Mitsubishi projection tv vs60va2 picture rolls
My 60" Mitsubishi rear projection TV picture rolls when first turned on . When it warms up, it stoped, but its getting worse. why?
  • sandra martinez Apr 08, 2008
    when tv is first turned on it rolls, after it gets warmed up it quits, or when one of the kids hits the front of the tv it quits.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
This unit has chroin bad caps on the 5v, 9v and 12v regulators. If you know circuitry you can check thos caps and replace the weak or open electrolytic caps. If you call on a tech that services mitsu. this is faily common repair for them and should not cost over 150.00 to 200.00 depending on your area.
Posted on Apr 07, 2008
Diagonal lines rolling or showing on picture
I think that means your FMT brd is going out. you can have a mitsubishi authorized service center come out and send an estimate to mitsubishi for help on the repair, or have a service center come out and repair it, usually about 300-500 out of pocket either way
Mar 17, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Picture rolling when I first turn on my tv
A rolling picture or loss of vertical sync can be caused by several components including a bad signal board or jack panel assy. You will not be able to resolve this yourself. contact a Mitsubishi authorized service center.
michtech
Feb 14, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Oct 25, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Mar 10, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-60707 60 in. Rear Projection Television
When it gets better after warm up it can be a capacitor in the 160 Volt high voltage circuit or a cold solder joint. these 2 thinks would be my best guess on this set.
Oct 26, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi rear projection tv
I've worked on a few of these sets and have found C2P08 to cause something like rolling bars in the picture and have found C2P05 to cause lines jumping in the picture.
Feb 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
151 people viewed this question
Top Televison & Video Experts
