Question about GE DPSB650EC Electric Dryer
Dryer will not turn on
Light in drum comes on, but when you press power pad...nothing... dryer will not come on at all, just the drum light.
  • jawag Apr 20, 2008
    the electronic pad/ control board does not light at all, is it worth replacing the asm panel? It is quoted at 350.00
    Novelist:
  • 184 Answers
IT COULD BE THE DOOR SWITCH. PRESS THE BUTTON IN WITH YOUR FINGER AND SEE IF THE LIGHT GOES OUT.
DOES THE SWITCH HAVE A POSITIVE CLICK? NO. REPLACE SWITCH. YES, THERE IS PROBABLY A THERMAL FUSE LOCATED SOMEWHERE NEAR THE EXHAUST. IT MIGHT HAVE FAILED. IF SO, THERE MAY BE A PROBLEM WITH OVERHEATING. THE MOTOR COULD ALSO HAVE FAILED. THE PUSH TO START BUTTON COULD ALSO BE DEFECTIVE.
Posted on Apr 08, 2008
  • DAVID LOGAN Apr 22, 2008
    THAT'S A CALL YOU'LL HAVE TO MAKE YOURSELF. IF YOU HAVE BEEN SATISFIED WITH THE DRYER UP TO THIS POINT, AND IT ISN'T TOO OLD, IT MAY BE WORTH IT. IF THERE HAVE BEEN OTHER ISSUES, YOU MAY WANT TO INVEST IN A NEW ONE. THE AVERAGE LIFE OF A DRYER IS 17 YEARS.
I have the LG Model# DLE1101W dryer. The dryer will power up but when I go to start the dryer after I put a second load in, I get a series of dinging sounds when pressing the start button and the drye
Id like to see if I could help you so you will have to use more definitive terms, "Start" I'm guessing that you mean that the drum doesn't turn? (the lights come on and you push the start button and the drum does not turn) If that's the case I would start with the door switch, Best to start with the most obvious first. Try jumping it to over ride wait your response
Sep 17, 2014 | LG DLE1101W 7.3 cu. ft. Ultra Large...
Turn on power, the lights come on but when you press start nothing happens just a click sound.
Click sound at power button and start button should get it going. If not then Dryer drum is not turning.
Aug 08, 2013 | Whirlpool Cabrio WED5550XW 27" Front-Load...
Dryer won't start..light clicking noises
There is a switch inside the unit that stops it when the belt breaks or comes loose. Check that.
Mar 15, 2017 | LG Home Applaince LG DLE2101W 7.3 Cu. Ft....
"control on" button doesn't come on
could be a bad capacitor inside the dryer
Jan 10, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmore dryer electric doesnt start
It sounds like the dryer drum belt is broken
there is a drive belt that goes all the way around the dryer drum and when you press start the drum starts turning unless teh belt is off or broken
You can change the belt or call and have service technician change it
Jan 04, 2009 | Maytag HYE3657A Electric Dryer
Dryer has power but drum want turn
check to make sure that nothing is stuck in the blower wheel if nothing is caught then you need a new motor
Dec 19, 2008 | LG DLE2532W Electric Dryer
Dryer won't turn on - interior light on
It sounds like you have either a broken drum belt or a door switch that isn't working. If the dryer belt breaks, the drum will not turn, but you will probably still hear the motor running. I don't think your model has a broken belt switch that disables the motor (at least I couldn't find one). You didn't mention anything about hearing a motor running, either. The likely cause, then. would be a door switch. If the switch was not making contact when the door was closed, it would give the very same symptoms you described. Have you tried pushing on the switch with the door open to see if the drum light goes out? If the light DOES go out, we probably have a primary power problem to the drive motor. If the light DOES NOT go out, replace the door switch. You can find the part at searspartsdirect.com. Just type in your model number and you can locate the switch under the "Cabinet Parts" heading as item number 10 (part #3406107). Let me know how you diagnose this and get back to me. If it is the switch, I can give you steps on how to replace it. If its not, then we'll have to troubleshoot a little further. I'm trying the simple approach first before attempting to disassemble the dryer. I hope this helps you.
Jul 03, 2008 | Whirlpool LER5636P Electric Dryer
Drum not turning
Have you recently lost a sock or a pair of drawers? Something mught be stuck in the impeller blower fan) attached to the motor. Very common problem
Dec 08, 2007 | GE DCSR483EA Electric Dryer
Dryer suddenly stopped - F&P ED56 Autosensing Dryer
what is the make/model of your dryer and does it have an electronic display? different solutions apply to different models thank you
Sep 09, 2007 | GE DVL223GB Gas Dryer
GE DPSB650EC Electric Dryer Logo
89 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
