Noise in machine and water pump is not pumping water out of machine. I think we need a new pump, but the part is hard to find. It is old the model # is aw20n2v series is 17138912sy want to also buy belt for same.
  • 5,911 Answers
If this is an Admiral washing machine, I found a complete parts listing for your washer at repairclinic.com. The drain pump you mentioned is listed as item #1000731 and costs $47.30. The drive belt is item #1318 and lists at $17.30. Just go to the website and type in your COMPLETE model number in the Search menu. Hope this helps you.
Posted on Apr 08, 2008
Loud drilling noise when coffee switch is turned on - rather than the usual purring noise - and no coffee delivery either
How old is your machine ? and what maintenance have you done over time such as replacing the shower curtain located at the pourring end of the hot water ? I had too very loud noise coming occasionnally from the stainless steel rack holding the cup while coffee is delivered. If your ground coffee is too fine it will stop flow during making a shot. Is water coming out when no coffee is placed in the portafilter.The water pump on this machine is a cheap pump that has to be replaced over time. Mine is 7 years old and has delivered four cups of expresso everyday of the year, and still working.3841c994-fb4b-459f-8d1f-710e0aafc3c0.jpg 2ead4f70-37c6-4236-a9c2-992dba149c4c.jpg
May 29, 2014 | Rancilio Silvia Espresso Machine
Water Ran out from under machine
Is the pump making loud noises.
If so the pump seal has perished,
Replace your pump.
Aug 14, 2012 | Fisher and Paykel Washing Machines
How can I best access the pump on my Samsung front load washer? I don't know how to remove the front panel
Some samsung washers have the water pump located in the back of the machine. If your model does not have a small door located in the bottom of front than remove back service panel to access the water pump.
Jun 21, 2017 | Samsung WF328AAW Front Load Washer
I had a new pump put in as my old one was making a noise and wouldnt shut off, but the water was ok , with the new one i get a bit of water or none at all, should i put back my old pump
hi..
did you checked that the new pump is properly set. I mean, all plumbing connections to the pump is to be free from leaks, unnecessary bends. i think your problem is caused either by a faulty valve like foot-valves or insufficient power supply.
there is no point in putting back the old pump. You bought new one because the old one does not worked well.
Mar 19, 2011 | Computers & Internet
I have a Kenmore HE washing machine, model number 11047512601. A rubber part in the impeller for the pump is broken, and the pump makes a grinding noise when trying to drain. I took the impeller out and...
YOU CAN NOT BUY IMPELLER FOR PUMP YOU HAVE TO BUY A NEW ONE, JUST TAKE THE OLD PUMP TO AN APPLIANCE PARTS STORE AND THEY CAN MATCH IT UP ON ON SEARS ONLINE
Nov 08, 2010 | Washing Machines
Water pump failed difficult to turn tub
I THINK YOU MAY NEED TO BUY A NEW PUMP FOR YOUR WASHER. OR IF YOU CAN FIND A OLD WASHER THAT IS THE EXACT SAME MODEL AS YOURS, MAYBE YOU CAN TAKE THE PUMP OFF OF IT AND TRY IT ON YOUR WASHER. IF THAT FAILS, THEN BUY A NEW PUMP.
RODNEY
May 15, 2009 | Maytag PAV2300 Top Load Washer
Load grinding noise, like the engine is working too hard.
Most likely the motor/pump assembly is worn out and grinding. If the machine is less than five years old it is under warranty. If over five years old, the repair part alone is about $150 not including labor.
Apr 17, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
KUD101FKSS Kichen aid dishwasher does not work.
There are three tabs that are holding the whole assembly, accessible from the bottom...they need to come out. Only then you can remove or even move the assembly...
Apr 07, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Washing Machines Logo
119 people viewed this question
Top Washing Machines Experts
