Question about Fuji FinePix F470 Digital Camera
Fujicamera f471 camera
Alot of my pictures have red eye. How do i fix this?
    Genius:
  • 2,985 Answers
Use an Image Editor the has Red Eye reduction mode
A Free one is Googles Picassa.
Read uop the camera manual on how to achieve this also
A comprehensive manual is usually to be found on the CD in PDF format
Posted on Apr 07, 2008
SOURCE:
Tip
How to remove red eye / eyes in pictures using Windows 7 built in tools
You don't need specialized programs or photo editing software to fix a red eye in Windows 7. You will only need to have MS Office 2003 or later installed or download a small free program called Red Eye Remover.
IF YOU HAVE OFFICE 2003 OR LATER INSTALLED
Go to the picture from which you want to remove the red eyes. Then , right click on the image and from the open with menu , select Microsoft Picture Manager.
This will open the program and load your picture to it.
Now select the edit picture button.
This will bring up a toolbar at the left of the window with the photo editing tools.
1) On the bottom of the toolbar , zoom using the slider so that you can clearly see the eyes you want to edit.
2) Then , on the right hand toolbar , select the Red Eye Removal Tool.
Now click on the eyes you want the red removed from. A little red eye should appear after clicking.
After selecting all eyes , click the okay button. This will fix the eyes selected.
After the eyes are fixed , just click on the save button or select save from the file menu.
IF YOU DON'T HAVE OFFICE INSTALLED
Download and install Red Eye Remover by clicking HERE.
Now , drag your picture into the program.
Now , use you mouse wheel to zoom in and center you screen so that you can see the eyes you want to edit.
Now , simply click and drag a rectangle around the eye and release. The program will automatically detect the red eye and remove the red out of it.
When done, simply click file, save as and either replace the original photo or save it as a new copy.
Please remember to rate this tip if you found it useful.
Kind Regards
StephanSA
on Feb 25, 2010 | Cameras
Red eye on sanyo digital camera xacti,always theres a red eye when taking pictures,i already adjusted everything,still occuring red eye.
Do you mean your subject's eyes are showing "redeye"? This is a common problem with cameras that have the flash very close to the lens. Almost every photo editing program has a tool to remove red-eye. Check your computer to see what you have installed. In the future, most cameras have a red-eye flash setting which shoots a short flash before the main flash to close down the pupils in your subjects eyes to eliminate red-eye. You could also turn up the lights in the room...sometimes that helps.
Apr 28, 2010 | Sanyo Xacti VPC-T700 Digital Camera
How do you activate red eye reduction in the 5900?
To take photos with red eye reduction requires your flash to firerapidly before snapping the pic. Make sure camera is in record mode pres the 4 way switch with the lightning sign on it. The flash modes will pop up. select red eye flash.
To fix red-eye after a photo is taken. Bring up the photo in playback mode and press menu button. Red eye reduction should be available as one of the menu items. Otherwise, display the pic, press OK button in center and if you like the fixed picture then select yes to store it.
Jan 12, 2009 | Nikon Coolpix 5900 Digital Camera
I get eyes that glow white in my pictures
bubba41, You didn't mention using the built-in pop-up flash that's when you get the "red-eye" and you can set the flash for redeye reduction when it's used.  If you are taking an indoor photo without the flash, if the redeye reduction is on turn it off that would eliminate the zombie or X-men eyes you are describing. randy320sgi
Jan 10, 2009 | Nikon D70s Digital Camera
Cannon Powershot SD 870
you can change it to no flash by when your taking a picture press the right arrow
Jul 01, 2008 | Canon PowerShot SD870 IS Digital Camera
Red eye and wise shot
I can help with the red eye - I've had the camera a year now and have only just found it myself!! - After you've taken your shot, review the picture and then press the Hold button, press the right side of the menu button, just as you would when switching through your pics. In the blue menu bar at the top you will see the red eye 'paint' symbol, press down on the menu button and it will 'red eye fix.
Dec 17, 2007 | Samsung NV3 Digital Camera
Red eye reduction
while in record mode, press the flash/up button repeatedly until you are in red-eye reduction mode. red-eye reduction mode should greatly reduce the problem when enabled. If this does not work, the software that came with your camera (and most photo editing applications) include a red eye reduction/removal filter.
hope this helps,
trin
Nov 17, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Red-Eye Fix
Here is a link to the product manual: http://alpha03u.c-wss.com/inc/ApplServlet?SV=WWUCA900 It states that to turn on red-eye reduction mode (p.43), go to the Camera menu, then set the top setting (red-eye) to "on". Even if you are unable to get this to work (or if you do get it to work, but are unhappy with the results), there is a really nice free proto organizer (www.preclick.com) that includes a red-eye removal tool that is really simple to use.
Feb 11, 2007 | Canon PowerShot A520 Digital Camera
Animal Eyes
I've seen some of those white eyes photos. Some are down right scary. I'm sure you have encountered red-eye when taking flash photos of people. With some animals, it is not red - but white. .... Try to catch the animal looking away from the camera when you take that flash picture. Have someone distract him/her. ............ Fixing Demonic Pet Eyes http://graphicssoft.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=graphicssoft&zu=http%3A%2F%2Fwww.myjanee.com%2Ftuts%2Fpeteyes%2Fpeteyes.htm http://graphicssoft.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=graphicssoft&zu=http%3A%2F%2Ftlbtlb.com%2Ftlbimages%2Fmax2.html
Aug 31, 2005 | Canon PowerShot SD400 / IXUS 50 Digital...
Fuji FinePix F470 Digital Camera Logo
62 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
