Question about Sony FD Trinitron WEGA KV-36HS510 36" TV
Kv36hs510 Power light blinks, but tv is not coming on. It always made a very loud noise before coming on, but now it just won't come on. Is it acircuit board that needs replacing? From the messages on the board it sounds like a common problem? Do you have a rough estimate of the cost? thanks
  • ladychaos Jun 05, 2008
    My tv normally made that pop noise when I turned it on but one day it just went black. Now, when I try to turn it on the stand-by light flashes and it turns on and off right away. How broken is it?
    President:
  • 2,712 Answers
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). This could have happened during the moving process. The sound comes from the flyback unit. I guess it must be a high pitched squeal, actually...
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
Since the set is new, it may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise. Many shops are hurting for work because so many of the smaller sets are never repaired anymore; they are just thrown out and replaced since the cost of a new set is sometimes as low as the repair expense.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers,
IrishDruid
Posted on Apr 26, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
Panasonic PT-61DLX76 tv power indicator light blinking orange 2X. Manual says it is malfunction 2. What is that and can I fix it myself?
That doesn't sound like something you can fix yourself. At a hunch I would suspect power supply board faulty.
Around £40 for a repair place to look at it, or bin (ebay) it.
Sep 07, 2015 | Panasonic PT-61DLX76 Television
My kv36hs510 2003 falt screen tv wont turn on but you can hear it trying to turn on, what can i do?
This set is very heavy and if fails to come on the power light should blink a specific number of blinks repeated over and over.
There are almost no customer repairs possible here as every part is special and Sony only---even as much as these sets cost new most when fail are being retired/recycled and replaced.
Typical repair cost in most cases will exceed 200 dollars or more.
Oct 21, 2012 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
Jun 16, 2012 | Toshiba 52HL167 52 in. LCD HDTV
When the tv is turned on I hear a loud grinding like noise
May I know if the unit won't power up, has a three blinking led light at the front panel? Also, please check if the grinding noise is near the lamp assembly.
Mjsazon
Dec 01, 2011 | Samsung DLP HL-P5663W 56" TV
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Flashing light blinks off and on , tv does not work
Hello I have a projection tv and mine did the same thing and it was the lamp they will burn out, but you will have sound but no picture, hope this helps you
Oct 14, 2008 | Televison & Video
36 inch sony TV flat screen
Good day.
Flyback could sometime be a problem but seldom that its the source. Have your circuits be checked first particularly the vertical section. Also, check on the supply of your system IC. there may be some imbalances there.
Response is highly appreciated.
chris
Mar 18, 2008 | Sony KV-36FS12 36" TV
Sony FD Trinitron WEGA KV-36HS510 36" TV Logo
61 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
