NUMBER HTS541616J9S-S1
THANKS
  • 3 more comments
  • Anonymous Jan 06, 2009
    HELLO
    I CANNOT GET MY TOSHIBA SATELLITE NOTEBOOK TO BOOT UP. IT HAS A HITACHI HARD DRIVE MODEL NUMBER HTS541612J9SA00, HARD DISK LOCK WHEN I TURN ON MY LAPTOP. PLEASE SEND SOLUTION ON THIS MAIL ADDRESS, [email protected]
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    OK. Toshiba took off the bios password...right? So you get in and see all your settings? If the password is stored on the hard drive it's in the firmware and will be tough. But...if it's only in the bios ( actually cmos ) we might lucky, not sure. Would you be willing to go into your bios and write down ALL your settings, and then take out the cmos battery if I told you how to do it? Have to take off the bottom to get at it. ( just several screws ). You'd have to leave it out for 24 hours. This would clear all the settings and hopefully clear the password. Let me know please. Thanks. I apologize for the time it's taking.
  • Jeffrey Pemberton
    If you can get into the bios, some laptops have the hard drive lock/unlock feature in the bios. Did you try this? If it's password protected in the bios, did Toshiba happen to tell you what the bios password was? It may be the same one you're looking for. I'll check your reply and I have one more thing to check for you and I'll get right back to you. I know you're in a hurry.
  • Jeffrey Pemberton
    Does it ask for a password? I stll need the answers to the other questions please. Thanks.
  • Jeffrey Pemberton
    How far does it get? What is on the screen when it stops or reboots? What's your operating system please?
Hello Oldnovii
Yes the BIOS has a hardsrive lock/unlock feature but thats wherethe password needs to be reset. No TOSHIBA did not tell me what the BIOS password was Client had to pay $ 25 to get it removed now they want $ 100 to remove the hard drive lock.
Posted on Apr 13, 2008
Hello Oldnovii
Yes it still does ask for a password. The hard drive is locked and cannot be accessed even with a boot ce or locking out the hard drive in the boot sequence in the BIOS setup
Posted on Apr 10, 2008
Hello Oldnovii
This Toshiba notebook has both a BIOS and hard drive lock on it. The client has already paid $ 25 to the Toshiba depot to have the BIOS lock removed now they want $ 100 to remove the hard drive lock. The hard drive lock cannot be removed by trying to bypass it using a boot cd or disabling the hard drive boot option in the BIOS. Any help will be appreciated since my client has now had the notebook for 2 weeks and cannot use it. Thanks
Posted on Apr 09, 2008
SOURCE:
My Toshiba satellite with a mk2555gsx won't boot up no messages, tried recovery discs to no avail.
SMART FAILURE PREDICTED on HARD DISK 2: TOSHIBA MK2565GSX-(S1)
Warning: Immediately back-up your data and replace your hard disk drive.
Press F1 to continue.
What is that problem?? and how to troubleshoot this my computer, the model is neo M1110 noteboke.
Sep 10, 2013 | Toshiba MK2555GSX 250GB SATA/300 5400RPM...
Toshiba Satellite A200-28s battery options besides stock Fujitsu
Any SATA drive will fit up to the size limitations of your motherboard. A 1Gb is about the norm now. WD, Samsung, Hitachi etc all about the same.
A 7200 speed will give you a slightly faster seek and write time or go for an SSD drive. All are compatible if SATA 2.5" format.
Oct 03, 2017 | Computers & Internet
I have a Toshiba Satellite A205. When I turn it on only the power light, number lock, scroll lock, and caps lock come on. After this nothing happens. I tried to remove the battery to see if it boots. It...
A series boot problems
Aseries laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre. www.Toshiba.com will help you out.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Mar 04, 2011 | Toshiba Satellite A205-S5804 Notebook
Toshiba Satellite A215-S7422 won't boot-up stuck with boot screen the bios is ver.1.00 need help how to make it boot up again,
My Toshiba A215 starts up but won't boot from any source_CD,external floppy, hard drive,etc.. I swap memory,CPU,hard drive ,nothing works,have any one got any solution?//
THANX
Sep 17, 2010 | Toshiba Satellite A215-S7422 Notebook
Hello. i have the toshiba satellite a200-28n and would like to replace the harddisks at 5400 to 7200 rpm.the types of disk are two mk2046gsx 200 gb each one.what harddisk can i choose for...
The maximum size hard disk you can install in your Toshiba depends upon the BIOS. The BIOS can support a hard disk up to a certain capacity. Check the specification of your model Toshiba to see the maximum hard drive it can support.
An alternative -
You can use an external USB hard drive and connect it to your Toshiba and not be restricted by the BIOS. You can use USB hard drive 500 Mb to more than 1 Tb.
The other advantage of using an external USB hard drive is you do not need to install Windows, the device drivers and your programs on the new hard drive.
Jun 11, 2010 | Toshiba Satellite A135-S2386 Notebook...
Hi!im using a toshiba a210 laptop.i put it on some fews days ago it says "smart failure on hard disk 4-hitachi-(s1). warning:immediately back-up your data and replace your hard disk drive.a failure may...
Your drive is failing and you should back up any important data you need onto CD/DVD or an external USB device (hard drive/pen drive). The drive may keep working for a while but your system is warning you that it has detected a critical error with the drive and failure is imminent.
Jun 10, 2010 | Toshiba Satellite A215-S5822 Laptop
My Toshiba Satellite a215 s7422 wouldn't boot
i don't believe you would get that far if it was the motherboard.
Apr 27, 2010 | Toshiba Satellite A215-S7422 Notebook
I need to replace my hard disk notebook with a bigger capacity hdd
Toshiba is rather secretive with their documentation. It is hard to find. Google TOSHIBA SATELLITE A10 SERVICE MANUAL and check the available offerings.
You now have a 5400 RPM, ATA 100 drive. You should not have any drive size restrictions. Shops are advertising many large drives as compatible.
I suggest that you purchase only a 7200 RPM drive. The faster speed will perk your machine right up.
I have not worked on Toshiba machines but suggest you have all restore disks and passwords at hand.
Feb 18, 2008 | Toshiba Satellite A10 Notebook
Open Questions:
WEBROOT tech SuPport PhoNe $+18OO$-8O31O69- NuMbEr installation This WEBROOT USA phone number is ranked #2 out of 2 because 7,728 WEBROOT USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the WEBROOT USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, WEBROOT USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. WEBROOT USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact WEBROOT USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling WEBROOT USA Calling WEBROOT USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from WEBROOT USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with WEBROOT USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare WEBROOT USA's phone numbers against each other. Contacting WEBROOT USA in General While I8OO8O31O69 is WEBROOT USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach WEBROOT USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact WEBROOT USA.
Oct 17, 2019 | Webroot Computers & Internet
Computers & Internet Logo
3,424 people viewed this question
Ekse
Alun Cox
