Question about Rockford Fosgate Punch P5002 Car Audio Amplifier
I have a Rockford Fosgate Puch 1000 watt amp "thermal" problem
Like i said the thermal light keeps turning on, the subs wont hit but the amp turns on, but the thermal light turns on. i wasnt doing ne thing out of the ordinary just going to school. F.Y.I i leave the gain up all the way and the freq. dwn the whole way, other then that i dunno what could have happened, can u guys plz help me out, i need that amp for the next bass comp for may 25 :P if i cant get it fixed i have 2 crappy 12" kicker comp VR's and 2 12" "lightning audio" Wallmart kickers hooked up to a Fosgate 426 amp. it sounds poopy in the trunk of my Nova, its all bare metal. but yea ne ways sorry for bsing ..... HELP MEEEEE!!!!!!
  • d3lgad00619 Dec 12, 2008
    i have the rockford fosgate p2002 amp.
    and i hooked it up and it wont turn on anymore!!!
    but if i unplug the ground and the 30A fuse then it the corners of the rockford fosgate logo lights up and the thermal light goes on.
    i plug em back in and the amp wont turn on or anything='[[[
    somebody please help me=[[[[[[[
  • Anonymous Apr 23, 2009
    sub just stopped same amp as dude really same problem
  • 631 Answers
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up without the thermal LED being lit, the wiring needs to be checked. If it still indicates that it's in thermal protection, it needs to be serviced. A local repair shop will be the quickest. Rockford will email you the schematics.
Posted on Apr 08, 2008
  • Tyler Jones
    Tyler Jones May 20, 2015
    I had the same problem with the same amp. Stuck in thermal mode. The problem was where the ground cable connects to the car chassis, mine was completely disconnected. My subs still had faint power since the ground cable was still touching the metal. But once I fixed the connector is was good as new!! No more Thermal light.
Get a new car
Posted on Jun 27, 2008
Does anybody know what watt this is. it's sosed to be a 2400 watt and why does it have 2 ports on each side to hook up speaker wire And what's the best way to run it with a 800 watt Rockford fosgate
dual voice coil subs hook up mono on amp, from amp - from right side + from left side of amp run to sub n then jumper wires from one side of sub to the other side goes negative jumps on positive and positive jumps on negative
Apr 03, 2015 | Rockford Fosgate Car Audio & Video
Why does my 6x9 amp drop or not let the sound play at all when my subs are on? it just started to happen? they worked together fine before. i turn the subs off and the 6x9 work? but when i turn the subs on...
You probably have too much hooked up for the size of your power supply which is presumably a small car battery. You either need to get:
A) New, better bigger battery.
B) Capacitor in series with battery.
C) Both of the above.
Mar 08, 2010 | Rockford Fosgate Punch Stage P212 S4 Car...
I have one 12inch 1000 watt mtx sub what size amp should i buy
Hello taona80,
If the 1,000 watts is RMS, I'd recommend an amp in the 750-1,000 watt RMS range, perhaps like the Alpine MRP-M1000 or Rockford-Fosgate T1000bd. If the 1,000 watts is peak power, the subs continuous (RMS) power handling is much lower, probably 300-400 watts. In that case, I'd recommend the Alpine MRP-M500 or Rockford-Fosgate T500-1bd.
Nov 09, 2009 | Nitro BMW-482 Car Audio Amplifier
Amps that work with 10" RFZ2410
well how manny amps can the sub hold? any amp will work you can bridge it to doulbe the power but i would say a 200 wat amp would do you good
Aug 02, 2009 | Rockford Fosgate RFZ2410 Car Subwoofer
Same exact problem
Hello phatjay_31,
It's likely that the sub has been damaged by too much power. The Type R's in both 10" and 12" versions can only handle up to 500 watts RMS. The 15" version can handle up to 750 watts. The Rockford-Fosgate T3000bd1 amp puts out 3000 watts RMS into a 1 ohm load.
I'd check the voice coils. They are probably melted.
Hope this helps.
Jul 19, 2009 | Alpine SWR-1222D 12" Type-R Series...
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Sep 08, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
I think my ex blew my amp
model number? im thinking 401s? if so that should be the only light on
Aug 07, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Rockford Punch 550.2 amp wont play
The amp is blown and need to be repaired.
You can contact Rockford direct to find a repair dealer.
Apr 16, 2008 | Rockford Fosgate Punch P550.2 2-Channel...
Rockford Fosgate Punch P5002 Car Audio Amplifier Logo
1,494 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
