Question about Cameras
Our digital camera was dropped and the lns is all the way out. it will start to turn on then it gives the message lens error then shuts off
You may have a problem with your lens unit.
Posted on Apr 07, 2008
Sanyo VPC-S1415 lens stuck in camera
that's happen due to physical damage like dropping etc.
try to open inside and align well the lens mechanism
Jul 01, 2016 | Sanyo vpc-s1415 - Vpc-s1415 14.0...
Tip
Lens Error fix for Digital Camera
One of the mostcommon digital camera error messages has to do with a lens problem.Some cameras will just beep and not show any error message and otherswill have an error message on the LCD screen. Some camera's will try tostart, the lens will go out and then return back and shut down.Sometimes nothing at all will happen, but the lens is the reason whythe camera will not start up.
Different camera'smay give you different error codes. Some of the error codes will beE-18 for older Cannon camera's, ACCESS error for Sony, Zoom Error forFuji, lens error restart, or just plain lens error. These are themost common camera error messages, but your digital camera may have a different one.
There are manydifferent things that can cause the lens to give an error message.One of the most common causes is keeping the camera in a case or bag.The dust, grit, felt, and lint from the bag gets into the cameralenses and causes it to jam. The static electric from the camerarubbing the side of the case causes the dirt to be attracted to thelens, which makes the problem even worse. Also if your camera is in acase and the button gets pushed to turn the camera on, and the lenscannot extend it can cause the lens pins to come out of the track,causing focus problems and lens errors. Bottom line is that you areoften better off not keeping your camera in a case! It is saferwithout a case then with one.
The next problemthat many people encounter is that they drop or knock the camera withthe lens out. When this happens, the lens pins can come out of thetrack, and/or the lens can be knocked sideways, which will jam thelens as it tries to extend and/or focus and zoom. If you do drop orbang your camera against something, there is about a 50/50 chancethat it can be fixed. Many times with care the lens can be realigned,but in some cases the jarring or the realigning, will break somethinginternally, so there will be no fix for it.
If your digital camera hasa problem, you will have a couple of choices. You can try to fix ityourself, or you can try to find a camera repair shop that will fix it for you.Because of the type of problems that cause lens errors, the digital camerarepair will seldom be covered under the manufacturer warranty. Alsobe careful to get a quote from a digital camera repair shop before youauthorize the repair. Many times the repair price quoted will be morethen the replacement cost of the digital camera. If you do a search on theinternet for a camera repair shop, make sure to include any shipping andhandling costs in the repair price.
If you choose totry and repair the camera yourself then look for my tip - Steps toRepair a Digital Camera Lens.
This gives you thehow and why of your digital camera error message, and/or why your digitalcamera will/may not start up.
Steps to Repair a Digital Camera Lens
How to easily download Pictures from Digital Camera
How to Unlock SD Card
Digital Camera Manuals, Drivers, Downloads, and Support
on Apr 26, 2011 | Cameras
The camera turns on then shuts back off again
hat type of problem is usually associated with a lens extend error.
It is usually caused by weak batteries or dropping the camera.
Keep your eye on the LCD screen when you turn the camera on.
Do you see any type of error message?
Now turn the camera on again and help the lens extend by gently pulling on the lens as it extends.
Does the camera stay on when you do that?
Sep 24, 2010 | Kodak EasyShare Z740 Digital Camera
Dropped the camera, getting a lens error 115,0,0,212
Lens probably does not extend or retract because of a misaligned gear box. The lens can in about 50% of the cases be repaired without having to replace it. Try to return to manufacturer first. If you're out of warranty, there are third party place that fix them such as camera lens repairs. If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Jul 05, 2010 | Kodak EasyShare C613 Digital Camera
Lens Error. Restart Camera. Camera gives this error message and then shuts off. I can't access photos or function buttons. What can I do?
Press the "MENU" button and navigate to the reset command and reset the camera. That may get the camera to function properly.
May 10, 2009 | Canon PowerShot SD1000 Digital Camera
"Lens error - restart camera" message, but won't restart
I just had the same issue when one of my children drop the camera. I'm not wanting to break anyone's camera but I was able to open the lens cover and pull the lens out and then turning it on it retracted and worked just like it should.
Apr 19, 2009 | Canon PowerShot SX100 IS Digital Camera
Canon Powershot A590 IS GIVING ME A "LENS ERROR, RESTART CAMERA" MESSAGE. I have restarted and the message keeps repeating.
Mine is the same model and it was giving me this same message when I tried to start it up. "LENS ERROR, RESTART CAMERA". It's probably a result of you dropping it. I research it and could'nt find the answer anywhere. I got mad and upset because I use my camera so much and it was not working for the holidays so I hit the lens of the camera on a desk, amazingly I turned it on after I hit t and it started working. I know it sounds a little crazy but give it a try! GOOD LUCK!
Nov 26, 2008 | Canon Cameras
IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
Jun 05, 2008 | Olympus i:robe IR-300 Digital Camera
Lens error No. 221,0,0,0
I have Pentex Optio E 30 camera
When i start my camera , i get error message Lens Error : 221,0,0,0
lens got stuck and it is not coming out for zooming
Sep 06, 2007 | Kodak EasyShare C703 Digital Camera
Cameras Logo
44 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
