Question about Dryers
Where can i get a wiring diagram for a kemore elec dryer model 110.86692300?
  • 5,911 Answers
The model number you provided is for a stacked model washer/dryer combo. If this is correct, look behind the panel directly below the operator console. The manufacturer usually places a wiring diagram behind the panel for service technicians. Post back if it is not there and I will see if I can provide you with a better solution.
Posted on Apr 07, 2008
6ya staff
SOURCE:
How do u put a kenmore dryer belt on do u have a diagram?
all kenmore dryers much the same procedure to change the belt
the casing has to be opened
some dissa sembly required
link as an example of how its done on any dryer unit
copy and paste link into your search engine
https://www.youtube.com/watch?v=x6zFGUpfC18
or
https://www.searspartsdirect.com/repair-guide/dryer/how-to-replace-a-dryer-drive-belt.html
May 29, 2016 | Kenmore Dryers
How to replace belt on kenmore model 11087673100 Dryer?
there should be a belt diagram on one of the inside panels to the unit
Best regards
Ck
Aug 18, 2011 | Summit Commercial Summit CEDC392PQ ELEC...
Kemore dryer model 65862 not heating. Replaced the heating element and verified that the thermastat is getting continuity.
do you have both power phases as in 120 volts per leg? also check your neutral wire at the dryer element if it uses one, they carry the im-balance of current and get brittle with age and break at the heating terminal connection
Oct 02, 2009 | Dryers
LG elec dryer will not turn on...
Check your breaker. When you swapped one of the hot legs (red and black) with the neutral (white) the breaker should have tripped as soon as you plugged it in. If the breaker isn't tripped, check the wiring diagram to see if there are any internal fuses in the control panel that might have fried.
Aug 29, 2009 | LG DLE2532W Electric Dryer
My kemore dryer model 11071812001 not drying clothes
Sounds like the problem is the solenoid coils on your gas valve. easy to replace and inexpensive + common. their are 2 coils on the valve that have 2 wires each going to them. Let me know if you have any other questions,
Phil
Jun 10, 2009 | Kenmore 73952 Gas Dryer
Kemore dryer (Mod#110.66512694) stops running
Reach inside and turn the drum. If it is hard to turn then something may be causing the motor to get hot and quit on overload. An overload is wired into each motor to prevent the copper from melting. If the drum is hard to turn you might want to inspect the rollers and idler. ACCESSING YOUR MACHINE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 16, 2009 | Dryers
Kemore igniter/glow bar repair
What is the model from the inside of the door. Go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears And enter it and you can get a diagram of the machine. Most of them are right up front on the right side. They are held in by 1 screw but be carefull putting in the new one. They break easy. Let me know if you need anything else. I'll be glad to help
Mar 29, 2009 | Kenmore 73952 Gas Dryer
Kemore Elite Dryer - no hot air
kenmore gas dryer heats at first, then cools off rest of cycle.
Jul 26, 2008 | Kenmore 74602 Gas Dryer
WHERE CAN I FIND A WIRING DIAGRAM FOR A KENMORE ELEC DRYER MODEL 110.86692300?
THERE IS USUALLY ONE ATTACHED SOMEWHERE IN THE DRYER. TRY INSIDE THE CONSOLE, FOLDED UP AND WEDGED BETWEEN THE WIRING. ALSO, SOME DRYERS WITH A TOE PANEL ON THE FRONT, HAVE THE SCHEMATIC GLUED TO THE INSIDE OF THE TOE PANEL.
SOME OF THE OLDER DRYERS HAD IT GLUED TO THE BACK PANEL.
Apr 07, 2008 | Dryers
Kemore Dryer / Model # 63742
I'm not familiar with this specific Dryer, but in most of them you can find their wiring diagram glued under the upper panel or the rear panel. Good luck !
May 16, 2006 | Kenmore 64742 Electric Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
jimorris77
