Question about GPS
My garmin gps 350 keeps losing satelite. Can you tell me how to fix it? Thank you!!!
    Scholar:
  • 119 Answers
GPS requires line-of-sight and generally uncovered skyline. It won't work so well in forests or in between highrises and such.
However, there are a few things you can do to help get better signal.
  1. Move the GPS closer to the windshield.
  2. If you have an external antenna (one that can be moved without moving the unit), move it closer to the windshield, or if it is magnetic, put it on the top of your roof.
  3. If your GPS model has the option for an external antenna but you do not already have it, you may want to consider getting the external antenna. It'll let you position the antenna somewhere better without having to put the GPS unit itself in an awkward or inconvenient position.
Posted on Apr 07, 2008
SOURCE:
My garmin e trex vista keeps telling me acquiring satelite for 1 month now. What's the problem and how do I fix it?
have you tried moving it to another location?
does it have an internal or external antenna..either way give it a good view of the sky..
May 29, 2012 | Garmin GPS
GPS Firmware Upgrade Popup
Easy problem to repair. Please see this link for repair assistance.
http://www.sharc.net/gps_antenna_repair.htm
- Jim
May 28, 2010 | Garmin nuvi 350 GPS Receiver
My Garmin Nuvi 350 does not aquire sattalites?
Make sure it is in its mount. The antenna is in the mount and needs to be connected tight also make sure You have a view of the sky and not parked in a garage that blocks the signal
Oct 28, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 350 satelite lost
Try flipping the back part up.
Jun 20, 2008 | Garmin nuvi 350 GPS Receiver
Garmin GPS problem
I have a 276C that has the same problem. Garmin has a unit with this problem and is working on a solution. The problem is that the real time clock loses time when the unit is turned off and disconnected from a power source. As a result when you turn on the unit it thinks the satelites are in a different orbit than where they actually are. The unit will continue trying to aquire forever and not find the satelites. You have to select "New Location" from the menu and select "Autolocate" and the unit will start to look for any satelites in view. The unit should get a fix within 15 minutes. This is a very frustrating problem having to reset it every day. There is a new version of firmware (5.3). I don't know if the problem has been fixed with this release.
Jun 15, 2008 | Garmin GPSMAP 276C GPS Receiver
Garmin gps, novi
What do you see if you use it in the open air? Same thing?
Some cars have a metal coating on the windows that works as a sun block, usually french cars. In these cars satellite reception is poor and this can be a reason for bad reception. Sometimes these problems also occur when a cell phone is too close to the gps. The gps does need line of sight to the sky to get a good signal, usually stuck to the windshield is sufficient.
Apr 04, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 GPS will not find sattelite
I GARMIN KEEPS SAY MEMORY IS FULL HOW DO DELETE IT
Feb 12, 2008 | Garmin nuvi 350 GPS Receiver
Garmin 360
have you ever updated the firmware (webupdater @ www.garmin.com)?
Dec 12, 2007 | Garmin nuvi 350 GPS Receiver
Open Questions:
GPS Logo
44 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
