Question about Dryers
Replacing belt on dryer
I need to replace the belt on my dryer, but I cant figure out how to open the top up. It is a Maytag Neptune MDE3000AYW. HELP!! :)
  • Anonymous Jun 06, 2008
    How to repalce a Dryer belt to frigidaire fdeb34rgs1
    Novelist:
  • 184 Answers
FIRST, OPEN THE DOOR AND REMOVE TWO PHILLIPS HEAD SCREWS ON EACH SIDE OF THE OPENING. TWO GO THROUGH THE HINGES, AND TWO ON THE OPPOSITE SIDE OF THE OPENING. THEN, PULL THE OUTER PANEL FORWARD FROM THE SIDES NEAR THE TOP. IT IS HINGED AT THE BOTTOM. LIFT IT OFF THE HINGE WHEN YOU HAVE THE TOP EDGE PULLED FORWARD. YOU WILL HAVE ABOUT SIX OR EIGHT 5/16 HEX HEAD SCREWS TO REMOVE
AND THE FRONT BULKHEAD WILL THEN COME FORWARD TO REMOVE. AT THIS POINT, THE FRONT OF THE DRUM IS EXPOSED AND YOU CAN SLIP THE NEW BELT ON FROM THE FRONT. PAY CLOSE ATTENTION TO THE DIAGRAM ON THE BAG FOR PROPER ALIGNMENT AROUND THE IDLER AND MOTOR PULLEYS. IT WILL BE EASIER TO INSTALL THE BELT IF YOU LAY IT IN THE GROOVE NEAR THE REAR OF THE DRUM, BUT THAT IS NOT IT'S FINAL RESTING PLACE.
AFTER YOU HAVE THE BELT AROUND THE PULLEYS, REPLACE THE FRONT BULKHEAD WITH FOUR SCREWS, ONE FOR EACH CORNER. MAKE SURE YOU DON'T FOLD OVER THE FELT SEAL AROUND THE FAN HOUSING. SLIDE THE LINT DUCT PORT INSIDE THE FELT SEAL. ONCE THE BULKHEAD IS IN PLACE, PULL THE BELT OUT OF THE GROOVE AND SLIDE IT TOWARD YOU UNTIL IT LAYS ON TOP OF THE MARKS THAT THE OLD BELT LEFT BEHIND.
ROTATE THE DRUM MANUALLY COUNTER CLOCKWISE TO BE SURE THE BELT IS ALIGNED AROUND THE DRUM.
IF IT IS NOT, THE BELT WON'T STAY ON THE PULLEYS.
AFTER YOU ARE SURE IT IS O.K., REASSEMBLE THE REST OF THE DRYER IN REVERSE ORDER.
Posted on Apr 08, 2008
I tried all of that but the belt feels very loose. Is the belt supposed to be tight?
Posted on May 24, 2008
Maytag neptune dryer model mde3000ayw wont start
If it only runs with start button held in then you have a problem with the door switch. Check to be sure the wires are on it. Here is the switch to order in case it is bad.
Nov 29, 2012 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Neptune MDE3000AYW serial no. 12307603UU. The dryer will not turn on. I can hear the timer clicking but when you push the start button it will not start. The door is closed. I have...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 04, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE3000AYW. The start button on my dryer went out. It tried to start and then died and smelled burnt. I am guessing the switch burned up. Any thoughts on how to fix it? Thanks
sounds like motor is in a bind see if you can rotate drum by hand if you cant then your belt is hung up,or a belt pully is bad,if drum turns freely,sound like motor is going bad
Jan 23, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have the MDE3000AYW gas dryer and the roller
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 22, 2010 | Maytag MDE9316 Dryer
- very loud squeaking sound
Hello JewettKann,
Typically, on the Maytag Neptune dryers, it is the felt gasket that is the cause and source of the noise you're hearing.
There is a felt gasket that runs all around the front and rear of the dryer drum and cabinet door edge (on the backside lip). As the dryer ages, this felt wears out and needs to be replaced to prevent the awful screeching sounds you'll experience, once the metal to metal contact becomes constant.
You can view the parts that need replacing at the following link (Item #17B on the drawing) Called a sound damper pad on some models.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MDE4000AZW&productCategoryId=0151200&brandId=3048&brandDescription=MAYTAG&modelName=MAYTAG-LAUNDRY&diagramPageId=00004&componentDescription=DOOR&documentId=M0402169&blt=06
This was a fairly common problem with the Neptune line. You can see for yourself by simply turning the drum with your hand and feeling and listening for the rubbing/grinding noise, along the top of the door opening.
If you can get the complete model number off your dryer, you can select the exact line drawing and parts list at the link below to make sure you're looking at your exact model.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=mde4000&=part+number
I hope you find this Very Helpful and best regards!
Dec 25, 2009 | Maytag Neptune MDE4000 Electric Dryer
Metal on metal sound when the dryer is running
I have the same problem and I'm sure its the belt tensioner pulley
Jun 06, 2009 | Maytag Dryers
Maytag neptune dryer making load noise seems unbalanced
Sounds more like the dryer drum seal is deteriorating.
If the dryer tumbles the belt is intact.
To access the belt.
Open the door.
Remove 4 screws on right and left side of the door opening.
Raise the door on the hinge side and remove it.
Pull the front panel forward and remove it.
From there you can see what to do next.
Mar 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Belt is broken on my Magtag Neptune Dryer #MDE3000AYW. How do I take the front panel off to get to the belt?
Hello del4221,
Here is a link to your dryers assembly drawings and parts lists. http://www.pcappliancerepair.com/model-display.php
You should be able to see how it is assembled and be able to disassemble it with this documentation.
Hope this helps..
Regards
Rick
Jan 07, 2009 | Maytag MDE9700AYM Electric Dryer
Neptune Dryer Time keeps going forever
your problem is most likely an issue with the start button. if it is stuck, the dryer will keep running even though it has passed the off position. your start switch probably needs replaced. Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
514 people viewed this question
Top Dryers Experts
