LCD television (Magnavox 26MF231D/37) is turning on and off on its own, with picture going out in such a way that the images disappears then grey lines appear across screen and loud sounds come out of the audio. After this, the tv turns off.
  • Anonymous Nov 20, 2008
    My exact Tv is doing the same thing. It gave us trouble for a while ... then after about 2 years would just show the green light and then never go on..
    I was told it is an ssb board.........$350 dollars to fix...........
    I think this part was defectively designed...........
  • ufon1 May 11, 2010
    my magnavox 26mf231d/37 display menu stays on constantly. how do i fix this problem
    Problem Solver:
  • 13 Answers
I have the same problem.
and so do MANY others:
another fixit post tells you to remove the back and take off a metal part:
This is the older brother: A lot of the reviews describe your very problem.
Magnavox should do something about this!
Posted on Dec 26, 2008
  • German Isales
    German Isales Mar 18, 2011
    Ufon1 I have the cure for the problem im a technician since 1990 and i also have the same lcd.
    Is an easy fix no need to buy another board. The main board has a small but anoying problem which the set turns itself off.
    If you want the know how instructions emaill me and i will send you step by step and pictures as to what part it is and location on the board.
Manavox tv won't turn on after power outage
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Philips 26MF231D 26 in. LCD Television
My magnavox 26mf231d/37 won't turn on
look it would be best to at least get a "Quote" from a reliable place for a fix, then you can at least make an informed decision.
Jan 31, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
My 2 year old Magnavox 37MF231D/37 LCD TV just blew the picture screen. The audio comes through fine, but the screen is dead black with no menus, info, nothing. I tried various inputs, same result. I...
The problem can be in the backlight inverter board (hard to get to), or the main power supply module may not be working. Look at the power supply first since it is easy to get to, look for burnt parts, bad capacitors.
Nov 11, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
Picture black & white menu color #26mf231d/37
I have the same problem too. Need a fix. This tv isnt that old and is not used that much. does not seem to be the cables or cable box. the menu has color to it but the channel picture is in black and white, flickers a bit, and seems to be in a very large pixle form. it this able to be fixed? Please Help.
Nov 10, 2009 | Philips Magnavox 27MS343S 27" TV
I have a magnavox 26MF231D/37 lcd tv. It has good sound but no screen, just black. Turn it on and off aqnd it doesn't flash no anything. thanks
Either your inverter board or video board is bad. If you can see picture while the TV is on then its your inverter board. If not, video board.
Nov 05, 2009 | Philips 26MF231D 26 in. LCD Television
Magnavox Philips 26MF231D 26 in. LCD Television wont turn on. The green power light is on but unit does not work; it won't power on or off using the power button, and screen remains black.
Most likely you have defective capacitors in the Power Supply. It is not an expensive repair but something that needs to be done by a svc. co., if your not familiar with Switch Mode Power Supplies (SMPS). I hope this helps and Thank You for using FixYa.. Let me know....
Mar 10, 2009 | Philips 26MF231D 26 in. LCD Television
32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
Jul 04, 2008 | Philips 26MF231D 26 in. LCD Television
Tv damage
It sounds like u have a damaged lcd panel. When your panel gets like this there is not much u can do to fix it. It will be cheaper to get another TV than to order a replacement panel. If your bought the service protection plan you can get it replace no problem but if you didn't. There is not much you can do for it.
May 02, 2008 | Philips 26MF231D 26 in. LCD Television
Televison & Video Logo
627 people viewed this question
Top Televison & Video Experts
