Question about Targus USB Ultra Mini Keypad Keyboard PAUK10U
Need to find a download for this
I need to find a download for this product cause it is not working on my computer do i plug it into the keyboard or the back of the computer? Please help me.
    Sergeant:
  • 287 Answers
User giude HERE
Posted on Jul 26, 2008
My keyboard keys are not working. I'm unable to enter my password. Mouse works
Try unplugging the keyboard and re-plugging it back into the USB Port.
If you have a cordless keyboard, the batteries may need to be replaced.
Brand make model of keyboard is not stated, I can no help you further.
Nov 16, 2016 | Computers & Internet
Dell latitude d630 some keys not working
Try plugging in a USB keyboard. If it works, backup your data to an external drive, then try looking for (and downloading/installing) any keyboard driver for your product from the Dell Support Site (you will need to enter your Service Tag - usually on the outside of the computer). http://www.dell.com/support/drivers/us/en/19/ProductSelector
Then, see if all the keys work. If not, you may need to get it replaced (which may exceed the cost of a new computer).
Jun 30, 2014 | Dell D630 Latitude Laptop Motherboard...
How do I connect the main unit to the front end?
Which main unit to Front end of what?
Sorry to say,but your question is not very clear about which product you need support.
Thus, please give some more detail on your product whenever you ask any support so that the experts can search the exact products and provide better support as there are hundreds of similar products in the market.
Please give exact Make and Model number of your product and also some more detail on your problem so that we could identify your issue better ant give appropriate solution.
Thank you.
Aug 24, 2011 | Computers & Internet
Trying to connect HP Laserjet 2100 (works fine with XP) to Pavilion dv7 with Win7 64 bit Professional. I downloaded the PCL5 driver from HP but it will not print. I am using a Manhattan parallel to USB...
Did you download the Win 7 64 bit drivers for this printer. If not i suggest try downloading the drivers from the following link
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=14914&pr...
Check the USB connection
The icon on the USB cable (c01424575.gif ) faces up when the cable connects to the product correctly. Check the back of your product and the back of your computer to make sure the USB cable connects correctly and securely.
After you make sure the USB cable connects correctly and securely, review the following guidelines to check other potential USB-related problems:
  • USB ports on the keyboard. USB ports on the keyboard and in the front of some computers might not be powerful enough to support the product. If the USB cable connects to the USB port on the keyboard, try connecting it to another available USB port on the computer.
  • USB cable length. HP supports USB cables less than 5 m (16 feet, 5 inches) long. However, a USB cable that is 5 m (16 feet 5 inches) long must be of high quality. Otherwise, HP recommends using a USB cable that is less than 2 m (3 feet, 3 inches). Do not use patch cables to increase the length of an existing cable. Use a powered USB hub if you need more length.
  • Alternate USB ports. Connect the USB cable to another port on the computer to make sure that the USB port on the computer is not the cause of the problem.
  • Defective USB cable. Replace the USB cable to make sure that the existing cable is not defective.
  • Conflicting USB ports. Disconnect any other USB printers, USB scanners, USB cameras, and any other USB connected peripherals. Start reconnecting these devices one at a time to determine if one of the devices is using too much power. Consider purchasing and installing a powered USB hub if necessary. NOTE: A USB-powered hub is a device that increases the number of available USB ports on a computer and facilitates communication between the USB devices and the computer. A powered USB hub can resolve communication failures between some, but not all, USB chipsets and HP products.
Jun 23, 2011 | HP LaserJet 2100 Printer
Hello, I am asking this question about my Logitech Keyboard M/N Y-RAU7; ID JNZ202198. All of a sudden one day after owning my computer for 2 years, the keyboard stopped working. The mouse works fine...
Try downloading new drivers for your keyboard. Go to the logic tech website and get plug in the model number of your keyboard under the product support keyboard driver section. Reboot your computer and it should work.
Aug 17, 2010 | Computers & Internet
My Trust wireless keyboard and optical mouse will not install when I start my computer
Be sure that you have new batteries installed in the keyboard and the mouse.
After booting up into windows, plug them back in and see if windows detects them, if it does detect them it should install the drivers for the mouse and keyboard. If it doesn't then go here and download the drivers for it:
http://www.trust.com/products/productdrivers.aspx?artnr=14627
If after downloading and installing the drivers the mouse or/and keyboard still doesn't work, hit the connect button on the receiver for the keyboard and mouse. Then hit the connect button on the keybyoard and mouse.
This will make sure that both the keyboard and mouse synch with one another. If they still won't work after all these steps then you know for sure that either the keyboard and/or mouse are definitely bad and would need to be replaced.
Jan 11, 2010 | Trust Wireless 11676 Keyboard
Wireless keyboard
what you should do is go to Microsoft website search for your keyboard and mice their you will find the exact device drivers reinstall them restart your computer then plug the keyboard and mice back in. if that don't work try using the installation disk that the products came with. Also their are specific instruction that comes with such devices. example you might have to press a button on the wireless receiver and another bottom on the keyboard together for a couple of seconds to get it to work properly. I hope this helps please vote/rate me
Jul 21, 2009 | Computers & Internet
Ctrl + Alt+Del
Hi
is it a usb keyboard or a ps2(round connector) keyboard? the problem is most likely that due to the computer not having started up properly the keyboard is not properly configured / installed by windows.
to get rid of this problem, you need the old type of keyboard, turn off the computer, and plug in a keyboard to the ps2 connector.
green one is for the mouse, the other is for the keyboard, plug in a keyboard, then turn the computer on, you should be able to press CTRL+ALT +DEL now and ones you sign in to the computer it should install the usb keyboard and it should work from now on, just make sure the keyboard is not disconnected or port changed when the power is off from the computer that cause the configuration loss.
May 21, 2009 | Microsoft Windows XP Professional for PC
Acer Aspire 5100 Notebook Boots to Windows, but nothing works. No keyboard, no mouse, no usb or CD, no external monitor.
need computer keyboard drivers and/or layouts. Additional information and links to comptuer keyboard drivers and layouts.
Keyboard, Mouse, and other input related links Linking you to various locations on the internet about computer input devices.
Information about the AT and PS/2 port This port is commonly used for a computer keyboard. ... This port is used to accept input devices such as the Mouse and Keyboard.
A20 error Issue related to the keyboard and/or keyboard controller. Solution:. Ensure the keyboard is connected to the proper port on the back of the computer.
Additional information and help with installing computer hardware. PC computer keyboards PC computer motherboards PC computer mouse PC computer power supply PC computer memory ... CH000449, Installing a computer keyboard.
NTOSKRNL.EXE is missing or corrupt. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the
Read instructions/Good Luck, Please dont for get to Vote/Thank You.
Dec 23, 2007 | Acer Aspire 5100-5033 Notebook
Targus USB Ultra Mini Keypad Keyboard PAUK10U Logo
137 people viewed this question
Top Targus Computers & Internet Experts
dhnguyen
Josh Whitehead
Josh Whitehead
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
