Question about HP VP6310 Multimedia Projector
Does not Turn On
My HP vp6310 was turned off and moved to another location. When I plugged it back in, no lights indicated power being delivered to the unit. The projector shows no sign of receiving power, and does not turn on.
  • 123 Answers
Tweenie22,
check ol the cable of ur unit if they were really connected properly..maybe there are might sum steps u just missed out..or try to check the manual..it might help u..
Posted on Apr 07, 2008
SOURCE:
I have a HP office jet printer t45 with an error message c0030002, how can I fix this problem
Try this. Hope it will help you.
This indicates an obstruction to the print carriage. Turn off the power,
c003 xxxx
open the top cover, and look for something preventing the ink car-
(x = any
number)
tridges from moving back and forth.
If the problem persists, close the top cover, turn on power, and open
the top cover again so the print cartridges move to the center. Remove
and reinstall both print cartridges. Close the top cover. Then remove
the power plug from the back of the HP OfficeJet, wait four seconds,
and plug it back in. If the front panel directs you to, realign the print
cartridges by pressing Enter and following the instructions on the
sheet that prints out.
Note:
For any error code not listed above, remove the power plug
from the back of the HP OfficeJet, wait four seconds, and plug it back
in. If the error code persists, contact Hewlett-Packard for assistance.
Oct 01, 2017 | HP Office Equipment & Supplies
Tip
Replace HP VP6321 Projector Lamp Models: HP VP6321 / HP VP6320 / HP VP6310 / HP...
Models: HP VP6321 / HP VP6320 / HP VP6310 / HP VP6300
Here are the steps to replace an HP VP6321 Projector Lamp:
  1. Turn off the projector and allow it to cool for 30 minutes.
  2. Unplug the power cord.
  3. Press the release latch (1) on the lamp cover and remove the cover (2).
  4. Press the release latch on the lamp connector and unplug the connector (3).
5. Loosen the two screws (4) on the lamp module, and pull out the module (5).
6. Insert the new lamp module into the projector and tighten the two screws.
7. Plug in the lamp connector.
8. Snap the lamp cover into place.
9. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp.
10. On the projector, press Enter.
11. Advanced setup, then Reset lamp hours.
12. Press Enter.
The lamp module has now been replaced and the projector is ready for use.
I hope that helps.
________________________________
Download Hp VP6321 Manual here.
on Apr 23, 2010 | HP vp6320 Multimedia Projector
I cannot turn on the HP Pavillion1450. Green power light flashing at rear.
The power indicator light on the back of the Power Supply flashing when power cable plugged in, indicates a problem with the power supply. There is a short somewhere in the wiring. It will need to be replaced.
Apr 11, 2011 | HP Computers & Internet
Color problem when projector connected to computer
It became obvious after a while that there was a problem with the VGA cable. I replaced it and everything is back to normal
Nov 23, 2009 | HP VP6310 Multimedia Projector
Blinking Temp and bulb light on HP VP6310
The color wheel sensor is dead. This is a common problem.
Jan 30, 2009 | HP VP6310 Multimedia Projector
Projectors
The color wheel sensor is bad.
Jan 18, 2009 | HP VP6310 Multimedia Projector
Hp vp6310
If you have no indicating LED, then main power supply is dead. If you have indicating LED but lamp don;t turn on, then it is either the ballast or color wheel sensor.
Aug 23, 2008 | HP VP6310 Multimedia Projector
Blank display
If the printer control panel is blank when you turn on the printer, check the following items.
1 Make sure that the printer is plugged into an active electrical outlet receptacle that delivers the
correct voltage.
2 Make sure that the on/off switch is in the on position.
3 Make sure that the fan runs briefly, which indicates that the power supply is operational.
4 Make sure that the control-panel display wire-harness is connected. See the hint in the
procedure for Top cover.
5 Remove any HP Jetdirect or other EIO cards, and then try to turn the printer on again
Apr 04, 2008 | HP LaserJet 4250n Printer
Flashing lights.. when i turn power off it just does same thing
All lights flashing indicates a "fatal error" condition, so the printer just needs to be reset:
1. Turn the HP c3180 off.
3. Wait a minute, then plug the power cord
back in.
4. Turn the HP c3180 back on.
This should clear the system error and restore the printer to its "out-of-the-box" default settings.
Feb 26, 2008 | HP Photosmart C3180 All-In-One InkJet...
Pulled the chord while the lamp was on. HP vp6310 does not light upanymore
One of the transistor on the power supply is blown. I can repace it.
Dec 07, 2007 | HP VP6310 Multimedia Projector
HP VP6310 Multimedia Projector Logo
226 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
