Question about Acer Aspire 5100 Notebook
Windows Vista not loading
Had a recent problem with a memory stick stuck in the drive. Got files transferred and then worked it out and unstuck from the slot. Also in the process Shockwave updated itself. Shut it down to get the stick unstuck. Took the battery out and unplugged it. Now it won't load Windows Vista back up. Suggestions. Have tried to reboot and no luck.
  • 3 Answers
FIRST OF ALL YOU SHOULD
  • REMOVE THE BATTERY COMPLETELY
  • LEAVE IT TO STAND FOR ABOUT 15-20 MINS,
  • TAKE CLOSE LOOK AT THE USB PORT AS ITS LIKELY TO BE DAMAGED,
IF IT IS, THEN CAREFULLY REMOVE ANY DEBRIS WITH SOME TWWZERS AND ENSURE THAT NONE OF THE INTERNAL PINS ARE TOUCHING
  • REMOVE ANY OTHER USB DEVICES
  • REFIT BATTERY AND BOOT THE SYSTEM ,PRESS F8 AND SELECT LAST GOOD CONFIGURATION
WHAT YOU HAVE JUST DONE IS REDUCED THE CHANCES OF DAMAGING ANY FURTHER HARDWARE I.E. YOUR SYSTEM BOARD , AND STARTED THE SYSTEM AS IT WERE BEFORE THE SHOCKWAVE UPDATE,
IF EVERYTHING SEEMS OK AT THIS POINT ,YOU SHOULD NOT USETHE DODGY FLASHDRIVE AND CHECK YOUR WINDOWS IS UP TO DATE.
HOPE THIS HELPS
Posted on Apr 07, 2008
Sony Memory Stick 8gb Pro Duo Memory card
In windows shows all files also the system files and then check your memory card and delete the files.
Or you can connect your memory card to a mac or a linux to see all files also the hidden.
Aug 08, 2012 | Sony 8gb Memory Stick Pro Duo Hg Hx 50mb/s...
Tip
Sony Memory Card File Rescue Service If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
use Sony's Memory Card File Rescue software to recover your data.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Download Sony Memory Card File Rescue Here.
I hope that helps.
____________________________
Download Sony Memory Stick Formatter here.
on Apr 18, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Tip
I hope that helps.
on Apr 18, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
How do I use a memory stick to transfer homework on a laptop to my computer
You will need to connect your memory stick to your laptop where the homework is stored. When you connect it, you should get a message asking what you want to do with the memory stick. If you cancel this and go to My Computer (if on Windows XP or Computer if on Vista or Windows 7), you should see your memory stick listed there under removeable devices. If it is not there, then there is a connection problem. Try removing and reconnecting the memory stick.
Once your memory stick is connected, go to where your homework is stored. Right click on the file, go to "send to" and then select your memory stick. The file should then copy over. If there are more files then do the same. Once completely copied over, you can remove your memory stick.
You then need to do connect the memory stick to your other computer. Go to My Computer and then open the drive under removeable devices. Select the files for your homework. Right click on any of them, choose copy. Go to where you want to save the files, right click and paste. They files should copy over.
Hope that is helpful and answers your query
Thanks
Nov 10, 2010 | Computers & Internet
Transferring music files with a memory stick
Insert the memory stick into a USB port on your computer.
Windows will recognize the device,
and give you a choice of applications, i.e., play music with Windows Media Player, or, use Windows Explorer to browse.
Select Windows Explorer.
Click to select the files/folders.
Choose "Copy Files".
Copy into your "My Music" folder on your new computer.
Nov 14, 2009 | Computers & Internet
Tip
I hope that helps.
on Apr 18, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
I cannot transfer photos onto my memory stick from windows photo gallery on vista home premium. I right clicked on the folder name looking for either ''send to'' or ''save'' so I could transfer the whole...
Drag and drop. open my computer and select source file, then click my computer again and select the memory stick ( you should have 2 open windows, best if minimilised ) then just drag and drop. Mouse over, left click and hold the left button drag the picture(s) to the stick and let go of the left button.
Apr 26, 2009 | Computers & Internet
Document transfer from vista hard drive to memory stick
4gb is not enough space to hold the entire My Documents directory unless you have an extremely small amount of data in it. If you take many photo's it wont be long before My Documents is too big to fit. Suggest that you back up this directory to a set of CDs or DVDs,
If you want to update a memory stick just copy My Documents from Vista to the memory stick. Vista will ask if you want to overwrite. Click [on overwrite all] and the job is done.
Jan 10, 2009 | SanDisk Open Box 1GB Cruzer Mini...
PROBLEM: k750i Memory Stick Duo Pro - Sony
hi
first format the memory card and upgrad the firmwer of your mobile then check for the same problem, happen again change
thet memory card.
vyas
Apr 17, 2008 | Sony Ericsson K750i Cellular Phone
PQI Intelligent Stick -- interrupted file transfer, removed unsafely... rescue data?
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Mar 22, 2008 | PQI Intelligent Stick (267027) Hard Drive
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
