Because a freezer only does one thing and that is freeze things, unfortunatly any things that breaks on a freezer causes the same thing. Is it running, does the fan work (frost free) are the shelves melting (non frost free) can you hear the compressor running , is the condensor fan running ?
Do you hear the compressor running? If so, can you feel that side of the unit being hot? If so, you need a professional to diagnose the sealed system very soon. If it is not hot, then it sounds like a restriction in the coolant lines. Still need a professional.
this is normal until all the freon has had a chance to get recirculated throgh the system.
make sure the evaporator fan is also working in order to properly cool the freezer.
look at level side to side , and front to back. if not level door can leak . you will see water where it is leaking. check defroster is if staying on .
Hi, It sounds like the defrost drain is plugged. UNPLUG the freezer. Remove the rear panel and you will be able to find the drain hole and remove the ice. Once you get the iceout of the drain. try and fluxh it with hot water (A baisting serigne works great). Sometines they plug up with duse from underneath. I hope this helps you. Please let me know if I can assist you further.
The condenser or high side is built into the side walls on these modern freezers and refrigerators in many cases. It is normal for the outside walls to be hot when the unit is working. Frost on the inside of the sealed packets of food is from the moisture content of the food. Running the temperature setting to cold will accelerate the moisture freezing to the inside of the food packets. This also is a normal condition.
the condenser coils of the freezer anre inside the case of the freezer, they are suposed to be hot they are removing the latent heat from inside the freezer to make it cold, no heat transfer no cooling, you will notice the high heat temps a lot of the time after adding food to the freezer or when you just have started it after being turned off for some reason it is fine
