Question about Fostex MR16HD/CD Digital Recorder
Display error When I power up the unit, the screen will illuminate, but I'm not getting a menu or any text in this screen. when i power up it goes into formatting mode and will not let me access the menu or setup options. what do i do?
    Genius:
  • 3,422 Answers
1. Is it a stand alone or have you get it hooked up to a PC?
2. If with a PC, Win Xp or Vista, Mac?
3. Is the unit new, refurbished, bought from ebay or from a dealer.
If the unit is more than 2 years old then the only solution is to get it repaired or buy a new one instead.There are instances where internal software gets corrupted or even in some models, memory battery has leaked or depleted.
Unfortunately there is no external reset for the unit. It has to be opened up and diagnosed with the use of a special diagnostic PC and software. The firmware may also need to be re-installed or updated.
Am afraid your only best bet would be to open the unit and check the inside. Easy enough would be memory battery (if ever present) since they look like a thick coin (Lithium 3Volts) but other than that, most repairs would need knowledge and familiarity with electronic component and circuitry, a service manual, a DVM, a soldering iron and even as earlier stated some specialized equipment.
Perhaps your best bet would be to seek the services of a qualified professional or the nearest authorized Service Center.
Goodluck,
Please don't forget to rate the solution as fixya..
Posted on Apr 07, 2008
Screen goes black but sound is good.
This sounds like the inverter which powers the display fluorescent has or is failed/failing. If you take a torch to the blacked out display can you see the image faintly? If so the unit needs repairing.
Mar 12, 2015 | Televison & Video
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
Panasonic PT LC76U Multimedia Projector Lamp how do i reset the timer
press the MENU button to display the menu screen, and then press the UP and DOWN aero button to select the "OPTION" menu. press the ENTER button and then press the UP and DOWN aero button to select "LAMP RUNTIME". Press and hold the ENTER button for approximately 3 seconds.
The "LAMP RUNTIME" screen will be displayed.
(NOTE: press any button other then the POWER button to cancel the "LAMP RUNTIME" screen)
Press the POWER button to turn off the power.
The POWER button on the projector illuminates red.
This will reset the cumulative usage time for the lamp unit to "0"
Jan 12, 2011 | Panasonic PT LC76U Multimedia Projector
How do you change language from Spanish to English on this phone? I put it on spanish somehow and i cant get it back to english.
Hello
Using Settings
Settings contains many submenus that let you customize your phone.
Display/Info Features The Display/Info menu controls how the keypad and display appear: - changes the wallpaper that • Wallpaper appears on the idle screen. - sets the size of text on the display. • Text Size - changes the look of the display. • Theme - controls whether main menu • Home Icons icons appear on the idle screen. - controls backlight illumination. • Backlight133 Customizing Your Phone - controls whether the time and date • Clock appear on the idle screen; sets time and date format; sets year. - controls whether the items on • Menu View your main menu and Java applications menu appear as large icons or a list. - sets large digits to appear on • Large Dialing the idle screen when you enter a number. - sets the language that your phone • Language displays.
for more information Get the manual from here http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/i850/US-EN/_Documents/Static%20File/i850_UG.pdf
Hope this helps if so do rate the solution
Jan 05, 2011 | Motorola Mobility i850 Cellular Phone
My screen goes off when windows xp starts the boot process
Does the display come back at all?
Is it the same on an external monitor?
As soon as BIOS screen disappears press F8 multiple times until a text menu appears allowing you to to select SAFE MODE. Select SAFE MODE.
DO you get a display now?
Can you select 1024x768 resolution and get a display, if so, rebot and try a normal boot.
May 16, 2010 | Acer Computers & Internet
Screen goes dark
It could be the display power inverter or the illuminator is going out. generally the inverter goes first.
Apr 29, 2010 | Sony VAIO PCG-K33P Notebook
Center of screen goes black
Check your closed-caption settings and make sure you have captioning turned off. You'll probably find it set for "text" mode right now. This causes the set to blank out a portion of the screen for the text, but there isn't any text to display.
Feb 11, 2009 | Samsung LN-R409D 40 in. LCD Television
Display error
Here is the link to your other post pls.
Feb 09, 2008 | Fostex MR16HD/CD Digital Recorder
Display
Green power light blinks every 3 seconds with the word Xerox on the screen, with just a black screen. Could this be a bad Switching Power supply cord?
open it up... whats the worst that could happen... see if the caps are fine... if they are bloated exchange them... if you need help doing so hit me up at abelino24(at)sbcglobal(.)net... I've repaired like three of these in the past few months.. its always the capacitors. they either get really hot and bloat or don't function if it gets too cold... so the solution if to get the right caps at 470uf / 25v and 220uf / 25v... hopes this helps...
Nov 18, 2006 | Xerox XG-71D 17" Flat Panel LCD Monitor
Open Questions:
See all Fostex MR16HD/CD Digital Recorder Questions
Fostex MR16HD/CD Digital Recorder Logo
89 people viewed this question
Top Fostex Televison & Video Experts
Henry  Thomas
Henry Thomas
Michael Galve
Michael Galve
Tom Chichester
Are you a Fostex Televison and Video Expert? Answer questions, earn points and help others
