Question about Lands Phones
Installation Commander NT 132 Phone System
I want to install a Commander NT 132 Phone System.
We have a second hand system, I need to buy a frame to mount it on the wall and some tails. (Cords?)
I need a manual or some guidance on where to start.
Please help.
Thanks
SOURCE:
SOURCE: Installation Manual for Siemens Hicom 150e office com system
i have the same problem
Could yoy help whith download an installation manual for the siemens hicom 150e office, thanks
Posted on Nov 12, 2008
  • 7 Answers
SOURCE: We cant hear the phone ring in our office now!
Call your phone from another phone. Don't answer it. Press you volume up/down button. Up makes the ring louder and down makes the ring softer. I bet someone turned you ring volume down. Once it is set it stays there. God Bless. Jerry
Posted on Nov 28, 2008
SOURCE: need user and installation/configuration manual
http://support.avaya.com/japple/css/japple?PAGE=ProductArea&temp.productID=107628&temp.releaseID=194851&temp.bucketID=159898
Programming manual.
Posted on Jan 15, 2009
  • 48 Answers
SOURCE: Need to program my Vodavi Infinite phone system
Here is the Station User Guide for your phone. I hope this helps you out :)
Vodavi Infinite Station User Guide
Posted on Jun 22, 2009
SOURCE: CORDLESS CWD2600 PHONE
if you press the tape button then play you should get your messages.
Posted on Jun 23, 2009
System Commander 9 fails setup
Have you tried loading System Commander 9 without Linux? the reason I ask is when you run a dual operational systems there tends to be issues that come up with certain programs, there have been to many problems with this type of settup.
Apr 17, 2012 | Computers & Internet
My dell pops up with a blue screen and says "STOP: c000021a (Fatal System Error)"
To resolve this issue:
  1. Create a parallel installation of Windows NT.For additional information how to do so, click the article number below to view the article in the Microsoft Knowledge Base: 259003 How and Why to Perform a Parallel Installation of Windows NT 4.0
  2. Start your computer to the parallel installation of Windows NT, and then start Registry Editor.
  3. On the Window menu, click HKEY_LOCAL_MACHINE on Local Machine.
  4. On the Registry menu, click Load Hive.
  5. Type the path to the System hive of the prior installation, typically%systemroot%\system32\config\system, and then click Open.
  6. When you are prompted for the name of the key, type TEST, and then view the following registry entry: HKEY_LOCAL_MACHINE\TEST\Select
  7. Note the setting for the Current DWord value in the preceding registry key. This is typically0x1, and is represented as CURRENT:Reg_Dword:0x1. This value indicates that the "CurrentControlSet" for your original Windows NT installation corresponds to ControlSet001 in this window. A value of 2 would indicate that the "CurrentControlSet" for your original Windows NT installation would correspond to ControlSet002, and so on.
  8. Locate the following registry key HKEY_LOCAL_MACHINE\TEST\ControlSetXXX\Control\Session Managerwhere XXX is the CurrentControlSet that you identified in the preceding step.
  9. Under the Session Manager key, note and then delete any PendingFileRenameOperationsentries.
  10. Click the TEST hive, and then click Unload Hive on the Registry menu.
  11. On the Registry menu, click Load Hive.
  12. Type the path to the Software hive of the prior installation, typically%systemroot%\system32\config\Software, and then click Open.
  13. When you are prompted for the name of the key, type TEST2.
  14. Remove any PendingFileRenameOperations entries in the following registry keys: HKEY_LOCAL_MACHINE\TEST2\Microsoft\Windows\CurrentVersion\RunOnce
    HKEY_LOCAL_MACHINE\TEST2\Microsoft\Windows\CurrentVersion\RunOnceEx
  15. Click the TEST2 hive, and then click Unload Hive on the Registry menu.
  16. Quit Registry Editor, and then restart your original installation.
Sep 30, 2010 | Dell Latitude D600 Notebook
I recently had a HD crash and have replaced it with another HD using the same Windows XP OS. While trying to reload programs that were on the old HD to the replacement, some of the programs get this error...
I always receive a "C:\WINDOWS\SYSTEM32\AUTOEXEC.NT" error message.
“C:\WINDOWS\SYSTEM32\AUTOEXEC.NT. The system file is not suitable for running MS-
DOS and Microsoft Windows applications. Choose ‘Close’ to terminate the application.”
This error message is not caused by the installation CD-ROM, but rather by the
“Autoexec.nt” system file. Windows is unable to find this file when launching the
installation CD-ROM, the file most likely having been deleted by another application.
To resolve this problem, proceed as follows:
1. Go to “C:\Windows\repair” and find the file “Autoexec.nt”.
2.Copy this file to “C:\Windows\system32”.
3.Right-click the file “Autoexec.nt” that you have just copied, and select
“Properties”.
4.Tick the “Read-only” box and then click “OK”.
