Question about Acer Aspire 5610-4648 Notebook
Screen going black
My screen went black but it flickers back on when i turn the power on or open the laptop
ive had my laptop for only a month when it did this
    Scholar:
  • 119 Answers
Get a strong flashlight and shine in at at angle toward the screen.
If you can see the image, which you probably can, then your laptop's backlight is malfunctioning.
Since you've only had it for a month, check with the retailer or manufacturer to see if it is still under warranty. Hopefully it is and you can get it replaced.
But before you send it back, if it has a DVI, HDMI or VGA port on it (most likely it does, unless it's an ultra-slim model), connect a PC monitor to it and turn it on. You may have to press a certain key combination like Fn-F4 or Fn-F8 to switch between the laptop display and external display, but hopefully the screen will display on the external display.
From there you can use your laptop as necessary to back up any data that you need before you send it in for service.
Posted on Apr 07, 2008
SOURCE:
Screen goes black
reboot using the key HOLD the key CTRL +F11 OR F12 depend of your computer model use restore factory default. or reboot using disck or USB.
Other wise restart HOLD the key CTRL+F8with network, and use the CHKDSK command for repair.
God bless you
Jun 23, 2013 | Toshiba Satellite P305D-S8829...
Laptop screen flickering
The video inverter may be failing, BUT...
More than likely the backlight is failing. If you can still see a VERY faint image on the screen this is almost certainly the problem.This is a very difficult fix. I recommend a replacement LCD.
It MIGHT be a bad lcd cable. With the laptop on, slowly open it from closed to open and back again and see if there is a position where the laptop screen does not flicker or turn off, [or if it does turn off if it turns back on.
If the screen goes COMPLETELY black then your GPU is failing.
Feb 21, 2012 | HP Computers & Internet
Screen went black...rebooted, computer seems to
Remove the battery and disconnect the power adapter for about a minute.
connect only the AC then boot it back up. If you can see the Compaq splash screen and still unable to load Windows, re install OS.
If you could not see the splash screen, too bad it could be a motherboard issue,
Hope this helps.
Dec 21, 2009 | Compaq Presario CQ60-220US PC Laptop
Dim and flicking last black screen
It sounds like your monitor went bad. It happens. Call around. There are a lot of deals now. Good luck.
Aug 04, 2009 | ViewSonic VX1940w LCD Monitor
HP pavilion notebook screen turns black after flickering
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 01, 2009 | HP Pavilion DV5Z PC Notebook
Monitor went black
This is a very common problem,
Most monitors go due to the connection, for example when you open and close the lid this loosens the connection so this is your problem.
You may be able to find and download the service manual on google, and take it step by step from there or take it in for a service.
hope this helps
alex
Apr 06, 2009 | Toshiba Satellite L305D-S5904 Laptop
Acer Laptop Screen Flickering
The flickering screen indicates that it is a backlight problem with either a faulty inverter or inverter connection problem. The inverter is usually located at the bottom edge of the LCD screen, and may have one or two connectors (one for the video info. and one for the inverter power or a combined connector) attached to the motherboard under the case near the top edge of the keyboard near the hinges. Reseating these connectors may solve your problem.
Jan 29, 2009 | Computers & Internet
My Ibm T22 wont boot up
Try removing the battery and unplugging the computer. Then put the battery back in and plug the computer in and turn it on.
Jan 08, 2009 | IBM ThinkPad R51 Notebook
Blank/black screen
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
5
Oct 12, 2008 | Toshiba Satellite A55-S106 Notebook
Acer Aspire 5610-4648 Notebook Logo
95 people viewed this question
Ekse
Alun Cox
