Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
My hoover floormate leaks continuously
I guess I shouldn't be complaining, because at least I can still use my scrubber. But after reading all the different problems, I too have noticed that besides the leaking, it seams like my scrubber is not getting the floor as dry as it use to and that the reservoir does not fit like it should. Is this just coincidental or a defect that the manufacturer is aware of and has some suggestions. If it is a problem that can be fixed with some new "O" rings please let me know where I can purchase them.
SR
  • cgpeters Mar 26, 2009
    gasket around the little intake that fits into the solution tank is wore out and causes it to leak continually
  • tpomy Mar 28, 2009
    My H3000 floor mate leaks continously. I think I am missing the O ring that sits on the vacuum opening at point where the clean water tank makes contact with the vacuum. I talked with a vacuum store and they claimed they did not see an O ring at this site, which does not make sense to me as there is the perfect little divet for an O ring. I did buy an O ring from Ace Hardware but it did not fit snug and the device still leaked. Has anyone else had this problem? If so, how did you fix it?
Go to Lowes or Home Depot and buy a No. 6 o-ring. It goes over the nipple which connects to the detergent reservoir.
Posted on Aug 22, 2009
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Hoover Floormate H3000 Upright Wet / Dry
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The problem could be that the Hoover H3000 Floor Mat could be clogged or something is blocking the suction port or you may have a pinched line of some type of which would cause it to not pickup, also you could have a bad tank assm or like you said in your request that the gaskets need replacing, the tank should fit properly and it could be warped or the gaskets could be bad, feel free to check with a local vacuum dealer in your area or in the yellow pages or the Hoover factory phone number is listed below:
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Posted on Apr 16, 2008
With my floor scrubber, I end up with really clean spots (where the tiles are high) and dirty spots (where the tiles are low). Tips?
High spots are preventing scrubbing element from reaching the lower spots. Guess you will have to get on your knees to finish the job.
Jul 24, 2016 | Vacuums
Why is there only 1 conductor in the power cord?
You always need 2 leads one for the return, power require always a difernce of potential to produce a circuit
Aug 03, 2014 | Blue Wave NE3855 Nitro Wall...
Hoover spinscrub
I would be careful in mixing solutions with different machines. The steamer carpet cleaner applies the cleaning solution differently than the spin scrub. If anything, I would delude the solution before using it in the shampooer. The steamer automatically deludes the solution, the scrubber directly applies a thick coat.
Elisa Jed ' http://www.babayans.com/en/
May 01, 2014 | Vacuums
I HAVE A DIRT DEVIL SPOT SCRUBBER & HAVE NO USER MANUAL & NEVER USED BEFORE. CAN NOT FIND INSTRUCTIONS ONLINE. CAN ANYONE PLEASE TELL ME HOW TO FILL THIS MACHINE & USE PROPERLY? THANKS!
Hi ramond745...
Go to the following webpage and view the operating instructions for your Dirt Devil Spot Scrubber, you can also print the page/s on your printer for later reference.
Please take time to rate me
http://www.ehow.com/how_7830177_operating-dirt-devil-spot-scrubber.html
Aug 16, 2011 | Vacuums
We have a 2x brushes bissell carpet scrubber. Do
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
x
Aug 29, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Help!!
Look up instruction manual at
http://www.dirtdevil.com/CustomerService/Manuals/DirtDevilManual.aspx?ManID=325fa4dd-0a38-48aa-b0b0-516143a0875a
Aug 23, 2008 | Dirt Devil SE2800 Spot Scrubber Handheld...
Nilfisk advance floor scrubber vacuum problem
CAN YOU HELP? I AM LOOKING FOR A SMALL FLOOR POLISHER AND SCRUBBER FOR MY OWN USE AT HOME. i SHOULD HAV TWO 5_6" SCRUBBER PADS AND FLOOR POLISHING PADS. THANK YOU AND GOD BLEES. NORSANRAIDERS@MSN.COM LOWTON , OK
Mar 12, 2008 | Vacuums
No power to scrubber head
Hi Dennis_b,
to continue checking that problem, please see, with an electrical screwdriver, if the machine has energy where the scrubber connects. If yes, the problem is in the scruber; if no, the problem is in the machine, where a red and a black wire makes the connection since the electrical extension to the scrubber connetion, passing thru the swich. it makes me to think in various problems. Even a broken wire can make a malfunction.
Complements
Jan 19, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Need owner manual
Depending on the revision date of your scrubber, here are the manual(s) you seek located on this page: http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=5457 Good Luck
Jun 17, 2007 | Dirt Devil SE2800 Spot Scrubber Handheld...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
4,016 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