Aug 06, 2009 | Microsoft Windows XP Professional SP2 Full...
Hi, ihave a dell latitude d600 when i start up i get windows gui up, then i get a stop c000021a fatal error message stating that session manager sys process has terminated with a status of: oxc oooo26c...
  1. Start your computer to the parallel installation of Windows NT, and then start Registry Editor.
  2. On the Window menu, click HKEY_LOCAL_MACHINE on Local Machine.
  3. On the Registry menu, click Load Hive.
  4. Type the path to the System hive of the prior installation, typically %systemroot%\system32\config\system, and then click Open.
  5. When you are prompted for the name of the key, type TEST, and then view the following registry entry: HKEY_LOCAL_MACHINE\TEST\Select
  6. Note the setting for the Current DWord value in the preceding registry key. This is typically 0x1, and is represented as CURRENT:Reg_Dword:0x1. This value indicates that the "CurrentControlSet" for your original Windows NT installation corresponds to ControlSet001 in this window. A value of 2 would indicate that the "CurrentControlSet" for your original Windows NT installation would correspond to ControlSet002, and so on.
  7. Locate the following registry key HKEY_LOCAL_MACHINE\TEST\ControlSetXXX\Control\Session Manager where XXX is the CurrentControlSet that you identified in the preceding step.
  8. Under the Session Manager key, note and then delete any PendingFileRenameOperations entries.
  9. Click the TEST hive, and then click Unload Hive on the Registry menu.
  10. On the Registry menu, click Load Hive.
  11. Type the path to the Software hive of the prior installation, typically %systemroot%\system32\config\Software, and then click Open.
  12. When you are prompted for the name of the key, type TEST2.
  13. Remove any PendingFileRenameOperations entries in the following registry keys: HKEY_LOCAL_MACHINE\TEST2\Microsoft\Windows\CurrentVersion\RunOnce
  14. Click the TEST2 hive, and then click Unload Hive on the Registry menu.
  15. Quit Registry Editor, and then restart your original installation
How and Why to Perform a Parallel Installation of Windows NT 4.0http://support.microsoft.com/kb/259003/EN-US/
Apr 13, 2009 | Microsoft Windows XP Home Edition
Lode needed dlls for kernel
Use the ERD disk and repair the installation. Choose to replace all files, and then replace only the Hal.dll and Ntoskrnl.exe files.
If you can start another installation of Windows NT on the same computer, you can expand the correct Hal.dll and Ntoskrnl.exe files from the Windows NT CD-ROM. To do so, follow these steps:
  1. Boot to the working version of Windows NT.
  2. Start a command prompt.
  3. Change to the CD-ROM drive.
  4. Change to the appropriate folder on the CD-ROM (for example, I386 for Intel-based computers).
  5. Type expand hal.dl_ <systemroot>\system32 where <systemroot> is the path of the non-functioning Windows NT folder.
  6. Type expand ntoskrnl.ex_ <systemroot>\system32.
  7. Restart the computer into the other Windows NT installation.
Mar 27, 2009 | Microsoft Windows XP Professional
A software in which winxp works without any installation
I believe the program you are looking for is called ERD Commander. It was made by Winternals and is no longer availible due to Microsoft buying them out. You may be able to find older copies still available for download on the net if you search for ERD commander or winternals.
Dec 17, 2008 | Microsoft Windows XP Professional With...
P2k commander
If P2kCommander dont recognize your phone please make sure to check the following:
  1. Make sure you have the latest version of P2k Commander software. It can be found here.
  2. You must be running at least one of the following operating systems: Microsoft Windows NT 4.0, microsoft Windows 2000, or microsoft Windows XP SP1. There have been some successes with microsoft Windows Vista.
  3. You may need the Microsoft USB patches installed, although not required if you are running Microsoft Windows XP SP2. (http://www.microsoft.com/downloads/details.aspx?amp;amp;displaylang=en&familyid=733dd867-56a0-4956-b7fe-e85b688b7f86&displaylang=en )
  4. The P2kdrivers must be installed, which are bundled with P2K Commander after version 2.8.
  5. If your phone is connected by USB and P2kCommander is started, try to connect your phone. The new devices must be appear and you must be point the p2kdrivers path to load it on your system.
  6. "hidden folders" which are not shown in filelist but are shown when viewing the phone: These are empty folders.
  7. P2kfilesystem does not show empty folder, but the phone does. To remove recreate the folder and delete it.(the folder not the files)
May 07, 2008 | Motorola Mobility RAZR V3x Cellular Phone
BOOTMGR is missing
i have a problem when my external drive is in the usb and i start my laptop it says bootmgr is missing how can i sort this problem as i have to take it out of the usb plug to get my laptop working the i plug the external drive back in and it works,
Dec 17, 2007 | Computers & Internet
Lands Phones Logo
79 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
