Toshiba A205-S4607 - After windows loads the display goes blank
When I reboot the system loads the windows drives(I have he no-gui option on startup) and then instead of the Windows logon screen come up the screen stays blank. I am running Windows Vista Home edition with SP1.
any ideas? I have rebooted several times no errors. Any help would be appreciated.
I have the same problem. If I use the driver disc and let it re-image the hard drive, the error still occurs. I'll try the BIOS patch and see what happens.
Posted on Jun 12, 2008
  • 77 Answers
If you have the recovery DVD, try reinstalling your system.
Posted on Apr 07, 2008
Why can't I turn off safe mode?
If W10, Go to the Shutdown menu, and hold down Shift as you select Restart.
Select Troubleshoot > Advanced options > Startup Settings > Restart.
The computer will reboot. But instead of loading Windows, it will bring up a Startup Settings screen with all sorts of options. Press Enter "to return to your operating system."
Feb 04, 2018 | Computers & Internet
Tip
Quit the Registry Editor and log off
Automate the above task using this utility
This tiny utility provides you the option to choose a color from the Color Picker dialog and can reset the logon Wallpaper if you want. Choose your preferred Color and click Apply Background color. Remove Logon Screen wallpaper option clears the logon
How to disable the Windows XP Splash Screen / logo at startup ?
To disable the Windows XP splash screen (logo) at startup, and to see the list of drivers loading at startup, follow these steps:
Click Start, Run and type MSCONFIG
Click the Boot.ini tab
Under Operating Systems section, select the appropriate entry and then enable the /SOS switch in the Boot Options section below
Click OK and close MSCONFIG utility.
The corresponding entry in the Boot.ini file is automatically added. Example given below:
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect
becomes
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect /sos
The /sos parameter displays the names of the drivers as they load during the boot process. Use when startup fails (while loading drivers) to determine which driver is failing to load. See Boot Parameter Reference for more information.
Also see /noguiboot parameter, which can also disable the splash screen.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
My nextbook keeps rebooting after an update and Windows doesn’t load. How can I fix?
  1. Insert a Windows 10 or Windows 8 DVD or a flash drive with the Windows installation files on it, into your computer.
    Tip: You can borrow someone else's Windows 10 or Windows 8 disc (or other media) if you need to. You're not installing or reinstalling Windows, you're just accessing Advanced Startup Options - no *********** or license breaking required.
  1. Boot from the disc or boot from the USB device, whatever your situation calls for.
  2. From the Windows Setup screen, tap or click Next.
  3. Tap or click on the Repair your computer link at the bottom of the window.
  4. Advanced Startup Options will start, almost immediately.
  5. Select system restore and press suitable restore point created before windows update and go next to restore the system
Nov 03, 2017 | Computers & Internet
Windows 8 wont recognize datel game controller
Try this Access Startup Settings When the Choose an option screen appears, click or tap the Troubleshoot tile.
Next, click or tap the Advanced options tile.
Select the Startup Settings tile on the Advanced options screen.
Click the Restart button on the Startup Settings screen to reboot your computer again.
Disable Driver Signature Enforcement On the Startup Settings screen, tap the F7 or 7 key on your keyboard to select the "Disable driver signature enforcement" option.
Windows 8 will immediately boot to its typical lock screen. Sign into Windows 8 as you normally would - everything will look the same, except Windows will no longer demand driver signatures until you next reboot.
You can now install unsigned drivers as you would on previous versions of Windows. Windows will alert you if you try to install a driver that isn't properly signed, but you'll see an "install this driver software anyway" option you can choose.
Reboot When you're done installing the unsigned drivers, reboot your computer. Windows will keep using any unsigned drivers you've already loaded, even as it enforces signature requirements for new drivers.
Nov 15, 2013 | Datel Xbox 360 Turbo Fire 2 Wireless...
F9 doesnt work on asus a52f just says windows 7
You might try the Delete or all the F function keys also some computers use cntrl +alt +delete
http://download.cnet.com/%7Bvalue=http://www.download.com/keyfinder-thing/3000-2094_4-10491989.html Finding lost application install keys is quick and simple with this handy executable, a complete rewrite of a well-received earlier version.
Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer." If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options.
Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option. g) At the DOS prompt type the following three commands: bootrec.exe /fixmbr bootrec.exe /fixboot (may return an 'Eliment not found' message) bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window.
Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
Hope this helps. Keyfinder Thing's simple, easy-to-understand interface has Wizard-like efficiency. This application quickly scans your system registry for 90 supported software titles and displays product names and icons in the result window. Single-button clicks copy all keys to either a text or HTML file. b> http://download.cnet.com/product-key-finder/3000-2094_4-10694022.html Product Key Finder is a single function utility that executes in a GUI, but displays a Command window result. You merely double-click it to display the 25 character Microsoft Windows Product Key. then store it away for safe keeping not on your computer
Dec 08, 2012 | ASUS A52f-xe4 15.6" 2.13ghz 4gb 320gb...
I need to find a set up disc
What operating system set up disc are you referring to ?
bootrec.exe /fixmbr
http://windows-xp-pro-startup-disk.soft32.com/free-download?gclid
windows xp pro start up disc
http://systemdiscs.com/?utm_source=neosmart&utm_medium=article&utm_campaign=Vista_Recovery
vista recovery disc
Hope this helps.
Nov 20, 2012 | Computers & Internet
System disks startup
bootrec.exe /fixmbr
hope this helps
Nov 12, 2012 | Acer Aspire X1 Ax-1430g-uw30p Slimline...
Pc is in a startup loop - boots up to windows icon - begins to load windows then bangs out to ''RGB No Signal'' before going into startup routine again. Will not even start in safe mode or any of the other...
I would boot the Windows XP CDROM and select repair and continue to the recovery console. logon with administrators password (usually blank) and it drops you at a dos prompt where you type chkdsk c: /p and press enter. If chkdsk runs, allow it to complete then reboot.
Jan 20, 2010 | Computers & Internet
Black screen before logon screen and before Vista Orb.
try recovery console enviroment using your your windows vista cd while booting in cd go to repair then it will repair your windows or go to recover to last working state or go to command prompt then type this SFC this will look for corrupted system file and try to recover it still . you can search it to google how to do it
or
try reformat your hardisk then install a fresh windows install
hope it solve your problem
Jul 09, 2009 | Microsoft Windows Vista Business Edition...
Pssword lock out
If you still can't find the solution try this thread: http://www.fixya.com/support/t156781-forgot_administrator_password
Oct 09, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
371 people viewed this question
David Payne
David Payne
