Question about Philips SHE2650 Consumer Headphones
The Case I can't open the case on these headphones Am I really weak or is there a trick I don't know about? It seems like it should just snap but it won't. HELP
  • mts231f Jun 26, 2008
    What the heck is a "socket," in which the phones are supposed to stay? If I pull on the jack, the tangle gets worse, whether the phones are inside the top part (as packaged) or not, and the phones won't fit into the bottom part.
  • amfa Aug 17, 2008
    I can't open the case as well. Is there a way to go about this. I am late for my early morning run because of this.
Please look at this website http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SHE2650/97&scy=AU&slg=ENG&grp=PORTABLE_ENTERTAINMENT_GR&cat=CA00301_CA&sct=SU00318_SU#. Then click on this link How do I use the supplied case?
This was how I got my phones out of the case
Posted on Aug 17, 2008
Keep the headphones inside the socket and pull the jack to unwind it.
Posted on Jun 19, 2008
How to open the case of a my book wd 320gb
Sounds like the drive in the thing is shot or the controller itself.
I remember a friend having one of those I dont recall it having any screws but it did have a snap apart case. Use a thin flat head screwdriver to locate and snap apart the catches.
If you can get into the thing to replace the drive and get the same result then the controller is shot and you will not have any luck fixing it unless you are good at surface mount soldering.
For now, check that the cables are good and that you are connecting it to a good port on your computer.
It is not uncommon to have external drives go kaput for seemingly no reason. The drives they tend to use dont like to be moved AT ALL when they are powered on, this is not condusive to an EXTERNAL case as it is too easy to move around.
Good luck. Let me know if you have any problems getting it apart, I can look up my friend and take his apart, yea hes cool like that.
May 02, 2008 | Western Digital My Book (WDG1U2500)...
Headphone cable unplugged
You should be able to look up the support manual which will contain the information for hooking up your cables on the support website for them.
Most mobo's in general come with manuals for where specific cables and such go.
So as said, go to their support website and lookup the manual for your computer.
Feb 21, 2013 | HP Pavilion Media Center m8430f Desktop PC
My Brother XL-3500 case will not open.
THE final trick !!! just get off the front wheel ..CHECK THE PARTS MANUAL:
http://partsbooks.sewingmachine.com/Brother/Home/PL_BM2700AS.pdf
The page 9 .. take off the # 65 + 64 +63 + 62 then it gets free.. enjoy!!
Dec 23, 2012 | Brother XL-3500
#1. Where can I get a free copy of the Manual for RCAWHP150C Wireless Headphones; #2. How can I us with TV that has not headphone connection?
for Q1 try this one
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000066699.pdf
for Q2 this one should do the trick
Mini StereoJack to Left and Right RCA Plugs
hope that helps...
Aug 07, 2011 | RCA WHP150C Consumer Headphones
I have a vintage ladies wrist watch by CYMA. There seems to be no lip to catch on for opening the back. Does it unscrew?
If the back of your watch is completely smooth, the odds are that it has a snap-fit case. Screw-back wristwatch cases generally have small indentations in the case back into which you fit a case wrench. Rolexes have an elaborately ridged edge to their case backs and take a special wrench. A few early water-resistant watches have little screws that hold the front and back of the case together, but these are usually quite obvious, and you didn't mention them in your description.
Most "fancy" ladies watches of the 40s, 50s, and 60s, had snap-back cases. To open one of these without damaging the case, I recommend gently working a decent quality case knife into the crack where the case back joins the case and gently levering up. If the case is really snug, you may need to do this in a few places to gradually pry apart the case halves. Often, the best place to do this is at the lugs, because they offer a leveraging point. I don't recommend doing this with a sharp knife blade, as the resistance from the case will probably damage the knife edge, and if the knife slips, it can easily scratch the case. If you don't have a case knife, try using the rounded edge of a butter or table knife. Do not use a flathead screwdriver blade, as the short width of that tool can easily place so much pressure on a small section of the case that it deforms and can never be made to look good again.
May 13, 2011 | Watches
Rear headphone jack is not working!
Go into the case and unplug the frount headphone jack to enable the rear, some motherboards are particular on this issue.
Apr 22, 2009 | E-Machines T2898 (764296109563) PC Desktop
Opening the case to repair broken power connector
FIRST FAIR WARNING: This take apart is best left to the repair tech's at an authorized repair facility. There are 6 snaps, two on the top, two on the bottom and one on eash side. I used a thin blunt tip letter opener and started at the top. This didn't leave any marks on the case that would tip off the repair tech's that you goobered it up inside which you will do if you proceed! Release the two at the top first, then the two on the bottom. Now release the one on the side where the power button is located. Open the case on the power button side only about 1/4 inch and slide the bottom off the top being careful not to separate the power cord and headphone connector plugs from the board that they a fastened to inside the case. SECOND FAIR WARNING: It is very easy to pull the connector plugs from the board and this will really convince the repair tech's that you ruined your $350 GPS. Good luck and don't say I didn't warn you!!!!!!
May 13, 2008 | Magellan Maestro 4040 GPS Receiver
Taking apart headphone cases
Carefully remove the padding/leather cover of the headphone and you will see that there are three screws there on the inside part of the casing. Unscrew them and the case will open. Do not try to force open the cases...
Nov 13, 2007 | Philips (33-01-031) Headphones
Philips SHE2650 Consumer Headphones Logo
233 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
