Question about Roland Vs-2000CD Digital Studio Workstation System
Roland vs 880 help - it is frozen in CD back up mode - if I turn off I lose 8 hrs of recording - I turned off CD burner and it is just frozen HELP!!
  • Roland vs 880 or BR-8 ; Could this machine play more than eight tracks at the same time?...how?
Posted on Apr 08, 2008
SOURCE:
ROLAND 2480 RECIEVE ERROR MESSAGE SUB SYSTEM NOT RESPONSE
This means the low-level part of the operating system is corrupted or missing. Simply try reloading the OS by putting the CD into the CD drive. If it does not allow an OS reload or if it fails, most likely the flash ROM which holds the basic part of the OS has been zapped and will require service. You can also try to replace the internal button battery inside that retains the memory.
Aug 24, 2012 | Roland Vs-2480 Digital Recorder Loaded...
My recording studio is stuck on the project load screen
Your VS-2000 is showing symptoms of fragmentation--resulting in the unit freezing or failing to completely load. The only possible solution is formatting the hard drive. Formatting erases all data on the drive.
Note: If you have any files that you need to keep, you may contact our Roland Customer Support department (323-890-3740) to arrange a "Data Recovery" service. Our service technicians can attempt to recover any data that is in your hard drive. Customer Support is available M-F 8:30am-5:00pm Pacific time.
CAUTION!!! Formatting the hard drive erases ALL recordings and data on the drive. This includes any installed plug-ins as well. Be sure to back up all of your project data (recordings) and plug-ins to CD/DVD(s) before formatting the drive.
Unlocking the System:
1. With the VS-2000 powered off, press and hold the TRACK/STATUS button for track 4 and the FX 2 button.
2. With both buttons pressed, turn on the VS-2000's power. Continue holding the two buttons until the display has loaded completely. This can take several minutes.
3. Once the system has loaded completely, release the buttons.
Formatting the Hard Drive:
Note: The format steps below pertain to using the VS-2400's on-board LCD screen. If you're using an external VGA (video monitor), press and hold HOME and press F6 to switch to the on-board LCD.
1. Press SHIFT AND F1/PROJECT.
2. Use the CURSOR buttons to Select "IDE:0".
3. Press PAGE until "FmtDrv" is displayed above F2.
4. Press F2.
5. CURSOR to "Physical Format".
6. Turn the TIME/VALUE dial until "ON" is selected.
7. CURSOR to "Surface Scan".
8. Turn the TIME/VALUE dial until "On" is selected.
9. Press F5 (OK).
10. Press ENTER/YES twice.
Oct 13, 2011 | Roland Vs-2000CD Digital Studio...
When I turn on my roland vs 2480 it never makes it past the load project start up screen. What can I do? please help
moz-screenshot.pngHave you tried to do a factory reset?
Hold SHIFT and press F4 (Utility). Press PAGE to get to page 3. Press F6 (PrmIni). Press F5. Press ENTER/YES
Dec 03, 2010 | Roland Vs2400CD Digital Workstation W/CD...
Play-back on Roland VS 2400CD. Tracks recorded no signal or sound
There is an instruction DVD for the VS-2400CD. It is very helpful.
I couldn't have ever worked this board without it. Here's where to buy it;
http://www.amazon.com/gp/product/B000BSEUYI
Apr 01, 2009 | Roland Vs2400CD Digital Workstation W/CD...
Roland VS2000 Doens't load project after power accident
turn it on and just let it load..it may take like 20 hrs or so but it will come on...and yea when it does you might not have anything that you had on there but you can start over and it will work like new..worked for me
C.D.
Mar 19, 2009 | Roland Vs-2000CD Digital Studio...
Load Screen Freeze w/ Roland VS-2400
The hard drive needs to be replaced. You can contact their customer service as to how to do this. It is relatively pain free and inexpensive as well.
323-890-3741
Mar 19, 2009 | Roland Vs2400CD Digital Workstation W/CD...
[email protected] My Roland VS 880
that would depend on where you are located in the USA doesn't fix ya have people who do repair work in another section.?
May 27, 2008 | Roland Vs-2000CD Digital Studio...
Mono instead of Sterio
Make sure you are panning hard left and hard right before you export the track. Why don;t you use the roland interface and bypass the mac all together.
Mike
Jan 15, 2008 | Roland Vs-2000CD Digital Studio...
Roland vs 2000cd studio workstation/harddisk recorder.
I have figured out a way to get around this problem without losing your data or sending it to Roland. I have three roland 2480s and have 4 hard drives. Buy another spare drive and when you load up to a different IDE drive shut it down, then put the old drive back into the unit and it will boot from the last known ide. Make sure it is not the same IDE # that was giving you the problem. You will get at your files but you better start to backup and defrag. I will not delete files on my roland unless I am willing to defrag. Buy an extra drive from a third party. You can see a company that sells this stuff on ebay and they are very good. "VS something store."
Aug 10, 2007 | Roland Vs-2000CD Digital Studio...
Roland Vs-2000CD Digital Studio Workstation System Logo
618 people viewed this question
Top Roland Audio Players & Recorders Experts
Ekse
Mike Duncan
Mike Duncan
Jerry Greenberg
Jerry Greenberg
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
