Question about Philips Magnavox Learning Universal Remote
Programing philip universal remote to my tv
I have a philips universal remote. I am tring to program it to my Phinsonic tv. I just need instructions on how to program it by using the up and down buttons.
thanks
  • Anonymous Mar 29, 2014
    When I follow instructions my tv turns off and the red light on the remote stays lit and the tv will not turn on
    Champion:
  • 207 Answers
You can find the instructions here. Just follow the step by step instructions to properly select model of your Phillips remote. http://www.urc.philips.com/
Posted on Apr 10, 2008
SOURCE:
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
Lost the remote to my philips HTL2101A and it has no power button, so i can't use a programmable remote.
It should still be possible to use a universal remote to power on your TV.
Some universal remote instructions will say that the device has to be turned on in order to properly program the remote. This is not necessarily true, and you should still be able to use the universal remote to find a preset that will at least turn your TV on so you can then follow the instructions for the remote to find the exact preset that will work with every button on the remote.
First, look in the instruction booklet of the universal remote for the section of preset codes. It should be a huge list of 3-5 digit numbers with corresponding device names. There should be at least one or several for Philips devices. Find the code that matches your device.
Then, follow the instructions to program in that code. Should be something like: Hold down a certain button until the light on the remote blinks. Enter the code. Press another button to program the remote for that code. Keep in mind every universal remote is different and will have different steps to follow, but all generally work the same way.
At this point you'll want to just try the POWER button on the remote. If your TV turns on it means the code you entered is the correct code, or at least close to the right one. If it's not the exact correct code some of the other buttons won't work or will command your TV to do the wrong thing.
If your TV does not turn on with the first code you tried, you will need to program the remote with on of the other Philips codes. Just follow the same instructions you used to enter the first code and try another one from the list. Try the POWER button with each of the codes used until the TV turns on.
If none of the Philips codes work you will need to follow the universal remote's instructions to cycle through all of the codes (I have had to do this before). There should be another section of instructions that tell you how to do this. Again, try the POWER button for every code until the TV turns on. Once the TV is on, you will want to follow the instructions for the remote as normal to find the exact code preset that will work correctly with your TV.
If all else fails you might want to purchase a remote that is at least newer than the TV you are trying to operate because an older universal remote may not have the correct preset for a newer device.
I hope this helps! Good Luck!
Dec 15, 2015 | Philips HTL2101A/F7 40 Watts Sound Bar
I have a remote contorl universal philips .i'm tring to makc my citezen tv work lost instruction manual serial numb 50804225
Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
CITIZEN .... 002 112 402 407 502 512 701 805 906 319
Please rate this solution. Thanks.
Aug 24, 2009 | Philips SRT9320/10 Prestigo 20-in-1...
You don't need the serial number, yo need to look for the model. Once you have it, here are most of the manuals for Philips remotes.
Aug 24, 2009 | Philips Prestigo SRU8008 - Universal...
Programming instructions
HERE ARE THE CODES FOR Philips TV. 1005, 1008, 1014, 1039, 1064, 1079, 1082, 1086, 1099,1104, 1106, 1115, 1116, 1123, 1149, 1150, 1153,1154, 1157, 1185, 1186, 1203, 1246, 1295, 1312, 1313, 13511157, 1185, 1186, 1203, 1246, 1295, 1312, 1313, 1351
Mar 31, 2009 | RCA 6-Device Universal Remote
Hello
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
May 09, 2008 | Philips Universal PH301S Remote Control
I need codes for philips universal remote control
lost manual tring to hook up dvd/vcr emerson up need code
Apr 24, 2008 | Philips Universal PH301S Remote Control
Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Feb 03, 2008 | Philips Magnavox Learning Universal Remote
Philips Magnavox Learning Universal Remote Logo
965 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
