Question about MTX Thunder 8000 T8154A Car Subwoofer
Sub repairable? The rubber has come loose on my 10" MTX subwoofer. Can this be repaired or will I need to replace it? It's about 3 years old.
  • 185 Answers
Ya u can use crazy glue or gorilla glue
Posted on Apr 09, 2008
How do I hook up 4 10 inch mtx old school?
you can put them in one box you will need a good port hole if you do.How to build subwoofer box
this link is on how to hook up speakers Subwoofer wiring diagrams \
good luck
Aug 11, 2015 | MTX Car Audio & Video
How many watts will the 10 inch mtx thunder 4000 have
It should tell you on the back of the sub ,The continus watts it will handle, If not phone the place you got it from, Or some place that sells them,
Nov 28, 2012 | MTX Thunder 4500 T4510-04 Car Subwoofer
Need rubber lip and diaphram for 10
junk it upgrade to a mtx thunder square 8500 im just waitin to blow my L7 10 but its taking like 8 years,,, hahaha
Jan 09, 2012 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Where can i find a foam surround to replace my 10'' mtx 6000?
You would have to look for a re coning kit from either MTX site or amazon or ebay
Aug 22, 2011 | MTX Thunder 6000 T61544A Car Subwoofer
How big of hole do i need for the mtx 6000 thunder 10in
The MTX Thunder 6000 T61544A is a 15" Subwoofer meaning you will need a 15" hole to fit the subwoofer into. The mounting plate that surrounds the subwoofer will extend past 15" allowing you to screw the sub in properly. Be sure to use a box that is at least 12 inches deep (sub is 10 inches deep by specifications + 2 inches for good air cushion behind.
Mar 01, 2011 | MTX Thunder 6000 T61544A Car Subwoofer
How do i wire mtx 9500 subs 2 10'' down to a one ohm
THE T9510-04 SUBS ARE SINGLE COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-04.pdf
THE T9510-44 SUBS ARE DUAL VOICE-COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-44.pdf
SINCE YOU NEED A 1 OHM LOAD, I PRESUME BRIDGED AND ARE USING TWO SUBS, THEN HOPEFULLY YOU HAVE THE DUAL VOICE COIL TYPE, AS THEY ARE DUAL 4 OHM AND YOU WILL HAVE TO CONNECT THE VOICE-COILS IN PARALLEL WHICH WILL MAKE EACH SPEAKER A 2 OHM SPEAKER AND THEN CONNECT THE TWO SPEAKERS THEMSELVES IN PARALLEL AND THIS WILL PROVIDE YOU THE 1 OHM LOAD. IF YOU IN FACT HAVE THE SINGLE 4 OHM VOICE COIL VERSION, THEN IT WILL ONLY PARALLEL THE PAIR DOWN TO 2 OHMS. OK. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 08, 2010 | MTX T9510-44 - 10" 9500 Thunder Series...
MTX Thunder7500 T7512-04 needs repair
can try to repair it is it around the outside rim ?? use SILOCONE to repair it as it will flex when used DO NOT USE SUPERGLUE
Sep 05, 2009 | MTX Thunder7500 T7512-04 Car Subwoofer
Rotten foam rubbers
You can have "The Speaker Factory" re cone them. Call for an est.first Generally gonna be less expensive to replace.
Jun 25, 2009 | MTX Road Thunder RT-1240 Car Subwoofer
Blown fuse??
there is an underlying cause for the fuse to blow. if something shorts out you would rather a 40 cent peice goes then the unit causing a fire. disassembly is require... look for obvious burnt parts first.
Robert
Sep 01, 2008 | MTX SW2 Subwoofer
Replacment speakers
is the rubber worn outta of them u can replace that easy nice quilty ring sets on ebay 20 bucks or u want new sub try mtx middle model 12 in to replacxe would be nice with your highs good mix
Jan 09, 2008 | Audio Players & Recorders
MTX Thunder 8000 T8154A Car Subwoofer Logo
167 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
