Question about Radio Communications
Albrecht ae4180 AM/ FM CB Radio repair manual... No transmit and receive...
I need badly a service manual or schematics for Albrecht ae4180. I just brought it second hand. The transceiver works, but the microphone has some PTT and connections problems. I tinkered for a while with the switch and pin connections. Unfortunately, I accidentally shorted something (I think it has something to do with the mic's center voltage pin and the RX-TX switch or input). An electronic component went on smoke, but I couldn't locate the burnt part or identify if it was a diode, a capacitor, a resistor, and an IC. I already used a magnifying glass to locate the burnt part, but all components seems to be intact (no cracks, no burn)
Please help. I know this is a German made CB Radio, and I already looked for documentations on the web, but they are very limited (and most of them ar written in Dutch language). I need to identify which part went up on smoke and possibly damaged.
My unit still powered up. It goes through channels 1 to 80, and with modified AM/ FM switchable bands on all channels. It has fully functional LCD display and switches. But no receive and transmit, though I can see a 1 bar in the RX signal indicator on both AM and FM band. The channel switching becomes too slow too, as a result of the damage.
I hope I could still put this lovely radio to work, just hoping that radio's microprocessor still works.
Thank you soo much!!!
    Scholar:
  • 67 Answers
Http://www.thiecom.de/ftp/albrecht/ae41xx/information/circuit-all-versions.pdf
That is a schematic.
And from the ftp web site - but in german :
http://www.thiecom.de/ftp/albrecht/ae41xx/information/
Hope this helps some.
Kevin
Posted on Apr 12, 2008
SOURCE:
Problem no squelch noise or speaker like its muted, but can hear weather ok shows receiving and ant ok
Since the radio cannot transmit on Weather bands, there is no need for the radio to detect if it is transmitting when receiving weather.
In CB mode (on CB channels) the radio will mute when transmitting. So... a guess is that it is muting, or transmitting all the time in CB mode. Check for a mic problem by removing the Mic from the radio ... if it receives CB with no mic connected, then there is an issue with the mic. Otherwise, unless the unit is in PA mode (public address mode) it is likely something internal and beyond the scope of this service.
Sep 08, 2015 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
How to get emperor ts-5010 to transmit on 29.520 fm and receive on 29.620?
This is an "Export-Only" radio that is banned by the FCC for use in the United States. It is a violation of Title 47 U.S.C. for any "CB" radio to be coincidentally capable (or modified to be made capable) of transmitting on frequencies assigned to the Amateur Radio Service. It is also against Federal statutes for any Amateur Radio equipment to be used for communicating on frequencies assigned to the Citizens (CB) radio service.
Jun 12, 2014 | EnGenius 800mW 802.11abgn ECB600 AP / CB /...
No transmit or recieve
sounds like a repair for a tech to me.
Jan 16, 2014 | Galaxy Radios SSB Echo Base Station CB...
No receive audio no receive signals but transmits
If you have a schematic and a service manual try tuning the receive . If that doesn't work use it for parts .You can't buy another and that is the only way that is cheaper .the radio ,new/used will cost less than a tech will charge to repair it.
Dec 20, 2013 | Radio Shack Powered ON TRC-444 40- Channel...
Cb is recieving but not trnsmiting
Ah! these and the cobra 2000 had the same board and same problems--
Some will have no transmit audio (check or sub to make sure microphone not the problem) and others no receive audio.
If circuit problem both are caused by a filter cap that opens.
Usually this occurs when radio has not been used for a long period of time.
If you have a schematic for the radio (mine are all out of reach) you will find in the audio circuit a cap (I think it is 220 uf at 10 volts) right near where the volume is controlled that is bad.
The no transmit audio problem is another cap in the mic circuit.
I hope this helps you as it is likely your problem--note if the audio output IC was bad no receive or transmit audio.
shoot me a question by using the make comment if you need further help.
73's
Mar 23, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
2002 Honda GL 1800 Gold Wing CB radio receives but won't transmit
Hi, Ohenry428 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
New CB Radio in 02 GL1800 Won Transmit
cb radio no transmit GL1800 Information Questions goldwingdocs com
Honda GL1800 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
http://goldwingchrome.com/Manuals/GL1800/Honda%20Goldwing%20GL1800%202003%20Owners%20Manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 20, 2010 | 2002 Honda GL 1800 Gold Wing
Please explain a 10 meter am/fm radio
Okay.
You do set this up like a regular CB. The meters refers to how long the waves are. CB is 11 meters. So its very close. The antenna woud be tuneds slightly shorter. Use the SWR meter in the radio to calibrate just like you would a normal cb.
Now for the ABCDEF knob. each letter is 40 channels in the band. So A would be 1 - 40 channels, then B would be the next 1 - 40 channel frequencies. You use the frequency counter in the radio(providing that model has one) to tell what channel you are on.
Here is some info one the frequencies in the band.
Now for AM and FM. this is the type of modulation you are using for transmit and receive.
CB transmits on AM or SSB. Amplitude modulation or Single side band. Most CB radios only have AM. But some also have SSB. None will have FM.
FM is frequency modulation.
10 meter radios can have AM FM SSB and DSB depending on the model and options it comes with.
So your radio has 6 ranges for freqency. each is 40 or 50 channesl. Not sure what model you have. If it has 40 then you have 240 channel freqencies.
with AM and FM, you double that, because you can talk on AM or FM on all the channels. If you are on AM and some one transmits on FM unless they are really close, you will not hear them at all, but if you do with will just be garbbled noise.
Also Am and FM both work a little different with range etc.
Now, you may be able to talk on the CB channels as well. Cb starts at 26.965 MHz and ends at 27.405 MHz. The channels are all .010 MHz appart.
Hope this helps
Dec 09, 2009 | Radio Communications
Radio Communications Logo
732 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
