Question about Dishwashers
I cleaned some furnace electric filters in my Kenmore dishwasher and covered the inside with a dark stain from the dirt. I still have the stain after a month of using the dishwasher for normal use. What/how do you suggest I clean out the interior? Thank you.
  • 32 Answers
Try a product called " greased lightning". spray bottle, should work for you. apply, let set for a few minutes and scrub with plastic bristle brush . you may have to er-apply and scrub a bit, but it will remove the tar.
future referance; try this product and spray your filters clean with your garden hose.[maybe even an oven cleaner and hose]
gemerally the thngs that gather on an air filter i dont want in my
dishwasher.
Posted on Apr 07, 2008
Cleaning instructions
Dirt is the biggest enemy of your furnace. It can waste fuel and drastically lower efficiency. Dirt affects all three basic components of your furnace, so cleaning is the most important part of regular maintenance. The three parts of the furnace should be cleaned: the filter system, the blower, and the motor.
The furnace filter should be replaced or cleaned at the beginning of the heating season and about once a month during periods of continuous use. To check the filter, take it out and hold it up to the light. If it looks clogged, replace it with a new filter of the same type and size regardless of the length of time it has been used.
Step 4: Clean blower assembly, belts and pulleys to blower, and motor housing. Cleaning blower is critical if furnace has a squirrel-cage fan, because openings in this type of blower often become clogged with dirt. To clean blower, remove panel that covers filter to gain access to blower or panel on front of furnace. This panel may be slip-fit on hooks or held by series of retaining screws. Access to inside of blower is usually gained by sliding out fan unit, which is held on track by screws.
If power cord to fan assembly is not long enough to permit fan unit to slide all the way out, disconnect cord. Mark wire connections first so you'll be able to reassemble unit correctly. With toothbrush, clean each fan blade and spaces between blades. Then, with vacuum cleaner hose, remove all dirt and debris loosened by brushing. Vacuum belts and pulleys. Wipe motor housing clean to prevent heat buildup in motor.
Feb 08, 2013 | Rinnai Toyostove Direct Vent Heater:...
Dishwasher does not clean properly, leaves white stains on dishes
check the can of salt inside the unit if empty refill that one,but not ordinary salt,buy onit the salt for dishwasher,or check the filter inside the unit is some foreign object,remove it to clean the water.and use only the dishwasher soap the solid one is good compare to liquid.
Jan 01, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
This is a 3 yr old dishwasher with very gentle use. It now is not cleaning glasses....even when rinsed before hand the glasses are still stained and spotted. Also my silverware needs to be completely...
Hard water stains are easily taken care of with the help of vinegar. Add 1/4 vinegar to the cycle when you start it and it will help to remove spots and cloudiness.
As for food residue you might check your filters and water pressure.
Oct 30, 2010 | Kenmore 13863 Stainless Steel Dishwasher
I am getting stains on my dark clothes that look like oil stains.
Check that the dispenser is clean, it may be gunged up with black gunge, use soda crystals and put machine on hottest wash. If all is clean it could be down to seal gone in drum letting grease into system. Good luck, let me know how it goes.
John
Sep 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite dishwasher not cleaning well and leaving dark stains on the dishwasher walls. water pumps in to correct level and pumps out. First cup of soap the water is just warm. Second up its hot and...
Check the following to address this issue
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Jun 04, 2009 | Kenmore 24 in. 16049 Built-in Dishwasher
Dishes not always clean and dirty water sometimes in bottom and food stains sometimes on inside compartments is it the filter or the inlet valve?
it shouldnt be either run an empty cycle and see if the water drains out all the way something may be stopping the drain
Apr 29, 2009 | Kenmore Dishwashers
Kenmore Dishwasher - stops cleaning dishes - 2 techs just scratch their heads - any suggestions? water is hot, changed soap, still not even coffee stains inside cups are cleaned, let alone the rest.
ensure spray arm holes are not blocked, the water level is good, the spray of water is strong, it is heating and the tablet is entering the wash, not much else can cause a bad wash. note dishwasher may not always be able to get rid of some coffee stains.
Mar 04, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kenmore Elite calypso 21086 leaves dirt streaks on clothes
Run the hottest & fullest cycle possible - without a load - and add a grease remover - like goo-gone. Fatty tissues build up inside the tub - and can be released on hot cycles if HOT wasn't used very often.
It is recommended to run a HOT load every 2 weeks or so to avoid these buildups and staining of clothes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 20, 2009 | Kenmore Elite 21086
Kenmore dishwasher leave white stain in dishes
probably detergent. try cleaning the sump out. here is how
ok in the dishwasher you will see you lower spray arm. take it off. now going up the back is the supply tube. you need to pop it off of thed top then the back and turn it clockwise to get it off the motor. after you do that you will see 4 torx screws. take all 4 out and you will be able to remove the fine filter. thats the normally grey piece with all the slots. after you remove the filter you will see two more torx screws. remove them they are for 2 seperate pieces one is the foreigh food seperator and the other is the chopper cover. remove both of them and clean the whole thing out. as yiou are puytting it back together. let me know if you get stuck
Nov 30, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Permanent (?) stains on inside of door
Have you tried a treatment (not sure of the name) that you wash plastic dishes with that takes the orange stains out? It can be found at Walmart for under $10. I don't know of anything that can prevent this problem but I don't see why a product that takes it out of plastic dishes can't take it off the plastic of the dishwasher. Hope it helps!
Sep 05, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
132 people viewed this question
Top Dishwashers Experts
