Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
Washed cigarettes in machine
I have just done a load of laundry and seem to have washed a packet of cigarettes in the machine. the clothes are now covered and the machne is producing tobacco when i fill it with water. how can i get to the filter to unclog it?
    President:
  • Kenmore Master
  • 2,651 Answers
No real filters to clean , your gona just have to run through a few loads empty to rid yourself of the mess. ittl clean itself out , youll be fine
Posted on Apr 07, 2008
SOURCE:
I have an IQ touch front load washer. lately I have noticed a mildew smell coming from the clothes and drum after washing. i have followed the manual and completed the refresh and comlete cleaning...
Water can remain in ANY washer after the load is done. With a top-loading washer, it's easy to leave the lid up so that the water evaporates. With a front loader such as yours, however, the open door can take space in your laundry area, so we usually close the doors. I suggest that you take a dilute solution of chlorine bleach and water and put it on a disposable cloth and wipe down the inside of your washer as well as the areas around the door itself and the part of the washer that the door closes onto. Once you've done this, leave the door open until the smell dissipates OR overnight. If you will get into the habit of leaving the door open for a couple of hours after you're done with your laundry, you will probably solve the problem.
I really hope this helps. If it does, please come back to Fixya and rate my solution.
Jul 09, 2011 | Electrolux Washing Machines
Machne not spining fast enough to dry clothes, clothes still very wet after spin cycle.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 19, 2011 | Washing Machines
Clothes are dirtier after washing...
The problem with your front load washer is a broken rear bearing. If you remove the rear panel, you will see brown "gunk" all over.
If you want to repair it on your own, order this:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-GLTF1240AS0-%3d%3di407639&PartID=407639
Good Luck!
Feb 01, 2009 | Frigidaire GLTF1240A Front Load Washer
go to your local appliance store and ask for "Affresh" washer cleaner. works excellent. If hubby need to get into the machine have hime clean out the pump. You probably have **** in there thats also contributing to the problem. good luck
Jan 26, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
3,573 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
