OKI C3200n Led Printer
Problem for OKI C3200n Led Printer
OKI c3200 Laser Printer...
By slade52 on Apr 07, 2008
Paper travels past the cartridges but jams in the heater rollers (about 3" passes through the rollers, then the paper jams and folds up like an accordion. I have checked the paper path and all rollers operate freely and there is not any other sheets blocking the path. Can you help me find a solution?
Thank you - Jim Weaver jaweaver@texas-skies.com
Comments:
Apr 08, 2008
- I am feeding it Office Max Laser paper. It has worked well for at least a year and probably 6-8 reams.
Clarification Request
Posted by Joeydonuts on Apr 07, 2008
What kind of paper are you feeding through?
Regular paper or something special?
Best Solution
posted on Apr 04, 2009
Very Helpful)
adspecs
Rank: Apprentice
Rating: 100%, 1 votes
There are 3 little black and white rollers under the cover on the back of the printer. They are pushed under the upper rollers. They should be on the outside of the upper rollers. Somehow they got wedged under the upper rollers. This should fix the accordian paper jam.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Aug 15, 2009
Not Rated)
maxeca
Rank: Apprentice
Rating: 0%, 0 votes
Being in electronics...we wash printed circuit boards all the time. Why not the fuser. So I did. With a brush, soap & water and blew it off with pressured air. Still had an ocassional jam up even after all of that. Next, I put a **** of paper I put a **** of paper in the oven and baked it for an hour and a half at 170 deg. F. Tried it again and what do you think? In my case the baked paper did the trick. It has been raining here alot and maybe the paper has picked to much moisture.
Was this helpful?
Yes
No
Solution #3
posted on Apr 18, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have a similar issue when using GLOSSY labels stock. I can only print one page at a time or it jams up in the fuser.
Solution #4
posted on Apr 08, 2008
Not Rated)
Joeydonuts
Rank: Wiz
Rating: 85%, 34 votes
I would take out the fuser and check for something stuck on the fuser roller. Sometimes you can't see it unless you spin the fuser roller. If you have another fuser, swap it out and see if the problem persists.
You can also try 1-800-OKIDATA.
Comments:
Apr 27, 2008
- Make sure you are choosing a 'Label' stock in the Printer Driver, it does make a difference.
Was this helpful?
Yes
No
Popular Solutions for OKI C3200n Led Printer
Questions and Unsolved Problems for OKI C3200n Led Printer
Do you recommend OKI C3200n Led Printer?
Answer
Answer
I'm having some trouble with the color.
Answer
on color prints, along the borders is fine, the middle 4" +/- comes out faded, large contrast... (More)
Answer
i cant get the mac book pro to use the c3200 oki printer
Answer
okidata 3200n printing tire tracks on right side of page --- did a full cleaning of inside --... (More)
Answer
After about 85 - 100 pages printed it will say paper jam 381. There is one page half way out the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For OKI C3200n Led Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
