Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
HP Pavilion F1503 LCD Monitor
The screen will come on very briefly, flicker and then go black. Is this the power inverter or the backlights? There are two backlights, and I don't see any red or yellow invertor transformers. I looked for an inverter online but can't find one for this model. Does it have one. I hope you can tell me what the problem is. Thanks, Pete
  • 1 more comment
  • kim002 Apr 10, 2008
    I do not know how to get the screen apart to do the things you have suggested. Can you help me?
  • peterb827 Apr 11, 2008
    There may be other issues, like a bad backlight, because after soldering it still did not work. Thanks for the advice. Pete
  • ichey103 Apr 28, 2008
    there are no brown/yellow/red transformers with a ferrite core in mine
    Champion:
  • 220 Answers
If you can see the backlight ,white 2pin connectors connect to invertor pCB.Look around these two connectors you should see 2 brown/yellow/red transformers with a ferrite core.These are the inverter transformers , resolder all pins and power transistors around it.
That should solve your proble.
Please provide feedback and rate this solution.
Samir.
Posted on Apr 08, 2008
Which model of Inverter Board does HP pavilion f1503 uses? My backlight keeps on dimming after 10 secs of start up. please be spefic with the model number
The part is a "ribbon cable" for an lcd monitor...ribbon made by Youngshin (AWM 2896 30V 80C VW-1).
2 ribbon cables for a hp pavilion f1503 LCD monitor (the two from the AD board to the TCP)
The LCD panel is made by HannStar (HSD150SX84).
Also, looking for other LCD parts, particularly:
the AD board for a Proview Pro-576 (I assume Sylvania PL-576 & Mag LT576s are similar); Board #: 200-100-AS576 Rev: B MV5-S2?
It uses a sampo inverter (QPWBGL8621DG) & a AU Optronics M150XN05 LCD.
Jun 20, 2012 | HP Pavilion F1503 15" LCD Flat Panel...
Turns on but very dim
This is a 15 inch LCD. and the inverters of these units go south often.
If the unit does not flicker and you do not have a lose of power, it will be the inverter.
Oct 21, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion Entertainment Laptop Monitor flickers black
If the laptop is under a year old it could still be under warranty and if so I would get it repaired under warranty.
OTHERWISE
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 02, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Monitor flickers goes out then comes back
Check out
www.lcdparts.net
Jul 10, 2009 | HP Pavilion dv5-1125nr Notebook
Inverter problem
1800652667 as soon as hurricane Ike gets done with Houston, Texas. Or www.hp.com/go/support
Jul 21, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Hp monitor black screen
Check for the updated drivers as well as your video card, if you have an internal video card and have tested it (your computer) on another monitor it is more than likely the inverter in the monitor the coils (on the mainboard) need to be resoldered more than likely.
Check the backlight as well
Jun 24, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Hp pavilion f1503 wont stay on
is your computer still running after the screen goes blankl
Jun 09, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Blackout problem
Normal problem is dry solder of Inverter transformer and/or transistors around it .
Samir.
Mar 28, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 1503 15in Flat. screen blanks out constantly
THis is a problem of the invertor board.If you are technically able you need to disasseble the monitor and resolder components around the red or yellow inverter transformers.
Samir
Mar 04, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor goes black
Samir.
Aug 30, 2007 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
199 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
