Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Red light blinking
TV can not be turned on. Red light blinking 4 times.
Thanks
  • Jerry Krauz Apr 09, 2008
    The service shop told me it"s a power supply.
    It hard to identify the part, because yhey don't show picture. Ine dealer already sent me the wrong part.
    Scholar:
  • 72 Answers
Did u say it was a error 4 ? if thats the case it is a communication error I2C2_blocked. and causing the TV not to start up. Heres what u do after u plug in the power supply after the relays click before the error flashes on front unplug the connector 1M03 if the TV remains on check connector 1316 for the 24v supply to inverters are there. If they voltage stays with 1M03 being disconnected your SSB is bad. probable the main BGA (Viper) is damaged. hope this helps if not send me a message back and ill help more.
Posted on Apr 15, 2008
SOURCE:
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Tele turned itself off, red light blinks 4 times then pauses and blinks 4 times again.
You can try unplugging it for a while and then plugging it back in, but according to the manual, the standby LED:
Lights up red when your TV is in PC power saving mode. If the LED blinks in red continuously, this may indicate the TV needs servicing.
(Operating Instructions, Page 22)
Mar 05, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
H ave a sony kdfe60a20, just replased bulb and fan for bulb, watched for about 2 hours then tv went dark. Now I have a blinking red light. blinks 4 times pause 4 times continuously until I unplug the tv....
4 times red standby light indicates problem with exhaust fan that is not running for some reason.
Recheck fan that you replaced and make sure its connector is plugged properly and it running freely.
4 times red light blinking is fan error in this tv.
Thanks.
Nov 03, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
No picture or sound. Red light blinking four times on sony bravia tv. Suspect power supply problem?
Red light blinking 4 times on Sony bravia TV.This is the problem of INVERTER BOARD.The inverter board has to be replaced.Every Sony bravia tv has a particular model number and the Inverter board part number depends on model number of the tv. As you have not mentioned the model number so the exact part number of the inverter board is hard to tell.But you can get the required inverter board part for your tv from www.partstore.com ----------- Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation.
Aug 18, 2010 | Sony Televison & Video
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Had Blinking RED blinking lights. FIXED
CHECK LAMP COVER, CLOSE IT AGAIN THE RIGHT WAY
Feb 21, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
The red light on my tv blinks 4 times and will not turn on?
This is most likely due to the all-to-common power supply failure. You can test power with voltmeter
Aug 28, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Feb 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Red lite blinking
help mine is doing it also, 4 blinks, no power
if any gets it fixed or knows how please email me at
[email protected] thanks
Dec 27, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
109 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
