Question about Dryers
WHERE CAN I FIND A WIRING DIAGRAM FOR A KENMORE ELEC DRYER MODEL 110.86692300?
    Novelist:
  • 184 Answers
THERE IS USUALLY ONE ATTACHED SOMEWHERE IN THE DRYER. TRY INSIDE THE CONSOLE, FOLDED UP AND WEDGED BETWEEN THE WIRING. ALSO, SOME DRYERS WITH A TOE PANEL ON THE FRONT, HAVE THE SCHEMATIC GLUED TO THE INSIDE OF THE TOE PANEL.
SOME OF THE OLDER DRYERS HAD IT GLUED TO THE BACK PANEL.
Posted on Apr 08, 2008
Kenmore elec dryer model 110.68722700 Where do belt switch wires attach to motor?
If your dryer is a fairly new model, the front panel below the loading door should have a service manual shematic in the inside of the panel. It is usually taped to the inside. Start there if not then you will have to go online and source out the schematic, you may have to pay for the file but it would be well worth it
Sep 03, 2014 | Kenmore Dryers
Hi Ginko. I have a Kenmore dryer model 11086810100 that has some wires removed from inside. The only HOT I can find is the red wire. I have 2 wires that have femals push-on crimped terminals, but I have no...
Hi Robert.
Thanks for the pics. I operate in UK and color codes here are different.
From what I can see the wiring in your picture does not match the US standard either.
The thermal fuse for example should have two blue terminals, not red and blue. The thermal fuse wires goes on one side to start, and on the other to the drive motor through the broken belt switch (if present).
The wiring at the blower must be revised and done again.
Here a service manual covering Kenmore 70 series dryers.
http://www.applianceblog.com/mainforums/attachments/sears-kenmore/3298d1196129125-kenmore-dryer-model-110-86870100-wont-heat-ldrwp-checkpoints.jpg
There is a wiring diagram at page 25.
Here a picture showing correct wiring: http://www.applianceblog.com/mainforums/attachments/sears-kenmore/3298d1196129125-kenmore-dryer-model-110-86870100-wont-heat-ldrwp-checkpoints.jpg
See also the pictures in this blog:
http://www.satfix.net/showthread.php?931-How-Dryers-work.-Whirlpool-Inglis-Kitchen-Aid-Kenmore-Admiral-Roper
About the red and yellow cable, the only red yellow wire in the diagram operates the switch for the guard function. The wire becomes hot and powers the motor when the guard switch is closed.
Parts (including wiring harness and terminals) are available here:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11086810100/0582/0151200?pathTaken=&prst=0&shdMod=11086810100
Jan 02, 2012 | Kenmore Dryers
How to replace belt on kenmore model 11087673100 Dryer?
there should be a belt diagram on one of the inside panels to the unit
Best regards
Ck
Aug 18, 2011 | Summit Commercial Summit CEDC392PQ ELEC...
My kenmore elec. dryer 67042 model wont get hot...I never recd a manual..need diagram to dis assemble and examine the unit! Can u help me find a diagram?
Make sure the unit is not plugged in when testing these fuses.You should also check the continuity on the heating element if all fuses check out as good.You may also need to check the main power at the terminal block and make sure you have 220 volts to the terminal block.These are all located on the rear of the dryer remove the back panel to get to them.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Mar 19, 2011 | Kenmore Dryers
Kenmore elite elec dryer, 110.64972300. runs no heat
Pull one wire off the element and start the dryer in a heat cycle . Check power from that wire to the cabinet . Touch the meter to the terminal you pulled that wire off of , and check that voltage . You cannot get correct voltage by checking across the element . Trace the wire NOT getting 120 volts . It will either go to the timer or motor . It will lead you to the problem .
Apr 28, 2010 | Kenmore Elite HE4 Electric Dryer
WIRING DIAGRAM
The manufacturer normally places a wiring diagram inside the operator console. Remove the back panel and there should be a diagram taped inside. Some of these diagrams will show two circuits. One is for a gas dryer, and one is for an electric dryer. Make sure you reference the correct one. I hope this helps you. If you need further assistance please let me know.
Aug 13, 2008 | Kenmore 63942 Dryer
Where can i get a wiring diagram for a kemore elec dryer model 110.86692300?
The model number you provided is for a stacked model washer/dryer combo. If this is correct, look behind the panel directly below the operator console. The manufacturer usually places a wiring diagram behind the panel for service technicians. Post back if it is not there and I will see if I can provide you with a better solution.
Apr 07, 2008 | Dryers
Dryers Logo
173 people viewed this question
Top Dryers Experts
