Question about Ovens
Hotpoint stove timer replacement
I am replacing the timer (WB19X5306) with WB19X10006 on a Hotpoint stove RS647G0J1BG about 19 years old. The instructions don't show the connection on this old timer. The old timer has 2 white wires connected on one corner and a red and white/red wires connected on the opposite corner. A pink wire is connected diagonally to the white wires. Please tell me how to connect the old wires to the new timer. Thanks!
  • 2 more comments
  • Gatorfan5 Apr 07, 2008
    The new timer came with white wire extentions, the new timer just has 5 terminal male connectors. Thanks
    The new timer doesn't have the connections in the same place.
    The new timer came with only wire extensions and were not attached. I have the new diagram but it doesn't have wire color connections just Output 1, Output 2, L1, L2 and neutral. The diagram for the old timer is not the same as shown in the enclosed instructions. This is my problem. Thanks!
    Can I blow the new timer by connecting the wrong wires?
  • 3,037 Answers
What color wires are on the new timer?
Posted on Apr 07, 2008
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri Apr 07, 2008
    the timers will wire up exactly the same way though you may have to work with the male connectors. As long as the wires from the same corners go to the same spots on the oven you should have no problems with this unless you don't remember the exact configuration which I can find for you
    let me know if you need more help
  • Benjamin Patri
    ok, do any of the wires have any color besides white on them, perhaps a line running down them?
  • Benjamin Patri
    well the neutral or ground goes where the pink wire was and the L1 and L2 wires go together and the outputs go together
    So try the connection with the L1 and L2 in place of the red and if that doesn't work then it would be the other way around
  • Benjamin Patri
    it shouldn't, it will just be having the power run backwards
SOURCE:
Old timer wood stove manual
I need to find a owner manual for an old timers wood burning stove insert or at least how to replace the fire bricks
Jan 07, 2014 | Ovens
How does one set the clock , timer, cleaner on a GE oven that has a WB19X10006 Electronic Oven Timer
http://genet.geappliances.com/search/search
Here is a link to the GE appliance help page. I believe you will find solutions here for all your settings.
Mar 16, 2011 | GE Profile JTP56 Electric Double Oven
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Hotpoint self-cleaning oven will not release door latch and open.
no you will have to replace the catch if its more than 20 years old maybe you should think about buying a new oven
Sep 27, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Amana gas stove acf3325ac f2 code
HI The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
PLEASE RATE IT............................
Nov 16, 2008 | Amana Ovens
Oven not heating to proper temp
go to: RepairClinic.com
you'll need make & model #.
Nov 16, 2008 | Frigidaire Ovens
Hotpoint stove fuse confirguration
Remove the old ones ONLY if you know what you are doing, and take them to the parts place with the modl # and serial # found on the tag plate!
Sep 06, 2008 | Hotpoint Ovens
Oven does not work
check ignitor oven if shorted, replace it. or the ignitor safety valve see if the harness wire is broken or burnt. replace it.
let me know if you try these component.
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
Stoves Newhome GL916
The timer has broken and needs replacing
I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
Hope this helps
Cost of timer from stoves £56.83 inc vat and delivery
Oct 28, 2007 | Ovens
Ovens Logo
244 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
