Question about Olympus Camedia C-8080 Wide Zoom Digital Camera
Zoom stuck on C-8080
The outer mechanism that allows you to zoom in on your subject was VERY tight at one point. The next time I used the camera, that mechanism was stuck. Because I use this camera infrequently and am not willing to spend a lot of money to send it away to see what the problem is, perhaps someone can give me a tip on what to do.
  • Anonymous Apr 20, 2008
    Hi I have a simular problem with the zoom. The camera was dropped on the lens onto grass and ever since the zoom dosn't work properly making a grinding noise when you try to zoom.
    I though of taken off the lens to see what had went wrong but don't have a clue as tohow the lens come apart from the camera.
    Can anyone help. Mark.
Hi Pishta68 my email address is [email protected]
Thank you for your reply.
Hope you can help.
Regards Mark.
Posted on Apr 27, 2008
  • 594 Answers
The lens is DEEP in this camera. I have one that I am taking apart right now to get to an image sensor. Email me your address so I can correspond directly about the insides of this tank.
SOURCE:
What is the difference in the optical and digital zoom?
Find the difference below
Digital Zoom
1. Digital zoom is a part of digital cameras, and camcorders, which helps to crop the entire image, and then digitally enlarge the size of the viewfinder of the portion that is needed to zoom in on
2. Digital zoom crops the image down to a centred area with the same ratio as the original, and also interpolating the result back up to the pixel dimensions of the original. this method involves cropping, hence the resolution and quality is reduced
3. Digital zoom, crops a portion of the image and then enlarges it back to size. And due to this, image quality is reduced in comparison with the original one.
4. Using the digital zoom allows the user to get closer to the subject when the photographer wants to be discreet about taking pictures, like taking a picture of a person in a graduation ceremony.
Optical Zoom
1. While taking a picture using a Camera to want to get a close shot of the subject without moving physically closer, photographers use the optical zoom.
2. The optical zoom ratio of a digital camera measures how much the lens can actually zoom in to make subjects appear closer. Optical zoom, enlarges a picture while keeping the resolution and sharpness of the picture high.
3. There is no relation between optical zoom and the resolution of the photo, as optical zoom only enlarges the whole image or the subject to a certain range. So image quality only depends upon the mega pixel (MP) of the camera
4. Optical zoom is very useful, while taking a picture of a landscape, or to get a closer view of a subject, without reducing the quality of the entire image, like taking a picture of a Rainbow in the sky.
Regards,
Ron
// Rate the solution with 4 thumbs up if the answer is satisfactory
Jul 01, 2011 | Nikon Cameras
Sony lens 18 - 70 got stuck and it is unable to zoom
Due to the tight tolerances inside the lense mechanism - small bits of sand or lint may become trapped in the mechanics.
It is advised to take the camera to a camera repair shop and have it disassembled and cleaned.
There are many small parts and intricacies that will render it totally useless if not done properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 29, 2010 | Sony Alpha DSLR-A200K Digital Camera
Pentax espio 140
subaru662,
can you see the lens in the finder move when you zoom out? if not ,the finder lens is stuck.
if it does move when zooming, see if you have a diopter adjustment wheel or sliding knob near the front lens of the finder. if so adjust the lens to your eye.
Jun 28, 2008 | Pentax Espio 140V 35mm Point and Shoot...
Olympus 8080 C 8080 wide zoom
It may have jumped a tooth, something like a car timing chain. The Zoom in this camera is a barrel that has 3 cams that rides inside another barrel that has "tracks" for the cams. The motor rotates the the outer barrel via gear teeth, forcing the inner barrel to extend or retract. There is a tab on the gear teeth that might index the position of the zoom lens. If this tab is in the wrong position, if the gear jumped a few teeth, the camera may not know where the zoom lens is in relation to the inner focusing lens, and cause the "zoom error" If that is the case, I can help you get it back into position. This is a theory, but does explain the tab on the gear and the constant zooming.
May 27, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Zoom
Lens probably got off its track. you need to take the front case apart and pull out the 3 lugs at the base of the outer lens. YOu should ba able to manage to get the outer lens off, dont worry about breakin git as the stuff is made of heavy plastic. If you get it off, see if the inner barrel rotates smoothly. YOu will be actig on a small motor so youll feel a little resistance, but it should be fairly easy to rotate. Lube the helical tracks with heavy white lithium grease and put the outer lens back on making sure to align the tracks, press the lugs back in and reassemble. worth a shot. I did mine and was successful. See my folder on the C8080 http://picasaweb.google.com/pishta68/8080lens/photo#5199141246863292738
Apr 24, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Zoom lever (Olympus Camedia C-8080 Wide Zoom Digital Camera ) does not work
If you can get to the ribbon cable that the zoom lever is attached to, you can use a multimeter or a continuity tester to see if the lever is actually shorting any traces on the ribbon. the zoom lever acts upon a motor that rotates the iner lens barrel, possible the motor lead is open or the switch under the lever is dirty/faulty.
Oct 21, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Connect an flash and aftermarket bracket
When using an external flash with the C-8080 Wide Zoom, you will need the appropriate flash cable with your flash and aftermarket bracket. The Hot Shoe Flash Cable (FL-CB05) mounts to the C-8080 Hot Shoe and the opposite end attaches to the aftermarket flash bracket’s flash shoe or to a standard tripod attachment thread (1/4x20).
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
PictBridge
PictBridge is a specification announced by six private companies: Canon, Fuji, HP, Olympus, Seiko Epson and Sony, in December 2002. Its aim is to allow for direct printing between various brands of digital still cameras.
AF Illuminator
The AF illuminator allows the auto focus system to focus on dark subjects. When the shutter button is pressed half way, the AF illuminator will light up the subject. The default setting is “ON”.
IESP auto focus
iESP is the default auto focus setting for the C-8080 Wide Zoom camera. It uses a contrast detecting system to analyze the entire image by comparing the subject against the background to achieve focus. When the shutter button is pressed half way on the C-8080 Wide Zoom, the AF target mark automatically moves to an area of the image where it finds the optimal contrast.
Olympus Camedia C-8080 Wide Zoom Digital Camera Logo
117 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
