Black screen on tv when turned on
The Tv turns on but nothing is on the screen. Not sure if the audio works because it is set to the digital in setting right now. Power indicator is on but there is a slow flashing light just above that isn't normally there.
  • jhmoog Jan 10, 2009
    The TV turns on but there is no picture. The audio is fine but the screen is black.
    Champion:
  • 367 Answers
If you open the back,look at the can shaped items.If any of them have the tops bulged out,they need to be replaced.This should solve your no picture problem, unless there is something else wrong.Hope this helps.Thank You very much!
Tyler
Posted on Apr 07, 2008
Can not get sound on the tv screen when I turn it up on to channels no sound at all Mrs s hardy
When you say you turn it up, I assume you see a volume bar appear on screen which changes as you change the volume. Try going into the TV menu with the remote and navigate until you find settings for the audio/sound making sure the speakers are set to "On". If they are you are more likely to have a problem internally requiring service.
You can, as an alternative, connect audio cables from the output of the TV to a stereo receiver/amplifier and see if you get sound that way, although that is only a work-around for your real issue.
You could also feed the TV digital audio output to the stereo amp via HDMI, digital coax, or fiber optic, if the stereo has those inputs.
Jan 23, 2016 | Televison & Video
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
Black screen on VOJ32o1A
Check and replace the back light inverter board. Check CCFL lamps too.
Jul 29, 2012 | Vizio VOJ320F1A 32 in. LCD TV
TV was working fine and then the picture has totally gone, just a Black screen as though it is switched off, Audio on all channels are fine and turns over as normal. No Text no nothing on the screen...
solution
step 1 : at first test your fly back transformer
step 2 : A.C. transformer test
step 3: adjust TV yoke coil
Send report :babul_jpi90@yahoo.com
Jul 28, 2011 | LG 50PS60 50 in. Plasma HDTV
Nothing happens when i connect my RGB to my TV i have pressed the button on my laptop which enables the external monitor connect but that still dosnt work.......... Also my laptop screen also turns black
The laptop screen turning black is what it's supposed to do.
Make sure your computer has the correct output, and the TV has the correct inputs. Very few laptops have analog video out (like the 3 RCA jacks, or the round S-Video jack), but some newer TVs have VGA inputs (Often blue, trapezoidal shaped plug with lots of pins).
If your TV and Laptop are compatible, make sure you've set the Input on the TV to the correct source. You will need to consult your TV manual for this.
Mar 01, 2011 | Computers & Internet
How do I get my Samsung TV audio to output though my onkyo tx-sr608?
If it is a relatively new TV you should use an optical digital audio cable. These are often called "toslink" cables. Plug one end into the "digital audio out" port of your TV, and the other into a free toslink port on the receiver (there are two on the back and a third on the front of the 608).
You should then change the settings on your samsung tv to: - turn the digital audio (s/pdif) output on - allow bitstream output over s/pdif - turn the tv speaker off I am not sure which model Samsung you have, so I can't go into great detail, but I'm sure you will be able to find the relevant settings, most likely under "sound" in your system menu.
lastly, you will probably want to use the input assign page of the onkyo on-screen menu to assign whichever input you use to your TV, and change its name accordingly.
Jan 09, 2011 | Onkyo TX-SR608 Receiver
Tv is black but i can still hear?
Check your wire connections on the back of the tv to make sure nothing had caused them to get unplugged OR been chewed through. If it doesn't fix the problem then try replacing your connections.
Nov 25, 2009 | RCA Televison & Video
My wii has nothing but a black screen when i turn it on
verify that the a/v cables are hooked up properly to your tv and that your tv is set to the correct input so you can see the video and hear the audio.
If you have already done this then go ahead and use a different set of A/V cables to make sure your using a good set.
If after this you still get a black screen then your mainboard inside of your Wii is bad and would need to be replaced.
Aug 11, 2009 | Nintendo Wii Console
Tv problem rca F19431
INTEGRADO DE AUDIO RCA F19431
Jun 07, 2008 | RCA F19431 19" TV
DIGITAL AUDIO IN
check settings on tv to make sure the digital is turned on. if its not red inside the jack on the back of tv, you will not get any sound through it.
Jan 14, 2008 | Accurian AVR-5048 Receiver
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
