Question about Kitchen Ranges
Maytag gas kitchen range/oven model# MGR575 ADW during preheat cycle in oven seems to keep trying to start left bank of burners over and over again. Gas can be heard flowing an ignition occurs and then burner goes out and the cycle starts over. this continues until set temperature is reached and from time to time while baking it will start to cycle again.
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
That actually sounds to be pretty normal operating procedure unless im not understanding correctly, the unit will shout off, and cycle back on to maintain proper temp as cooks, the" top lef bank of burners" they show signs of clicking??? but not actually igniting correct??? and do they ever start to click when unit is completly off???
Posted on Apr 07, 2008
I have a maytag gas stove model mgr5720adh When I use the oven during the preheat is fine it does take longer to preheat but when it maintaining the temp I start smelling gas.
Change the igniter the igniter is not getting hot enough to open the safety valve and what it does there's not enough heat on the igniter to ignite the flame of the burner
Jan 17, 2017 | Maytag Kitchen Ranges
My Maytag Gas Oven MGR5750ADW preheats on certain temperatures and not others. For example it wont preheat at 350 degrees but will preheat at 380 degrees. At 350 we smell gas.
What you have is an ignition problem get this corrected before you experience a delayed ignition, the hot surface ignitor pulls enough amps 3-3.4 to power up and open the gas valve but ignition did not take place reason you smell gas don't know how old unit is ignitor may be weak good on draws 3-3.5 amps burner ports may be dirty or the bracket that the ignitor mounts too may have bowed away from the burner
Jan 29, 2015 | Maytag MGR5750 Gas Kitchen Range
I have a Maytag gas range model MGR 5729 ADW. My problem is this: 1. The igniter glows brightly 2. Burner will light with a strong woosh, but not until 2-3 minutes. 3. Burner goes out after about 30...
get in a gas fitter to properly diagnose the problem,
igniters in ovens normally click / flash as that ignites gas quicker than a hot wire so I suspect that is problem 1
problem 2 indicates that there is a gas flow problem, probably a faulty hose or regulator
what ever it is , gas is not in the domain of diy so an accredited professional gas fitter is required to do the fix
Apr 25, 2017 | Kitchen Ranges
Oven takes too long to preheat. 20 minutes to get t0 300.
3 possibilities:
1. Broil burner is cycled with bake burner during pre-heat ... make sure both burners are coming on during the pre-heat ... could be ignitor or gas valve failure on one burner ... you can check Broil mode to see if the broil burner ignites...
2. Temperature sensor bad or connections corroded ... this can signal the electronic control that the oven is hotter than it actually is...
3. Fault in the controller itself. If this seems likely we can test/repair it for you if you like.
Best Regards,
Bruce
www.fixyourboard.com
Jun 23, 2010 | Amana ACF3355AS Gas Kitchen Range
My oven flame is yellow and orange. you can smell
open air vent on main burner. check burner orifice and pressure regulater
Dec 31, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
I have a maytag MGS 5770 ADA range/oven. The oven does not heat. The top burners and broilers work fine. However, the bottom oven burner doesnt kick in. the igniter glows red hot but the gas never...
I would start by replacing the ignitor. It could glow enough to light the oven, but to maintain the burner, it often re-ignites several times during a cooking cycle. I have had the problem before, replaced the ignitor and all was well. You should be able to find an ignitor for under $40 online. Just google 'Maytag oven ignitor' and you should find many offers. My sister just bought one for $19.99!
Mar 15, 2009 | Maytag MGS5770 Gas Kitchen Range
MAYTAG GAS RANGE MODEL # MGR5750 ADW
The range has sensed a runaway temperature. if you have a meter you can ohm out the temperature probe make sure it reads around 1270 ohms. if it is way off replace the temperature probe if it is close to 1270 replace the EOC. (Electronic Oven Control)
Dec 15, 2007 | Maytag MGR5751AD Gas Kitchen Range
Unable to preheat
You need to replace the temp. sensor. It's not reading correctly. These occasionally go when you use the self clean as the range gets up as high as 900 degrees. Replace it and it will solve the problem
Nov 29, 2007 | Whirlpool SF367 Gas Kitchen Range
Inacurate temperatures
Often the temp gauge is the culprit. To check temps, allow to preheat for 15 minutes. Monitor the highest temp reached after burner shuts off and record. Then monitor lowest temp before burner cycles back on again. Average out readings. Example, if high is 355 and low is 345, average temp is 350. Do this for 3 cycles and average out.
Nov 19, 2007 | Maytag MGR6772 Gemini Gas Kitchen Range
Kitchen Ranges Logo
219 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
