When I tried to insert a memory card which I was using for a Nokia mobile set, my camera's screen turned black and displayed system error 1 0
Let me give you a little information about this issue. Nikon 4600, S1 and S3 have a faulty operating system. The good news is that there is an update for it. The process of repairing that issue might take an hour or two. You have to hard boot the camera with a jumper setting on the unit to force the new operating system in the camera and then upload all the updates.
Nikon is repairing them for people, but they want you to send it in and are charging people $87 for the repair. You might be able to find someone near you that can do the repair for you much cheaper.
It might just be better to buy a new camera.
Sorry i couldn't help more. Good luck.
Is the card formatted? If not, format it in your phone, or via card reader hooked up to PC.
When a System Error message appears on the LCD screen of the
Nikon Coolpix 4600 this usually means the camera has a fault that will need
repairing. There are two things you can try first. The first one is to try a
different memory card. The second is to remove the batteries for 24 hours and
then put them back in the camera and try again. If this does not work contact nearest Nikon Service Center.
Good Luck, do rate the solution if helps
