Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
Remove connectors off hose
Kenmore Power Mate 11627212790 How do you pop off connectors without breaking them. Should it be this difficult?
  • stupe Apr 28, 2008
    The roller will not turn. The motor still works. I stepped on the button but it did not start the roller. Does it need a belt?
  • Anonymous Mar 31, 2014
    very difficult to remove hose from connector
    President:
  • 1,673 Answers
Are you talking about the hose cuffs? If so, put the cuff in a vise and squeeze it until you see the locking tabs and using flat blades, pry the hose out from the cuff.
Posted on May 26, 2008
Kenmore power mate works intermittently ever since I took it apart and cleaned the sensor. It's like something is now loose with the power connection but I can't figure it out.
Electrical issues can be difficult to diagnose. You have to inspect closely and wiggle wires and connections to determine where the problem is.
Sep 08, 2017 | Kenmore Vacuums
Connectors on Kenmore Power Mate
to take the hose off, you just depress the clip at the end but there is no easy way to remove the connectors off of the ends, it just must get cut out and the new one pushed in and sealed
Let me know if you need any further help
Apr 07, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore vacuum repair
You have to check the AC cord for any break circuit.if you wish to get more derails then check the below added link.
http://electro-medical.blogspot.com/
Jul 04, 2016 | Kenmore Vacuums
Kenmore 25614/25615 Progressive bagged canister vac won't start
sounds like there was a loose connection or loose wire that came in contact with another wire. check your cord for small burn holes, also could have shorted out in the hose or the wand. If you are comfortable to disassemble the vacuum i can walk you through the troubleshooting process so we can find out what actually went bad. id start with the cord though. let me know if you have any questions or need more assistance
Jan 04, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
I have a Kenmore canister vacuum cleaner. The
check the reset button or the wire that goes into the powermate sometimes it frays and breaks
Dec 29, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
I have a Kenmore Canister Vac. I need to replace
Try forcing a flathead screwdriver between the flange (tab) on the hose collar and the tab on the swivel assembly itself, taking care not to gouge the wires. Saw one solution where they used 2 screwdrivers simultaneously; couldn't do that, but did loosen one side at a time.
Sep 24, 2009 | Kenmore Vacuums
Kenmore vacuum model 25614 power mate will not reset
What you see from the outside is usually a pop up button which sits on top of the actual internal switch remove the lid of the power mate as though you are cleaning the brush roll or changing the belt. Then test the reset internally. Post back to advise .
Sep 19, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Change the belt in my kenmore power-mate 120 amps...how to open it to get to where the belt is???
HELLO, JUST REPLACED THE BELT ON OUR'S. FIRST TAKE LITE LENSE OFF THERE WILL BE 2 SCREWS, REMOVE. THEN FLIP OVER POWER MITEON EACH SIDE PRY WITH 2 SCREW DRIVERS WHERE THE ARROWS ARE TO SEPERATE & THERE IT IS THE BELT. MIKE
Sep 13, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
152 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
